Old 02-08-2015, 04:56 PM   #801
K20chevy
K20chevy's Avatar
Re: off it goes
[QUOTE=CHROMAHOLIC;7027141]^^lol, thanks guys...we've been test fitting the wiring so not many new pics, we did the cable driven wipers mounted (hopefully I will never need them but better to be safe then sorry) went cable driven so wiper motor could be hid in cowl area.. We did finish up the rear splash pans, just wanted something to hide compressors and tank but still let in air flow to cool the compressors yet quite them down a bit. Also have a drain for the water trap in the one splash pan and then a drain cock for the tank, both done so things can be drained without removing the splash pans
Would you be willing to do another set of the mesh stainless steel cover? And if so, PM me with details. Thank you!
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104
68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441
K20chevy is offline   Reply With Quote
Old 02-08-2015, 05:02 PM   #802
CHROMAHOLIC
CHROMAHOLIC's Avatar
Re: off it goes
I would but the problem with making you one is that we actually changed the cowl holes to make them a little more symmetrical. So it most likely wouldn't line up with the stock holes....
CHROMAHOLIC is offline   Reply With Quote
Old 02-08-2015, 05:19 PM   #803
K20chevy
K20chevy's Avatar
Re: off it goes
Hm... is there any way you could make one for the stock holes?
Old 02-21-2015, 08:17 AM   #804
CHROMAHOLIC
Re: off it goes
lol, thanks guys
Old 02-21-2015, 08:48 AM   #805
CHROMAHOLIC
Re: off it goes
Sorry....I probably couldn't make a factory cowl screen now, just due to the fact that I don't have a template to work from. We tried a couple of variations of templates to see what we thought looked the best, I initially in my mind wanted two pieces but once we laid it out on the truck I didn't like how one wiper wasn't behind the cowl and one wasn't. (I'm funny that way, some call it a sickness, lol)
So I really don't have anyway of making one without a template to work from. We changed the hole shapes, sizes and stretched it farther to the drivers side...
Factory
Stretched farther to drivers side
What I had thought I wanted ( 2 Piece )
Old 02-21-2015, 09:47 AM   #806
Ohchiiit
Ohchiiit's Avatar
Re: off it goes
very very impressive build! your truck is what dreams are made of! hope theres a young child in the family that will have the opportunity to show and tell the unborn hot rodders just how cool his dad/grandfather was back in 2015! BADA$$ RIDE!
Ohchiiit is offline   Reply With Quote
Old 02-21-2015, 10:02 AM   #807
Hart_Rod
Hart_Rod's Avatar
Re: off it goes
Impressive build. Can't wait to see it finished.
Hart_Rod is offline   Reply With Quote
Old 02-21-2015, 10:31 AM   #808
CHROMAHOLIC
Re: off it goes
thanks guys.....
Old 02-28-2015, 09:18 PM   #809
CHROMAHOLIC
Re: off it goes
Brake lines are just about done....from reservoir down the firewall through the top of the frame rail
Machined out new rear fender braces, instead of the bolt going through the eyelet we machined these and tapped the bottom so this way they hold the fender with a stainleless button head through the bottom of the fender
Old 02-28-2015, 09:25 PM   #810
mooseknuckles
mooseknuckles's Avatar
Re: off it goes
Sick!!
mooseknuckles is offline   Reply With Quote
Old 02-28-2015, 09:42 PM   #811
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: off it goes
Never a cut corner. Great stuff.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 03-01-2015, 03:47 AM   #812
Gregski
Post Whore
Gregski's Avatar
Re: off it goes
Chip? Chip Foose, is that you, LOL, jk!
Gregski is offline   Reply With Quote
Old 03-01-2015, 06:01 AM   #813
CHROMAHOLIC
Re: off it goes
lol, thanks guys....
Old 03-19-2015, 02:20 PM   #814
nickbwilson
Re: off it goes
Beautiful build so far my question is where did you get your cold air intake parts from the tubing????
nickbwilson is offline   Reply With Quote
Old 03-19-2015, 06:24 PM   #815
CHROMAHOLIC
Re: off it goes
thanks
http://vibrantperformance.com/catalo...dcf3425151e4dc
Old 03-24-2015, 04:27 PM   #816
nickbwilson
Re: off it goes
Did you buy A 90 and weld a piece of straight pipe off the 90 over to the inner fender well, just asking because the intake tube coming out of the throttle body looks like its a solid piece then you welded the end on where it goes from shiny to scuffed up? thanks for all your help
Old 03-24-2015, 05:03 PM   #817
RebelSoldier
RebelSoldier's Avatar
Re: off it goes
It looks badass. Love the wheels.
RebelSoldier is offline   Reply With Quote
Old 03-24-2015, 07:31 PM   #818
CHROMAHOLIC
Re: off it goes
one piece from throttle body to where it's scuffed, then we welded a 90 into the fender
Old 03-24-2015, 07:32 PM   #819
CHROMAHOLIC
Re: off it goes
thanks
Old 05-09-2015, 12:07 AM   #820
ajgriffin
ajgriffin's Avatar
Re: off it goes
Any updates?
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 05-09-2015, 06:56 AM   #821
CHROMAHOLIC
Originally Posted by ajgriffin View Post
Any updates?
Not really any pics to post, we've pretty much have it all wired, exhaust just showed up...so time to start fabbing it up. After exhaust it's tear down and paint. Actually took a month off on the build, just to relax, re-coop, refill the wallet, lol. Sometimes on big projects like this a break from it is nice....we are building our own exhaust so I'll post pics soon. Thanks for the interest in the project
Old 05-09-2015, 09:32 AM   #822
68Timber
I know the pieces fit
68Timber's Avatar
Re: off it goes
I just noticed the brake line loop tucked under the firewall. Cool detail.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 05-16-2015, 10:13 AM   #823
66Slabside
Re: off it goes
Just invested a Sat morning reading this instead of working on my own car (no I don't have a truck yet but it's my next project.) Everything that could be said has been said about the level and quality of this build. Subscribed and in for the long run. i mean who cares if it takes 5 years, it'll still be way better than most guys who take ten years to build a truck.
Thanks for sharing.
66Slabside is offline   Reply With Quote
Old 05-16-2015, 01:04 PM   #824
CHROMAHOLIC
Thanks for sharing.
Thanks for the compliments....we're getting there, slow but steady....stay tuned we'll have some exhaust pics coming soon
Old 05-17-2015, 07:38 AM   #825
CHROMAHOLIC
Re: off it goes
first time motor has been in the truck with the fuel rail cover on
