Old 09-25-2012, 10:54 AM   #801
shawno72
C/10 junkie
shawno72's Avatar
Re: Project Grande Slam: Coley's Hot Rod Shop
Originally Posted by CC69Rat View Post
Eric's Cheyenne Super, etc. I wouldn't be going this low ..
I sure want to go this low......
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 09-25-2012, 10:55 AM   #802
shawno72
C/10 junkie
shawno72's Avatar
Originally Posted by gringoloco View Post
To give you an idea, here's mine w/ a 6" drop coil and 1.5" blocks. Sits just right, IMO. The caveat here is that I did the trailing arm mount 'flip', which I recommend, but it did raise the rear around 3/4" higher. Top pic is pre-flip. You will absolutely require a c-notch at this height.
What is your front drop?
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 09-25-2012, 11:01 AM   #803
CC69Rat
CC69Rat's Avatar
Help me understand the trailing arm mount flip (?)
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 09-25-2012, 11:11 AM   #804
lolife99
67-72 parts collector,…
lolife99's Avatar
The spring is the pivot point.
Move the front of the trailing arm up.
The rear of the trailing arm moves down.
Keith
Convert to disc brakes.
Old 09-25-2012, 11:13 AM   #805
gringoloco
A guy with a truck
gringoloco's Avatar
3" Belltech spindles and trimmed 1" Belltech drop coils. Figure around 5" drop. I have Porterbuilt arms going on to push that wheel forward in the arch...
Fixes your rear geommetry at extreme drop levels, bringing it back closer to stock. benefits pinion angle and antisquat/dive. Check these links:
NoLimit Rob's "Make it Handle" thread:
http://67-72chevytrucks.com/vboard/s...&postcount=270
A couple talking about the 'flip':
http://67-72chevytrucks.com/vboard/s...d.php?t=439768
http://67-72chevytrucks.com/vboard/s...d.php?t=362464
...and the raises ride height discussion:
http://67-72chevytrucks.com/vboard/s...d.php?t=496411
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-25-2012, 11:16 AM   #806
Rusbuilt
Rusbuilt's Avatar
Thats good info! I may try this!
Rusbuilt is offline   Reply With Quote
Old 09-25-2012, 11:40 AM   #807
CC69Rat
CC69Rat's Avatar
So, correct me if I'm wrong. .. doing this adds to the rear drop? by ~.75" ? Axle ultimately sits higher / closer to the bed floor?
The original holes in the top would index into the holes in the bottom in a direct 180* true "flip" of this bracket? I can see where it would change the 'tilt' of the pinion angle to correct in low drop angles. Does this put it back to (or close to) the factory pinion angle or would I still need shims?
top to bottom, left to right. Original hole #1 would drop into hole #6 making it a direct 180*flip? Holes #2 and #3 in the bracket would then need to be re-drilled into the cross member because there were no holes there originally. The original cross member holes can be re-drilled and matched for 8 total bolts? Am I seeing this correctly?
Chad
Old 09-25-2012, 11:51 AM   #808
Rusbuilt
Rusbuilt's Avatar
Looks to me like it takes away from the drop a bit and it would bring pinion angle closer to stock but not exact.
Old 09-25-2012, 11:52 AM   #809
lolife99
lolife99's Avatar
correct.
Keith
Old 09-25-2012, 11:56 AM   #810
CC69Rat
CC69Rat's Avatar
.... but it did raise the rear around 3/4" higher. Top pic is pre-flip. ..
Sorry .. I see it now.
Chad
Old 09-25-2012, 01:56 PM   #811
NoNeck
NoNeck's Avatar
Flipping the trailing arm brackets seems like a lot of work. Plus you are RAISING the truck by 3/4".
Why not use some degree shims like the ones pictured (not these, they are for leaf springs), between the rear end plate and trailing arm? That's what they are designed for. If they don't make 'em, I can have some made up with the exact amount of pinion correction for the U-Bolt design.
Question: Where do you mount the brake line union on the frame rail once the Porter
Built crossmember/shock locator is installed?
POP
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 09-25-2012, 02:02 PM   #812
lolife99
lolife99's Avatar
You can buy trailing arm shims here:
http://www.stockcarproducts.com/trkarm1.htm
Keith
Old 09-25-2012, 02:11 PM   #813
CC69Rat
CC69Rat's Avatar
Pop -- Take a look at the Hotchkis writeup here:
http://www.truckinweb.com/tech/suspe.../photo_27.html
My flipping the mounts for the trailing arms, it not only corrects the pinion angle but it will help the truck with handling, etc. Hotchkis makes a bracket to do essentially this same thing. "Anti-Squat"
I had seen them before but I never knew where they go / mounted. Pretty cool.
Chad
Old 09-25-2012, 06:54 PM   #814
superflysteiny
superflysteiny's Avatar
I know I am not helping but I think you should lay her out. You and your dad will be the coolest cats in Daisy
superflysteiny is offline   Reply With Quote
Old 09-25-2012, 07:02 PM   #815
CC69Rat
CC69Rat's Avatar
Yeah, it's going down but I cant really do air. .. just as low as I can on a static and well built, well handling ls2 candidate..
Did I say that out loud?
The wheel is back in that Chicago sort facility and hasnt moved since 8 last night..If it comes back to Cali were going to need to just stop it, pick it up and maybe reship Fedex. I dont know whats going on in Chicago.
Chad
Old 09-25-2012, 08:31 PM   #816
gringoloco
A guy with a truck
gringoloco's Avatar
This mod will raise your truck ~3/4", in my experience.
Correct.
It subtracts 3" of the drop your pinion 'sees'. So, in your case it would be like a 3" coil drop worth of pinion angle change. I doubt you would need shims, but each truck is different.
Yes, but I only re-drilled the two closest to the pivot point, and used six 7/16" bolts per side for 12 total. I've also seen guys do 8 per side.
Did I read LS2?!
-Chris
Old 09-26-2012, 06:52 AM   #817
CC69Rat
CC69Rat's Avatar
Still no movement on the other wheel. Stuck in Hodgkis IL again, since 9/24.
The other one made it just fine. I dont understand it but if its not here by eob tomorrow, ..Im escalating with UPS. This is beyond ridiculous.
Chad
Old 09-26-2012, 12:08 PM   #818
superflysteiny
I am on it as I write this. I will have answer for you by the end of the day. I leave for vaction tomorrow but I pmed you my number and I will pm you my uncles lab number too. Thanks Eric
Old 09-26-2012, 07:47 PM   #819
CC69Rat
CC69Rat's Avatar
Eric -- it's in Nashville. Hopefully it's on schedule now, I think we're good.
Chad
Old 09-26-2012, 11:58 PM   #820
knomadd
knomadd's Avatar
I wish I had the extra funds right now to do all of that. I want to bag my truck so I can get it low and still tow once in a while but hell, I can't spend that much cash for a while. It will take me forever to save the money, but I'm not disciplined enough to save and not buy other stuff. Been trying to buy a 700r4 for my GTO but keep spending that money on truck parts or tools.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 09-27-2012, 08:24 AM   #821
CC69Rat
CC69Rat's Avatar
I really can't spend that much either, .. I just have an incredible wife and parents that helped me pull the coin together for the rear wheels. Had I needed to pay the actual price for these wheels I wouldn't have gone this route. Honestly to run a ~.25 spacer if I need to is worth it to me to save that much on my wheels. I have a bonus check in March (our Annual Performance Based Initiative at work) which should allow me to get the fronts. My truck will look kinda goofy through the winter but it will give me some time (on jack stands) to get the underside cleaned and detailed like I want it, run my hard lines for the rear discs, fix the exhaust.. it will need to go a little higher.. etc. It's just a winter time project for me a my pop. I have decided to go with the Porterbuilt stuff in the rear. Notch, shock bars, track bar, etc. I took the day off tomorrow and dad and I will begin knocking rivets out.. I'm going by tonight to pick up a step bit for the holes. Tomorrow is Dad's birthday. I thought we'd just hang out the whole day and work on the GMC.
I will come out gunning in the spring.. The GMC will be a 'semi-finished up' clean driver for local shows and I can get back on the stepper.
I have inherited a 2006 Acura RSX as my occasional daily, so I now have a garage spot too!
Chad
Old 09-27-2012, 08:46 AM   #822
CC69Rat
CC69Rat's Avatar
Oh, .. and the wheel is on the UPS truck for delivery today. Woohoo. I just hope it made it ok. Eric, I'll check it out and let you know. Thanks for your help.
Chad
Old 09-27-2012, 08:54 AM   #823
Rusbuilt
Rusbuilt's Avatar
Good deal!
Old 09-27-2012, 08:55 AM   #824
N2TRUX
Happy to be here
N2TRUX's Avatar
Have you thought about air for the rear? If you do manual bags in back you can add a hitch and tow a small trailer since you dont want to scratch up that pretty bed wood.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-27-2012, 09:57 AM   #825
CC69Rat
CC69Rat's Avatar
Ken, I may change to Schrader at some point .. I will probably bag the stepper. We'll see what happens I guess. I do haul a trailer but it's pretty rare I haul more than my bicycle.
In the pictures below, just making sure. The factory upper shock bar comes out, correct? Probably a stupid question. I have the upper bar that I'm 99% sure replaces this one. (Where the hammer is laying in the pics)
I just want to make sure, never done this before.
Chad
