Old 01-02-2016, 12:59 AM   #1
Coach529
Coach529's Avatar
Re: 1949 Chevy 3600 into a daily driver
Originally Posted by Advanced Design View Post
That is an interesting set up.....and for the price I may invest in one just to see how it would work with my 2500psi pressure washer.
Unfortunately I do not have the heated area to wash inside.......and the weather outside will not allow it until APRIL.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 01-02-2016, 11:32 PM   #2
Advanced Design
Advanced Design's Avatar
Nice fix on the notch Coach. I agree, outside in the snow is hard core...awesome!
Following along on the irs redo too.
Advanced Design is offline   Reply With Quote
Old 01-03-2016, 01:41 AM   #3
Coach529
Coach529's Avatar
30's in January is about as good as it gets up here in NoDak.
If it would have hit 40 I would have shut the heat off and opened up all the garage doors!!
1949 Chevy 3600
Old 01-03-2016, 11:29 PM   #4
Coach529
Coach529's Avatar
IRS install sneak peak.....
1949 Chevy 3600
Old 01-04-2016, 12:41 AM   #5
60chevyjim
60chevyjim's Avatar
rustoleum semi gloss works nice for chassis and under hood .. I buy it by the quart .
thin it with acetone to spray it or you can brush it on the chassis .
60chevyjim is offline   Reply With Quote
Old 01-04-2016, 04:27 AM   #6
lower50's
lower50's's Avatar
Nice work on the frame, IRS is going to be sweet!!
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-04-2016, 01:23 PM   #7
Coach529
Coach529's Avatar
Thanks I am so damn close to setting it down on the ground and checking ride height. Maybe tonight!!
1949 Chevy 3600
Old 01-05-2016, 12:39 AM   #8
BIGglaSS
BIGglaSS's Avatar
Nice. I was going to do a TBird IRS, until I scored a deal on two C4 IRS. Yours looks a lot easier.
BIGglaSS is offline   Reply With Quote
Old 01-07-2016, 10:15 PM   #9
Coach529
Coach529's Avatar
Found this picture on Instagram. I think Henry needs blue wheels.
What do you think?
1949 Chevy 3600
Old 01-07-2016, 11:41 PM   #10
99 to Life
99 to Life's Avatar
I could go either way, blue or black. I like a lot of white with blue trucks, so like a cream with wide whites or something light would look cool too. lotta options with your blue.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-07-2016, 11:42 PM   #11
Coach529
Coach529's Avatar
I always thought a cream would look good......but I was afraid it would blend into the wide whites too much......
1949 Chevy 3600
Old 01-07-2016, 11:50 PM   #12
99 to Life
99 to Life's Avatar
put a center cap on and a beauty rim, break it up a tad, or just go darker cream. either way I think it would look good.
Old 01-07-2016, 11:53 PM   #13
Coach529
Coach529's Avatar
I contacted Cragar about a beauty ring......they do not make one, but they say a thin one will fit. I need to round up a set.
1949 Chevy 3600
Old 01-07-2016, 11:59 PM   #14
99 to Life
99 to Life's Avatar
check ebay, prolly find a set for sure.
Old 01-10-2016, 10:05 PM   #15
Coach529
Coach529's Avatar
Not much forward progress lately.
The IRS is mocked up and tacked. I made some templates for a bigger notch and those are at the fab shop getting cut.
I spent about 6 hours in the car over the last couple days and most of it was spent thinking of where and how best to mount my compressors and air tanks. Spent a little time tonight mocking it up.
I plan on drilling some holes for my leader hoses to go through the cross member to the tank.
1949 Chevy 3600
Old 01-10-2016, 10:47 PM   #16
Advanced Design
Packaging components on a build sure takes time. Look, think and measure...too often I short myself on the think part.
Good looking components and location.
Old 01-10-2016, 10:51 PM   #17
Coach529
Coach529's Avatar
Thanks.
In my mind I figured I had enough room for a drop down battery box in the area as well. It did not work out once I start putting stuff in place.
Now I need to find a place for the Battery. UGGGHHH. :-)
1949 Chevy 3600
Old 01-10-2016, 10:48 PM   #18
99 to Life
99 to Life's Avatar
been there done that, takes longer than ya think moching stuff up. Ur gas tank still behind the seat I assume?
Old 01-10-2016, 11:03 PM   #19
Coach529
Coach529's Avatar
Yes it is.
1949 Chevy 3600
Old 01-10-2016, 11:03 PM   #20
99 to Life
99 to Life's Avatar
so you're talking about battery out in the back? it won't fit between the compressors? How far down would you be able to mount below your frame?
Old 01-10-2016, 11:05 PM   #21
Coach529
Coach529's Avatar
I was actually hoping to build a box for the battery between the IRS and the air tank but there is not enough room.
It might fit between the compressors, but I had that space reserved for a couple holes for the leader hoses to go to the tank.
1949 Chevy 3600
Old 01-10-2016, 11:26 PM   #22
99 to Life
99 to Life's Avatar
well reason I ask on your below frame location is.... if you mount below frame line, then perhaps you can play with mounting comps upright and getting a different angle on your lines. (I'm just a stickler for upright mounting on comps even though side mount still works). I'm seeing a couple ideas but without knowing sizes of things by the pics, its hard to say if it would work.
1.what if the comps where butt up to each other, heads facing one another and the hoses run through frame in the center, then to the space that is now left (where old compressor location was) you can mount a battery there.
2. any benefit to swapping air tank location with comps? if that area is bigger maybe the battery can go there too.
3. more work than necessary maybe, but... you can move the xmember back and have more room, seems to be about 6" from back of frame to comps, is that possible to utilize that space?
4. easy way out, can leader hoses go under that xmember if you had battery in middle?
Old 01-10-2016, 11:47 PM   #23
Coach529
Coach529's Avatar
Now you got me thinking.
I headed back out to the shop. Damn it is cold here. -10 right now. OK so if mount the compressors upright and side by side I would have room for a custom battery box as well a small mount for a box to hold compressor relays and main power fuse.
I did not have enough hands to hold both compressors and take a pic.
I have to do some research to see how much room I have on the top of the frame before I hit the bottom of the box.
1949 Chevy 3600
Old 01-11-2016, 12:18 AM   #24
99 to Life
99 to Life's Avatar
yes that seems like it would be good right there. I was thinking that same set up, but bf the xmember. wasn't sure if you had the length or not, but that is cool there. If I can recall, with the 53 and earlier beds, they have a wood block on some of the mounting points and some xmembers, so isn't the bedwood atleast that high off the frame, like about 2"? you could also easily make a drop mount for your compressor to mount off your frame and drop the comp down about an inch or whatever you need.
Old 01-11-2016, 10:31 AM   #25
Coach529
Coach529's Avatar
I am going to look at it some more tonight. Not 100% sold on any of the ideas yet.
My main concern is I do not want to be able to see the stuff once the bed is on from the back.
I plan on running a rear bumper, so that will help.
1949 Chevy 3600
