Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 08-07-2017, 09:52 AM   #801
7dee2
7dee2's Avatar
Re: My 78 K15 High Sierra build - Fish Tremble
Nice!
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 08-13-2017, 08:36 PM   #802
rgunlock
rgunlock's Avatar
Got a few things finished up, but it was over 105 heat index all weekend which kicked my butt before I got everything done I wanted to.
Repaint GMC on tailgate band - done.
Finish up "restore" of GMC grille - done.
Mount new map pockets on door panels - done. Jury is still out whether I like the color but the wife does so I guess they stay.
Found and fixed AC drip from evaporator unit - done.
Started trying to chase down various issues with my guage cluster. Speedo isn't working, but after pulling the cluster I drove several feet holding the end of the cable - doesn't move so I guess a problem at the xfer case end. Voltmeter isn't working when in the cluster, but bench tests ok. Same for the clock - it isn't getting any power. Doesn't look like any of the bulbs in the cluster are working. Tested a couple bulbs ok. Any case, I'm trying to figure out how to test the circuit sheet but heat did me in before I got far.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 08-13-2017, 09:35 PM   #803
TKCR
TKCR's Avatar
Everything looks great!! Too bad the map pockets aren't the same color as the armrest, that would look way better. I could never get map pockets to match in my truck, so I just don't have any.
Old 08-13-2017, 09:47 PM   #804
Greenlee
Greenlee's Avatar
That's a beautiful truck!
Greenlee is offline   Reply With Quote
Old 08-14-2017, 12:01 AM   #805
boynton
boynton's Avatar
I agree with matching the map pockets to the armrest. The best way to test the circuit board is to use a test light. You can visually follow the circuit as you go. Just locate the ground and the other side will obviously be the hot. You should be able to look at the plug that goes into the circuit board and find the black wire that is your ground and start there. I'm sure it is something basic-loose ground bad fuse etc. you can easily see a bad circuit board as they generally melt and turn black where they are bad. You are almost there! It looks great.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 08-14-2017, 07:42 AM   #806
rgunlock
rgunlock's Avatar
I think that you are right TKCR. It would be easiest to dye the armrest but I like its color better than the pockets.
Thanks Greenlee! Once I get the cluster worked out, its off to get it inspected and plates and start road testing it.
I did find one spot where the circuit sheet wraps over the edge of the cluster housing to pick up a bulb that is delaminated and looks suspect. I'll get it figured out.
Rick
Old 08-18-2017, 10:24 AM   #807
7dee2
7dee2's Avatar
Road Testing, YES!
Brett
Old 08-20-2017, 06:23 PM   #808
rgunlock
rgunlock's Avatar
Chasing gremlins in the wiring this weekend. Wasn't getting any light in the guage cluster, voltmeter wasn't working, speedo not working, etc.
Pulled the cluster back out of the dash and checked all the circuits for continuity. Made up a nice cheat sheet while I was at it. Circuits were all intact, but I do worry about that cheezy wiring connection. All those little copper leads are just kind of blowin' in the wind.
While I had it apart, I'd read about some upgrades on this site. Painted the housing chrome and used the #168 bulbs (all new) rather than the #194. Since I had no light before, its tough to judge improvement but it seems to me that it will be bright enough now.
Had blown fuse which I think explains the voltmeter not working. I am a little concerned because I think I've already replaced that fuse a couple times (not keeping close enough track of it over time). Hopefully, not a problem in my wiring but I'll keep an eye on it. Bench tested my clock and it worked. After replacing the clock fuse I had power at the connector to the clock. Plug the connector into the clock for cluster reassembly and no clock - dang
Chased down the issue on the speedo. Pretty sure it is an adapter at the NP205 end that's broke. I doubt that adapter was correct for the 33's I put on so likely need to replace it anyway. Just having a little trouble figuring out what I need to get for 350, SM465, NP205, 3.07 gearing and 33 Inch tires. Removed the adapter and connected the speedo cable directly to the NP205. Wife and I drove it down the road and filled a tank at the station. Speedo at least work, and now I've got a couple miles on the odometer
Next up figure out why the windshield washer isn't working. Wipers themselves work. There are only 2 wires to the washer pump, white and dark blue. White is hot with the key on. I believe that the blue should be ground when the button is pushed on the switch. Tested that at the washer connector end and no continuity to ground when the button was pushed by my lovely assistant. So, maybe I've already killed the new switch messing around with my wiring. Figured what could I lose. Hooked a lead on the pump itself to ground and tried applying 12V to the other lead - nothing from the pump. I'd assume I'd at least hear something. So, maybe a bad pump also.
Trip to the gas station a mile or so down the road was at least uneventful. Steering is going to take some getting used to. I haven't got the front end aligned other than with a tape measure when I reassembled the front end. I don't know that the truck is trying to wander as much as that the steering is VERY sensitive to any movement of the steering wheel. Don't really like it the way it is, but not sure what to do about it and won't do anything until I get the front end aligned. Other than that, the only thing I noticed was noise from the rear of the truck. I'm thinking that the drum has likely got surface rust and the shoes on at least one side are rubbing a bit. Don't think that will be a biggie. Maybe just do the reverse/brake/reverse/brake deal to see if they'll self adjust like they are supposed to.
Rick
Old 08-20-2017, 06:49 PM   #809
MTCK
MTCK's Avatar
Getting soooooo close! Hope the gremlins stop interfering with the electrical side. How did the truck drive with that combo of gears and tires? My '77 had 32's and 3.07 gears when I bought it. 4.10 gears made it a different truck.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 08-20-2017, 07:11 PM   #810
rgunlock
rgunlock's Avatar
Still not sure on how it will drive with the 3.07 gears. The only road I've been on has a 35MPH speed limit. Seems to accelerate ok but would really like to get it to highway speeds. Hope to get inspected and plates on it soon so I can take it out. If it doesn't work out, I have some axles ready to go with brand new 4.10 gears, limited slip diffs and a NV4500 for that matter. Had them built for the Apache project, but who knows I may go a whole different direction on that one.
It does feel like it is sooooo close! Honestly though, as much as I want to finish and be driving it, another part of me doesn't want it to be done. It's been my go-to weekend activity for 6 years now. I know I have other projects lined up to keep me busy, and the '59 to build, but somehow it just doesn't feel the same. Am I just nuts???
Rick
Old 08-21-2017, 12:24 AM   #811
bilfman
bilfman's Avatar
This, for ALL it's ups and downs and learning curves has been my favourite build on this site ever. A real man taking the steps to build a real truck and learning as he goes. It don't get more real or better than that. I love checking in. Thank you for sharing. I'll be sad when it's over 😉
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 08-21-2017, 07:31 AM   #812
rgunlock
rgunlock's Avatar
Wow - thanks! It is so nice to hear this!
Rick
Old 08-21-2017, 09:06 AM   #813
7dee2
7dee2's Avatar
I don't think so, old habits are just hard to change. Congrats on getting that much closer!
Brett
Old 08-21-2017, 12:59 PM   #814
rgunlock
rgunlock's Avatar
Thanks Brett! Of all my old habits, this is the one I LEAST need to change
Rick
Old 08-28-2017, 02:12 PM   #815
TKCR
TKCR's Avatar
Hope you and your family are safe and doing well. I'm thinking about all of you down there in the path of that storm. Stay safe and gives us an update when you can.
Old 08-28-2017, 02:59 PM   #816
rgunlock
rgunlock's Avatar
Thanks for checking in TCKR. I've poured 31 inches from my rain gauge since Friday evening but we're still dry and have power. Can't get out, but we're stocked up and doing fine.
Rick
Old 08-28-2017, 03:17 PM   #817
TKCR
TKCR's Avatar
Thanks Rick for the update, glad to hear you safe and sound, and not to mention dry.
TK
Old 08-29-2017, 09:38 PM   #818
boynton
boynton's Avatar
TK
I agree. If y'all need anything I can be there somehow shortly!
1970 SWB Step-Side
Old 08-29-2017, 11:35 PM   #819
swamp rat
swamp rat's Avatar
Glad to hear your not in the flooded end of the state!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-29-2017, 11:43 PM   #820
Greenlee
Greenlee's Avatar
I hope you are still high and dry! My family and friends on your side of town were worried about us. Now it seems like you guys are getting it just as bad. My parents live on Clear Creek in Friendswood. They haven't got any water in the house, but have been trapped there for days.
Old 08-30-2017, 08:21 AM   #821
rgunlock
rgunlock's Avatar
Thank you all for checking in. We stayed high and dry through this and I believe "knock on wood" that the worse is over for us. Looks like the storm has passed and the water around us is receding rather than rising.
Rick
Old 08-30-2017, 09:36 AM   #822
7dee2
7dee2's Avatar
Really glad to hear you guys are OK, hopefully life will get back to normal soon.
Brett
Old 09-01-2017, 09:15 PM   #823
rgunlock
rgunlock's Avatar
Thing about constant rain is you get bored. Went ahead and wire-wheeled cleaned up the bench seat frame I got from TKCR when I went through Ohio on my summer road trip. This will appear to be a re-run, but I assure you that a LOT of work was involved in this! Now I have the deluxe seat with full foam and a fold-down back for the ultimate in luxury
Rick
Old 09-01-2017, 10:21 PM   #824
TKCR
TKCR's Avatar
Looks
Awesome!!
Old 09-04-2017, 10:29 AM   #825
7dee2
7dee2's Avatar
Beauty, the interior looks great Rick!
Brett
