Old 01-06-2017, 01:32 PM   #801
izzy_Britton
izzy_Britton's Avatar
Re: Loadmaster '47 COE
Having a steel flat bed may allow you to weld fixtures to it for such things, then cut them off, bring the weld, and repaint.
But maybe installing some 2 inch trailer hitch type receivers strategically located would allow for different fixtures to be used without the need to cut them off, grind, and repaint...
I have my trailer hitch set up so that the usual receiver gets the tow ball, but either side of the hitch frame can also attach tow balls, for storage of different size/type.
-Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 01-06-2017, 01:45 PM   #802
47 Fasttoys
47 Fasttoys's Avatar
Making a little progress on the frame. I have the 2 main arks bent and now working on adding the studs. I cant seem to find the windows or doors I'm happy with, may make my own. I will be cutting the bottom 2 inches off the frame as is mounted to the main floor frame.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 01-07-2017, 04:08 AM   #803
Nut Case
Nut Case's Avatar
Loadmaster
What you are doing is such a treat, I looks great, I'll be following along smiling the hole way..
Keep on keepin on
NC
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 01-08-2017, 09:00 PM   #804
47 Fasttoys
More progress on the Blue Turtle.
Rob
My '47 C.O.E build
Old 01-08-2017, 10:24 PM   #805
Advanced Design
Advanced Design's Avatar
Nice. Is the short arc the top of the door?
Advanced Design is offline   Reply With Quote
Old 01-09-2017, 01:16 PM   #806
lower50's
lower50's's Avatar
LOL "blue turtle" is looking great.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-09-2017, 10:12 PM   #807
Bad Apache
Bad Apache's Avatar
Better than Mud Turtle, lol. Love the ingenuity as always! Great work!
1958 Apache 454ci 4 speed
Bad Apache is offline   Reply With Quote
Old 01-09-2017, 11:14 PM   #808
47 Fasttoys
Yes, the ark is for the door. Picked up some more steel today so I can continue. It looks like a lot of supports but keep in mind you are looking at 2 walls.
Rob
My '47 C.O.E build
Old 01-10-2017, 08:33 AM   #809
lower50's
lower50's's Avatar
Do you have an idea on how much it will weigh?
1951 MG TD
Old 01-10-2017, 05:45 PM   #810
47 Fasttoys
Weight? nope no idea. If I had to guess maybe 900-1300 pounds. I'm really more concerned about the aerodynamic effect going down the highway. A lot of unknowns in this project. I've had a few heavy loads on the truck, 1000-1500#, and dragged a few trailers with no issues but never something with this large of a wind foot print. Then again, I never built a COE until this one either.
I aint no afraid....hey y'all, watch this. LOL, famous last words.
I got this idea: because the top is shaped somewhat like an airplane wing and should provide lift, when I hit about 80MPH the rear of the truck should lift the tires off the ground thereby reducing friction between the road and tire which should in-turn increase gas mileage by maybe 50 %. Now if I could just find one of those turbo things for the intake pipe I should be looking in the range of 83 to 85 MPG....Right?
Might be time to get to work.
Rob
My '47 C.O.E build
Old 01-10-2017, 06:27 PM   #811
crestronwizard
Talking Re: Loadmaster '47 COE
Rob
80mph will be fine..........it's 88mph that you have to watch out for!
crestronwizard is offline   Reply With Quote
Old 01-11-2017, 09:18 AM   #812
lower50's
lower50's's Avatar
Your thinking sounds right to me
1951 MG TD
Old 01-12-2017, 10:36 PM   #813
47 Fasttoys
Measure, cut, weld....repeat.
Rob
My '47 C.O.E build
Old 01-13-2017, 12:42 PM   #814
99 to Life
99 to Life's Avatar
you are pretty handy with that roller. great artistry
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-13-2017, 02:20 PM   #815
MARTINSR
MARTINSR's Avatar
Yes. cool stuff!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 01-13-2017, 03:35 PM   #816
flashed
That is going to look great .
flashed is offline   Reply With Quote
Old 01-13-2017, 05:02 PM   #817
joedoh
joedoh's Avatar
puts me in mind of graceland, if you quit now you could use them as arty driveway gates! :P
looking good!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 01-13-2017, 06:53 PM   #818
Advanced Design
Arcs and circles. That framework is impressive!
Old 01-13-2017, 07:45 PM   #819
47 Fasttoys
Thank you all, I really wanted to follow an old style theme on this thing. Round window are one of those things you just can't seem to find these days. The new T@G have them but only in the door, everything else is all plastic. I still need to figure out the tilt open system and screens but I have some ideas. Using the roller isn't so bad, you just have to learn to creep up on your desired radius.
Rob
My '47 C.O.E build
Old 01-19-2017, 07:00 PM   #820
47 Fasttoys
A little more progress. I wanted to weld the walls on while the base was on the truck just in case the flat bed has any twist in it. I will also do the floor and wall sheeting this same way. Now getting it back off the truck at this point is gonna be a pain. Anybody got any used truck camper jacks they wanna sell? I need some with a 30 inch range.
Rob
My '47 C.O.E build
Old 01-19-2017, 07:12 PM   #821
flashed
That is going to look so Kool.
Old 01-19-2017, 08:09 PM   #822
99 to Life
99 to Life's Avatar
that thing is going to be crazy!
Old 01-19-2017, 11:24 PM   #823
Bad Apache
Bad Apache's Avatar
Proportions look right on! I'm digging it!
Old 01-20-2017, 12:03 PM   #824
kampfitt
Love It !!
kampfitt is offline   Reply With Quote
Old 01-20-2017, 06:04 PM   #825
WDriller
That is absolutely awesome! I'm curious how you're going to match/compliment the patina of the truck.
WDriller is offline   Reply With Quote
