Old 11-18-2018, 11:40 AM   #801
RockinKees
RockinKees's Avatar
Re: "Project Orangepeel" 52 A.D
Oh Yes you do!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 11-19-2018, 02:46 PM   #802
lower50's
lower50's's Avatar
That is all coming together very nice.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 11-19-2018, 06:34 PM   #803
reaper71
reaper71's Avatar
Thanks Lower
reaper71 is offline   Reply With Quote
Old 11-24-2018, 09:03 PM   #804
reaper71
reaper71's Avatar
Update:
Hey Guys I had to switch gears a bit (need parts to finish up my radiator splash pan) so I will be moving on to my gas filler idea.
The plan is to install it into the stake pocket.
Pic 1. Here is after I made my cuts into the inside of the bed.
I mocked up the filler as well. So I cutout all of the rear panel (tube will run through here) I'll be using 1 3/4 o.d tube and will all be welded and have 1 rubber connection between the tube and tank.
Pic 2. Close up of filler (popup style)
Pic 3. Here I was figuring out the angle for the 1st tube.
Pic 4. the 1st tube welded up, this will then be welded to the next extension.
I forgot to mention, This will All be removable
Mark
Old 11-24-2018, 10:49 PM   #805
mongocanfly
Post Whore
mongocanfly's Avatar
That's nice Mark...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-24-2018, 11:14 PM   #806
Advanced Design
Advanced Design's Avatar
Holy wow! What a great idea! Never seen that one done before.
Advanced Design is offline   Reply With Quote
Old 11-24-2018, 11:17 PM   #807
OutlawDrifter
Looks good! Cool idea!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 11-25-2018, 06:05 AM   #808
RockinKees
RockinKees's Avatar
Really nice Mark!
I did see a few, but in the stakepockets of a ‘58-‘59 Fleetside. On pics that is, not here in the Netherlands....
This is a different approach!
Cheers!! Kees.
Kool Guyz CC
Old 11-25-2018, 09:35 AM   #809
reaper71
reaper71's Avatar
Thanks Greg
Old 11-25-2018, 09:36 AM   #810
reaper71
reaper71's Avatar
Thank you Doug!
Old 11-25-2018, 09:36 AM   #811
reaper71
reaper71's Avatar
Thanks outlaw!
Old 11-25-2018, 09:38 AM   #812
reaper71
reaper71's Avatar
Kees, It's was harder/and more work than I thought it would be. But in the end it will pay off I think.
Mark
Old 11-26-2018, 06:52 PM   #813
lower50's
lower50's's Avatar
That is an amazing idea! It should really make some people take a second look when you are at the gas pump.
1951 MG TD
Old 11-26-2018, 07:07 PM   #814
reaper71
reaper71's Avatar
Thanks Lower!
Dare to be different right?
Old 11-26-2018, 07:21 PM   #815
reaper71
reaper71's Avatar
Pic 1. This is the tube I'll start with 1 3/4" o.d from speedway $14.
Pic 2. The 90 is welded in.
Pic 3. Now the U bend can be cut off and clocked to make the next turn.I also was mocking up the placement of the neck going into the tank.
Pic 4. This is the rubber tube (fuel safe) from filler neck supply (lots of great stuff)
Pic 5. So after drilling,vacuum,welding etc. here is the hookup to the tank.
Mark
Old 11-26-2018, 07:26 PM   #816
8man
Very custom and also cool! Nice plan.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 11-26-2018, 10:07 PM   #817
OutlawDrifter
Looks great! Any plans for a vent line? With the two extreme curves, it might have burping issues.
1991 Z/28, 6.0L/T56
Old 11-26-2018, 11:02 PM   #818
Scott2
Great idea and nice execution!
Scott
______________
my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979
Scott2 is offline   Reply With Quote
Old 11-27-2018, 08:52 AM   #819
reaper71
reaper71's Avatar
Thank's Everyone!
Outlaw...I have thought of that, Not sure how I'll do it yet (limited space)Nor do I know where to place it.
Any Ideas?
Mark
Old 11-27-2018, 12:13 PM   #820
RockinKees
RockinKees's Avatar
Looks good Mark!
I made my vent line just besides the fillertube.
Maybe this is an idea if you have the space.
Cheers!! Kees.
Kool Guyz CC
Old 11-27-2018, 02:24 PM   #821
OutlawDrifter
Can you put a smaller 3/8" or 1/2" line above the fill hole, then snake a rubber hose along the top/upper side of your 1 3/4" fill line?
Just terminate it in the top of the fill line below the bed rail level with a 90?
1991 Z/28, 6.0L/T56
Old 11-27-2018, 08:52 PM   #822
reaper71
reaper71's Avatar
Unfortunately I dont have that kind of room, The 1 3/4 tube just fits.
Old 11-27-2018, 09:58 PM   #823
edgeleycanuck
Maybe filling a bit slower would be a solution if need be. And just a thought, could you put a small tube inside the fill tube and have it fastened/welded near the edge of the filler opening? Like the fill spouts on a 5 gal gas jug.
edgeleycanuck is offline   Reply With Quote
Old 11-28-2018, 08:45 AM   #824
reaper71
reaper71's Avatar
That might be an Idea!
Old 11-28-2018, 08:58 AM   #825
reaper71
reaper71's Avatar
Pic 1. I ended up redoing the entire back section.
It was all rotted on the topside,so I made the passenger side solid(or welded in) and the Drivers side is a cover that can be removed.
Pic 2. There is 3 bolts holding it in place, 1 on top 2 on the sides.
Pic 3. I made a filler/cover panel and this was filed and refit several times.
Pic 4. Here I put a small piece in to help locate the filler panel.
Mark
