12-02-2015, 07:22 AM | #826 |
Six in a row makes it go...
Re: Tricked-out Chevy six cylinder engines
Sorry - nothing tricked out on the latest one. Just got my stocker-type rebuild on my '67 292 back from the engine shop.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
12-02-2015, 11:12 AM | #827 |
Post Whore
Looks good!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
12-07-2015, 07:32 PM | #828 |
Mine, freshly painted....
If you don't like this pound sand ..... |
12-14-2015, 05:28 PM | #829 |
have some older pictures on page 28 of my 235. Thought i would post some more current ones up from this season.
My updated list: 235 over .040 848 head Water heated dual Edelbrock Intake Fenton Headers Dual Weber carbs HEI Ignition Custom PCV system Drilled crank snout for dampener bolt Custom made Power Steering / Alt bracket system Mechanical Fuel pump with pressure regulator Shortened water pump Flex Fan Spin on bypass oil filer setup Delta Cams 251 grind mechanical cam New push rods and lifters
52 Chev 1300,55 235 40 over, 848 head, dual Edelbrock intake, Fenton headers, CW 32/32 carbs, 251 cam, HEI, T5 Trans, 3.23 rear, 235/75/r15 rubber. If it aint broke I still try to fix it! Last edited by wolffcub; 12-14-2015 at 05:48 PM. |
12-14-2015, 05:54 PM | #830 |
12-14-2015, 07:29 PM | #831 |
Post Whore
Bet that 235 runs good! Looks nice.
12-14-2015, 08:26 PM | #832 |
Wolffcub, thats a great looking engine!
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
12-15-2015, 12:44 AM | #833 |
Thanks. It running much better than before. That cam was sure a nice upgrade.
52 Chev 1300,55 235 40 over, 848 head, dual Edelbrock intake, Fenton headers, CW 32/32 carbs, 251 cam, HEI, T5 Trans, 3.23 rear, 235/75/r15 rubber. If it aint broke I still try to fix it! |
12-27-2015, 10:39 PM | #834 |
Engine mostly done:
12-27-2015, 11:30 PM | #835 |
Post Whore
02-11-2016, 10:02 AM | #836 |
Ran across this one the other day. Ad says its a 250 with 6 water injected carbs...never heard of that, but sounds cool!
https://hiltonhead.craigslist.org/cto/5406982345.html |
02-11-2016, 11:17 AM | #837 | |
Post Whore
04-28-2016, 12:25 AM | #838 |
Post Whore
How's things going fellow Inliner's? Not much going on with mine, gonna order more engine parts next check though, and am in the process of restoring the truck. Really eager to hear this puppy run!
07-10-2016, 10:22 PM | #839 |
I just did a "spray can rebuild" on the 250 in my '66 shortbed. All stock except for the HEI. I do have a Offy/Holley 390 combo on the shelf to go on in the near future.
07-10-2016, 11:49 PM | #840 |
Post Whore
Very nice!
07-11-2016, 01:39 AM | #841 |
Mike, will you be running headers?
07-11-2016, 08:43 AM | #842 |
I was planning on the Langdon headers, or possibly one of the 2.5" outlet 292 manifolds. I'm going to run the offy with the stock exhaust though for a while due to budget constraints. Both the 1bbls I have around are weepy, warped, throttle shaft leaking crap, and I don't want to spend the coin on another.
07-11-2016, 04:14 PM | #843 |
I bought my Clifford Research long tube headers back in '78, when they were under $90 bucks. Can't get 'em for that now. Mine have lasted thru 2 engines, but I've had them re-flanged to 3/8" and -- after #5 tube got bashed in off-roading -- that tube was resectioned. They ran 25 years on a 1977 build and then were hot tanked and bead-blasted for a 2005 rebuild. Don't know what I'd run now, if I had to build up another 292, but Clifford's are not in the budget anymore.
07-11-2016, 04:31 PM | #844 |
Post Whore
Got my Clifford headers for $349 some 4 years ago. lol
08-13-2016, 04:19 PM | #845 |
Hi i just got my trucks home. I got 2 1966 gmc 1/2tons. Ones a parts truck with a 283 and the other is my good one with a 6 banger. Reading this thread got me thinking maybe keeping the 6 banger and fixing it up like these tricked out ones on this thread. Question i have is what kind of output or horsepower can be had with doing these 6 cylinders right?
08-13-2016, 04:33 PM | #846 |
Question i have is what kind of output or horsepower can be had with doing these 6 cylinders right?[/QUOTE]
The question we will have is..............How much money do you want to spend. Unless your towing something, I never understood why people worry about how much power an engine makes. Now having said that, I blew through 7K real fast and got nearly 300HP out of my 292. |
08-13-2016, 07:12 PM | #847 | |
Post Whore
230: Flat top pistons. 4 inch side covers. 250: Dished pistons. 4 inch side covers. 292: 6 inch side covers and fuel pump in the center.
08-15-2016, 01:06 PM | #848 |
I'd keep the six man. Something different, easiest IMO to work on and you can bolt on some upgrades before you get into the real performance stuff.
Wanda - 1969 C/10 LWB 250 I6 3OTT LWB>SWB |
11-03-2016, 04:28 PM | #849 |
Ok guys i thought I would post some ear candy over hear for the ones who are not following my 46 build thread. This is the first start up since dyno day of my 292. This motor was built by Larry's Power in Groton Ct., the same shop that did Leo Santucci's spliced head 292. Enjoy!
https://www.youtube.com/watch?v=auaDSwCWdCk |
11-03-2016, 09:52 PM | #850 |
So I finally got the Offy/Holley 390 combo up and running a few weeks ago. I used a cable throttle assembly from an '88-up Chevy truck. After some carb repair and tuning, it runs pretty well, and gets around the same mileage that I was getting with the original setup, 14-15 MPG. That's with the stock 3 speed, 3.73 rear, and 28" tall tires. There is a noticeable power increase as well. I'm running it with a stock exhaust manifold for now, but Langdon headers are what I have planned for the future.
