Old 11-19-2011, 10:19 PM   #826
bharrison1
bharrison1's Avatar
Re: my 80 build
Cool!!Rallies always look good!!
bharrison1 is offline   Reply With Quote
Old 11-20-2011, 01:05 AM   #827
3r!c84
Badass
3r!c84's Avatar
Re: my 80 build
Get 15x10 rallies ! For the rear
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-20-2011, 11:53 AM   #828
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
these are just temporary till I can afford 17s or 18s
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 11-27-2011, 10:22 PM   #829
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 11-28-2011, 11:04 PM   #830
baclay9
Re: my 80 build
I had a question about the lizard skin. How much does it take to do the inside of the cab. I am going to do the floorboard, inner firewall, beneath headliner and basically everywhere you cant see on the inside.
Based off what you did how much do you think I will need? I was thinking 2 gallons of the sound insulator and 2 gallons of the heat insulator.
baclay9 is offline   Reply With Quote
Old 11-29-2011, 10:48 PM   #831
flamingbig10
6.0 powered square
Re: my 80 build
you'll have more than enough with the 2 gallons each
Aaron
Old 11-29-2011, 10:49 PM   #832
flamingbig10
6.0 powered square
Re: my 80 build
I'm having the drive shaft made all new every thing for 230
Aaron
Old 12-02-2011, 01:12 AM   #833
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 12-03-2011, 06:59 PM   #834
harnalien
TruckincrazY
harnalien's Avatar
Re: my 80 build
Who did your driveshaft for you?
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 12-03-2011, 10:43 PM   #835
flamingbig10
6.0 powered square
Re: my 80 build
http://stanhopkinscompany.com/ they did the drive shaft for 175 that includes a 4l80e slip yoke, 2 1350 solid u joints, and balance, they also built the 12 bolt for 230
Aaron
Old 12-03-2011, 10:46 PM   #836
flamingbig10
6.0 powered square
Re: my 80 build
Today I put a vacuum bleeder on all 4 calipers, I was able to get a lot of air, tomorrow I'll do a manual bleed, I also set the seat back in the truck so I can mock up the accelerator pedal
Aaron
Old 12-11-2011, 12:27 AM   #837
flamingbig10
6.0 powered square
Re: my 80 build
got the brake bleed, diff full of 80 90 gear oil with limited slip additive, a polished indicator panel, and this
Aaron
Old 12-11-2011, 09:31 PM   #838
yellowGT
yellowGT's Avatar
Re: my 80 build
Aaron Ill sell you my TT2s. Or trade me the cragars for mine.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 12-12-2011, 01:10 AM   #839
flamingbig10
6.0 powered square
Re: my 80 build
what size
Aaron
Old 12-12-2011, 01:23 AM   #840
yellowGT
yellowGT's Avatar
Re: my 80 build
20x8 backspaced for the front. I only have two though meaning you would have to buy the rear ones with your needed backspace.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 12-12-2011, 02:02 AM   #841
yellowGT
yellowGT's Avatar
Re: my 80 build
woah! I could just sell them to you. I thought about trading them for your cragars but they wont fit my chevelle...dont know what I was thinking.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 12-15-2011, 12:47 PM   #842
flamingbig10
6.0 powered square
Re: my 80 build
thanks for the offer but the money is a little tight right now. The inner fenders and radiator support is at the body shop, all the unneaded holes are welded up, and mud has been spread, the bottom of the inner fenders will be getting rhino lined
Aaron
Old 12-15-2011, 07:39 PM   #843
harnalien
TruckincrazY
harnalien's Avatar
Re: my 80 build
Thanks. I'll keep them in mind. I'm thinking of going TH400 in mine because I just can't crunch the numbers enough to make the 4l80 affordable. This isn't a DD, so I can't justify the cost to the "boss."
Old 12-19-2011, 11:11 PM   #844
flamingbig10
6.0 powered square
Re: my 80 build
no problem, I got the pedal welded and installed and drove it down the street left two 5 foot black mark with a little throttle, but its not running all that great just yet I did fiqure out I had the wrong o2s pluged in backword installed the correct ones now it backfires alittle
Aaron
Old 12-20-2011, 12:05 AM   #845
bark
Re: my 80 build
hey where did you get the disc/disc valve from? how much
no problem, the captain fab rear disc brake brackets, wilwood d-52 calipers, and disc/disc proportional valve are all on th way
bark is offline   Reply With Quote
Old 12-31-2011, 12:26 AM   #846
bowtiemanchevyman
bowtiemanchevyman's Avatar
Re: my 80 build
i was reading your post and i was woundering what happen with your dash. after a couple of reply u stoped i was wounder how you did it and if u have pic of what u did.
i love your truck i would run a holley or demon better performace and gas mileage i run a demon and it much better then a edelbrock
bowtiemanchevyman is offline   Reply With Quote
Old 12-31-2011, 12:32 AM   #847
flamingbig10
6.0 powered square
Re: my 80 build
thanks, I haven't messed with dash since I posted the pics, the 350 is long gone has 6.0 in it now
Aaron
Old 12-31-2011, 08:39 PM   #848
flamingbig10
6.0 powered square
Re: my 80 build
Thursday I installed a new crank sensor and was going to do a crank relearn but it wouldn't allow me since there isn't a signal to computer for the brake pedal or park brake. Today I started up the truck today it stopped popping through the exhaust and it idled a lot better, drove It down the street did at 20 foot rolling burnout had to let off it was starting to go sideways
Aaron
Old 12-31-2011, 09:06 PM   #849
mooseknuckles
mooseknuckles's Avatar
Re: my 80 build
lookin good man!
mooseknuckles is offline   Reply With Quote
Old 12-31-2011, 10:36 PM   #850
CoggedBelt75
CoggedBelt75's Avatar
Re: my 80 build
Good to see you hanging in there Aaron and trying to get the efi working right instead of just slapping a different intake and a carb on it. If you're doing this yourself I know the frustrations you are going thru. Even tho I can access my ecu from my laptop and been playing with it for 4 years, it's still all Greek to me. How about another vid when you get a few more bugs out of it?
Joe
__________________________________________
1975 C10
"Questions are a sign of intelligence indicating a desire to eliminate ignorance"
CoggedBelt75 is offline   Reply With Quote
