03-09-2013, 04:09 PM | #826 | |
Re: 68 S/C update.....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-09-2013, 04:12 PM | #827 |
??? the bracket kits are the same for all 5 water pumps or the 3 different offsets. there are a 1,2,or3 spacer kits depending on your set up. i would call there tech dept. they were super helpful when i called.
website https://www.villagegarage.com/ truck guy in the whiskey world https://www.instagram.com/c10glen/?hl=en https://www.hemmings.com/stories/car...e-perfect-day/ |
03-12-2013, 10:30 PM | #828 |
Still pulling parts off and cleaning stuff up!! I pulled the inner and outer heater box off today. I found some nice shiny gold paint underneath. I wish I could figure out a way to get the spray on black paint off without messing up the gold paint underneath. I tried some acetone, but that didn't work to well. If I can't figure it out, I'll just shoot some more black semi-gloss on it. I also mounted the new Dakota digital gauges. I think they are going to fit right in with the mostly stock interior.....
03-12-2013, 10:34 PM | #829 |
A day late and $1 short...
Looking good brother... diggin' the gauges!
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
03-12-2013, 11:34 PM | #830 |
Man of Mini-Talents
The gauges look great! How does the speedo hook up?
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
03-13-2013, 08:37 AM | #831 |
Thanks Ernie. I'm taking my time and doing a lot of planning so hopefully it will go back together as nice as it was before I tore it apart....
Thanks. It connects to an output wire out of the computer.
03-13-2013, 08:43 AM | #832 |
Did you try laquer thinner on the firewall? I've had luck removing unwanted paint myself with it.
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! |
03-13-2013, 09:28 AM | #833 |
Do you think it will hurt the original paint underneath?
03-13-2013, 09:46 AM | #834 |
It might. but you could just shoot black over it if it does.
03-13-2013, 09:47 PM | #835 |
It probably won't, the original finish is really hard but keep in mind it probably wasn't exactly cherry when the PO "improved" it. Just wet a rag and let it do the work, it will come off if it's just rattle can.
Please remember to wear gloves!
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
03-27-2013, 10:29 PM | #836 |
Out with the "old" and in with the new!!!
03-27-2013, 10:59 PM | #837 |
Man of Mini-Talents
Very nice, but why?!?
Obviously for adjustment, but what problem did you have that made this necessary? Just curious.
03-27-2013, 11:11 PM | #838 |
is the "old" up for grabs?
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
03-27-2013, 11:22 PM | #839 | |
03-27-2013, 11:23 PM | #840 |
yes it will.
03-28-2013, 08:54 AM | #841 | |
I sold it about 4 months ago and the new owner has been patiently waiting for me to pull it..... I played around with it and I'm pretty sure I'm just going to reshoot in in semi-gloss black, .
03-28-2013, 10:38 AM | #842 |
Looking good Rob!
-Rus |
03-28-2013, 10:41 AM | #843 | |
Man of Mini-Talents
Works for me!
03-29-2013, 03:04 PM | #844 |
Thanks Rus.
:LOL: Break Break Here are the specs for my Cam: http://www.summitracing.com/parts/cca-54-45311 I'll also be upgrading to dual valve springs, hardened pushrods and a trunion upgrade for the rocker arms (as well as deleting the AFM and VVT, ). UPC: 036584213741 Cam Style: Hydraulic roller tappet Basic Operating RPM Range: 1,500-6,700 Intake Duration at 050 inch Lift: 219 Exhaust Duration at 050 inch Lift: 235 Duration at 050 inch Lift: 219 int./235 exh. Advertised Intake Duration: 269 Advertised Exhaust Duration: 285 Advertised Duration: 269 int./285 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.607 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.621 in. Valve Lift with Factory Rocker Arm Ratio: 0.607 int./0.621 exh. Lobe Separation (degrees): 113 Camshaft Gear Attachment: 3-bolt Computer-Controlled Compatible: No Grind Number: 269LRR HR13
03-29-2013, 03:10 PM | #845 |
A guy with a truck
219/235?! Wholly lumpy blower cam, Batman! Gonna sound BA. 3" exhaust on this one?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
03-29-2013, 03:16 PM | #846 |
Yeah, forward progress!
Posted via Mobile Device Posted via Mobile Device
03-29-2013, 03:18 PM | #847 | |
Finally!!! Hope your trip is going well.
03-29-2013, 07:40 PM | #848 |
Is the blower and the cam swap going to drive a converter change?
03-29-2013, 08:14 PM | #849 | |
03-29-2013, 09:08 PM | #850 |
Laid Back
Use urethane reducer to take the spray paint off..
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
