Old 03-14-2011, 09:48 AM   #826
67cheby
67cheby
67cheby's Avatar
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
Nice work as usual !! Looking great
67cheby is offline   Reply With Quote
Old 03-14-2011, 11:49 AM   #827
MalibuSSwagon
niiiice
MalibuSSwagon is offline   Reply With Quote
Old 03-14-2011, 02:36 PM   #828
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
A shot of the 2002 leather seats all the way forward and back. Still plenty of rear legroom when fully back.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 03-14-2011, 03:38 PM   #829
fencepost
fencepost's Avatar
Thats going to be really nice ride.
fencepost is offline   Reply With Quote
Old 03-14-2011, 03:39 PM   #830
67cheby
67cheby
67cheby's Avatar
are you going to run the denali guages???
Old 03-14-2011, 03:55 PM   #831
thor
thor's Avatar
IIRC, he said he was going to keep it stock on the inside, atleast what you can see.
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 03-14-2011, 04:28 PM   #832
drewskiren
drewskiren's Avatar
Stock looking with new seats and new wheels and tires. A stock looking gauge cluster, but I'll have to relocate the radio and unfortunately I have to use the modern A/C controller.
Drew
Old 03-14-2011, 04:56 PM   #833
VA72C10
VA72C10
VA72C10's Avatar
Those seats are super comfy. I had a set before. Will make for a nice comfy ride combined with the modern air ride suspension!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 03-14-2011, 07:07 PM   #834
drewskiren
drewskiren's Avatar
Are you catching my theme here????
Drew
Old 03-14-2011, 07:27 PM   #835
JasonBird
'67 C-10 LWB Driver
JasonBird's Avatar
that's awesome drew!
'67 C-10 LWB - My Build Thread
'67 C-20 LWB - My Donor/ Parts truck - SOLD!
'92 GMC SAFARI VAN - My Parts Go Getter
'06 KIA SPORTAGE EX - My Commuter
"All of this crap better make a truck!" - my wife Sue.
Proud U.S.M.C. Dad!
JasonBird is offline   Reply With Quote
Old 03-14-2011, 08:10 PM   #836
JRBECK64
Jumpin Judas thats a lot of wire!!!!
Truck is really lookin good.
JRBECK64
JRBECK64 is offline   Reply With Quote
Old 03-14-2011, 08:15 PM   #837
drewskiren
drewskiren's Avatar
I drilled all the holes for the front seats, easy. The rear seat has a lift and flip feature the incorporates these hoops for sliding up and down on as it goes through the motion. I had just hacked them out of the blue parts truck, so now I have to grind out the welds and separate the backing plate from the blue sheet metal. Once that was done I drilled out the ends where they mount on the crew back panel and cut slots connecting the end holes. Stuck them in from behind like the factory did and welded them up.
The bottom brackets on the rear seat just bolt to the floor.
Drew
Old 03-14-2011, 08:16 PM   #838
VA72C10
VA72C10
VA72C10's Avatar
Old drivetrain and mechanicals, boring, no room, and uncomfortable?
Old 03-14-2011, 08:24 PM   #839
drewskiren
drewskiren's Avatar
You forgot ugly.
Drew
Old 03-14-2011, 08:33 PM   #840
VA72C10
VA72C10
VA72C10's Avatar
oh...and I also forgot uncool and not awesome
Old 03-14-2011, 08:36 PM   #841
drewskiren
drewskiren's Avatar
JRBECK64
Thanks for the compliment, Yeah - every time I look over in the wiring harness direction I get that sick feeling, but then I read my little green tags and feel better.
Drew
Old 03-14-2011, 08:39 PM   #842
kmdracer
kmdracer's Avatar
Very fine job sir!
kmdracer is offline   Reply With Quote
Old 03-15-2011, 12:03 PM   #843
drewskiren
drewskiren's Avatar
Here is a shot of the seat holes and the seat belt holes I drilled if anyone cares for placement purposes.
Drew
Old 03-15-2011, 12:13 PM   #844
VA72C10
VA72C10
VA72C10's Avatar
Have you decided how you will reinforce under the cab floor?
Old 03-15-2011, 12:16 PM   #845
drewskiren
drewskiren's Avatar
Giant washers that the 2002 uses to hold the cab on. That and the rear mounts on the front seats land on an overlap seam of double sheetmetal on the crew cab (suburban) floor. These 2 mounts are obviously the 2 most important with my integrated seat belts.
Drew
Old 03-15-2011, 12:24 PM   #846
maynardtruckin
maynardtruckin's Avatar
Ok looking through your build and it is a sweet truck, but I was wondering what is the dimensions of your rear door? I am thinking that the rear seat will be tight for leg room. I have been looking at several different trucks like this over the years and all were tight for leg room in the back. Just kind of wondering because I am looking to do something similar to my 70, but still a sweet build.
Chris
67 c10 swb build in progress
70 c10 lwb driver pending parts for drastic overhaul
70 c20 lwb parts truck for above mentioned drastic overhaul
71 k20 lwb building for off road use and towing
maynardtruckin is offline   Reply With Quote
Old 03-15-2011, 01:42 PM   #847
drewskiren
drewskiren's Avatar
The "doors" are stock suburban doors, but really there is only one. 33 inches long. Give me a couple of months and I'll take pictures of the seats installed and measure it for you. Remember also that I am using the 2002 extended cab seat and not the huge crew cab seat available starting in 2003.
Drew
Old 03-15-2011, 02:41 PM   #848
68 TT
Still plays with trucks
68 TT's Avatar
In retrofitting the newer seat into mine I am leaning toward using a length of 2"x1/8" steel flat bar below the floor pan that will tie both seat mount points on each side of the seat together front to back just for a little more strength and to spread the load a little. The seat belt anchor points can be tied into the flat bar as well. I might be able to tie the ends of the flat bar into the edge of the original seat mount reinforcement areas too.
Run the seat mount studs from the donor through the flat bar and up into the cab so the stock locking nuts can be used too. Stitch weld the flat bar to the bottom of the floor pan to secure it in place and seam seal the rest of the edge to keep moisture out.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 03-15-2011, 03:14 PM   #849
drewskiren
drewskiren's Avatar
Good plan. After I responded to that message I walked out and looked it over and decided I had room for 4 inch by 6 inch quarter plate on the rear mounts, I may just do one plate like you are thinking. Paint the bar first, mount seat with nuts and bolts and Locktight, then seam sealer the perimeter of the flat stock, finish with undercoating.
Drew
Old 03-15-2011, 03:19 PM   #850
drewskiren
drewskiren's Avatar
Moving on, we must be able to stop. I had a spare brake assembly that I stole a linkage from to help mate old to new. I cut off the new rod and welded the old threaded rod to it. Then I threaded the cutoff - half on the old threaded rod, half on the new shaft that was a tiny bit smaller diameter. This was my reinforcing sleeve over my welded rods. Then I had to make the center hole much bigger and relocate the holes for the studs on the new booster to fit inside the cab. I took out the studs on the 72 brake mount and later drilled it out to line up with the new studs.
Drew
