Closed Thread
Old 06-12-2012, 09:11 PM   #826
lowdownstar
big guy
lowdownstar's Avatar
Re: What Did You Do With Your Truck Today ?
I built a frame for the back bed and put a piece of plywood on top so i can use the truck to carry all my junk to the good-guys car show this week end. i took the truck out for it's first ride last night ever! It runs good i am very happy with it so far still have lots of bugs to work out but she is moving!
Thanks Ray
lowdownstar is offline
Old 06-13-2012, 02:22 AM   #827
Chevette
Chevette's Avatar
Nice job on the frame. Is it inch and a half? I can't recall ever seeing plywood with the grain running on the 4ft.
Chevette is offline
Old 06-13-2012, 06:37 AM   #828
lowdownstar
big guy
The steel is 1" and the ply wood is 1/2" i used two sheets. I just did it for the show because i didn't have time to build a nice wood deck for it yet.
Ray
Old 06-13-2012, 09:02 AM   #829
focusedontheprize
focusedontheprize's Avatar
Bed looks nice.
I ordered the cab mounting kit for mine. Hopefully I can get it on the frame in 2 weeks. This weekend I hope to have the rear end painted and the engine mounts finished.
focusedontheprize is offline
Old 06-13-2012, 11:12 AM   #830
lowdownstar
big guy
ocusedontheprize they are never done! lol
Ray
Old 06-13-2012, 08:31 PM   #831
Fatbear
I put the 2013 sticker on my tag
Fatbear
1952 yellow 3100
350 v8 on sonama frame
Fatbear is offline
Old 06-13-2012, 11:23 PM   #832
jrdecat
I dropped my gas tank and discovered that I need a new one. Yay!
jrdecat is offline
Old 06-14-2012, 01:09 AM   #833
meter swinger
meter swinger's Avatar
Ran it out of gas.
Guess maybe ill fix the gauge.
HAHA
meter swinger is offline
Old 06-14-2012, 01:33 AM   #834
npetric
Test fitting the motor....
npetric is offline
Old 06-14-2012, 08:32 AM   #835
danheit
danheit's Avatar
Mocked the body onto the new frame.
danheit is offline
Old 06-14-2012, 09:51 AM   #836
mknittle
mknittle's Avatar
What's a new frame?
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 06-17-2012, 07:53 PM   #837
mobileortho
mobileortho's Avatar
Since I'm not going to use tail tailgate chains, I wanted to fill the void on the tailgate. Cut a piece of angle iron and weded it right up. Turned out pretty good.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline
Old 06-17-2012, 09:25 PM   #838
mknittle
mknittle's Avatar
looks good from that angle!I may do somthing like that when I get that far.
Mark
My GMC build.
mknittle is offline
Old 06-17-2012, 09:34 PM   #839
mknittle
mknittle's Avatar
I looked at it and thought about my coil-over mounts. tomorrow i will put the cover back on my rear end. bad gears and all. then I can finish the suspension mock up.
i will worry about the gears later. It will be a good excuse to change ratios for the four speed.
Mark
My GMC build.
mknittle is offline
Old 06-18-2012, 01:10 AM   #840
OrrieG
OrrieG's Avatar
Body work and fixed the tailgate trunions so they are perpendicular to the tailgate instead of angled 3/16".
OrrieG is offline
Old 06-18-2012, 06:56 AM   #841
lowdownstar
big guy
I took it out for it's first ride and decided to bring to a good-guys show, had a blast!!! Truck ran good still have a few bugs to work out but it was so much fun to drive!
Thanks Ray
Old 06-18-2012, 08:09 AM   #842
focusedontheprize
Think I finally am done with grinding rust off this truck...
Pulled the rear end this weekend and cleaned it. After 2 coats of POR15 and 3 coats of flat black it matches the frame (no pictures at the moment). Pulled the axles to get them drilled for a Chevy bolt pattern, finished the mock up of the motor and transmission, pulled the motor mounts to finish the welding on them and put the motor back on the stand.
Next weekend my goal is paint and to finally put the thing in between the rails for good.
Old 06-18-2012, 08:53 AM   #843
mknittle
mknittle's Avatar
Thanks Ray
looks rwally nice Ray.
Mark
My GMC build.
mknittle is offline
Old 06-18-2012, 08:27 PM   #844
lowdownstar
big guy
Thanks it was a really nice show. here are a couple of pic's of cool trucks
Ray
Old 06-18-2012, 08:55 PM   #845
mknittle
mknittle's Avatar
I put the rear end back in after I cut the brackets off that were in the way. now I can start on the coil-over mounts. and then some more gussets and a couple braces.
Mark
My GMC build.
mknittle is offline
Old 06-18-2012, 09:04 PM   #846
lowdownstar
big guy
Looking good!
Ray
Old 06-18-2012, 09:13 PM   #847
mknittle
mknittle's Avatar
Looking good!
Ray
Thanks Ray, It seems like it takes me longer to decide what do next than to do it
Mark
My GMC build.
mknittle is offline
Old 06-19-2012, 01:37 AM   #848
azsnow
azsnow's Avatar
Sold it...
azsnow is offline
Old 06-19-2012, 10:34 PM   #849
mknittle
mknittle's Avatar
I started the lower coil-over mounts. I started last night by making a drawing and tuning it until I had somthing that I liked.
This morning I made a template for the parts that fit between the shock and the part that welds to the housing{on the left}. The template is .125 smaller on all sides to compamsate for the tip on the plasma cutter.this will allow me to make all four parts the same. it will also make it easier to make a replacement if I don't get the bending right the first time!
Then I drilled the holes for the first plate that welds to the housing.{on the right.The silver marker lines show roughly how it will look.As an after thought I think I might add another adjusting hole on the bottom.
When I get it the way I like{before cutting} I will clamp a blank to it and use transfer punches so both come out the same. I also like to bolt parts that aer the same together during final grinding.
Mark
My GMC build.
mknittle is offline
Old 06-19-2012, 10:44 PM   #850
Amorget
Do you have a PlasmaCam or something like that?
Amorget is offline
Closed Thread
