#826 |
Re: What did you do to your truck today? Chapter II
I Like those! ......how about some before and after shots.
1970 C10 Short Stepper with 71/72 front clip. |
#827 |
2WD Jimmy
![]() Join Date: Mar 2005
Must be the same little short cop that literally physically ripped the rear lisence plate Off my sons mini truck and threw it on the ground. My thought is, how are you really going to see the plate that well with a trailer back there anyway.
#828 |
Before.
#829 |
?? you weren't allowed to pay the fine and get it out of impound ?? .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#830 |
Tried again to get my brakes finished up. Still can't get the parking brake to fully engage so the truck continues to sit in jackstands
1972 Chevrolet swb fleet side. - SOLD 2018 Toyota Tacoma but hunting for another C10 Link to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=607303 Instagram: https://www.instagram.com/72c10shortbox/?hl=en |
#831 |
Your truck looks awesome either way, but like the new look!
#832 |
while i'm off work i replaced the bed floor with a mint condition floor i found. been an ongoing project cause while i had the bed off that led to replacing the rear coils then while doing that i noticed the trailing arm bushing were shot so replaced those. have the bed on and bolted down now and just finished connected the wiring.
can't wait to get it back on the road. |
#833 | |
#834 |
I know it's not like they can't pull forward and see the front license plate here in Oregon! LOL
1970 C-10 350, 350 trans, ps,pb |
#835 | |
RAT1968 '68 Cab/'71 Parts
You know Irene. Pretty refined broad. But, in any situation similar to that one in which the guy was, as we say "carrying a heavy badge", she doesn't always make the best choices in her communications. The best for *me*, that is.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#836 |
He could have, but the impound was $300.00 the 1st day and it went up after that. He and I are both on SSDI so paying a fine wasn't an option.
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182 700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236 |
#837 |
Finished putting side molding on. Also finally got the rear tires mounted today.
Tires and rims now all the same size 20x10 275x45's. Waiting for the door panels to get covered and I have to get to the shifter boot fitted. Maybe tomorrow...
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
#838 |
Cut-n-Buffed one of my rear fender wells.
#839 |
#840 |
![]() Join Date: Apr 2013
When I see this I think of pulp fiction..when they keep lookinhlg in the briefcase..
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
#841 |
![]() Join Date: Sep 2012
Put in all the new window seals to go with the new door seals I put on a couple of weeks ago, Funny, look at the new seals compared to the 45 year old ones on the floor
#842 |
I put a AUX input jack 3.5mm on my original AM radio for my 72 GMC Burb project. I found the thread last night and thought I would give it a try. The total cost for the mod was $4.39. This belongs on the "Under $50 Cheap Mod" thread, but it appears that thread is closed (can't post to it)! Now my factory AM radio plays my Samsung Galaxy. This is the thread, very easy to do, just follow the pictures. http://67-72chevytrucks.com/vboard/s...d.php?t=502427. He did a great job but I modified the instructions a little bit for my benefit, so I thought I would post them below just in case anybody else wanted to print them while doing this mod.
Aux Input Connector Simple install of a Stereo type 1/8” input jack into stock 67-72 AM Radio. This allows for the use of any low signal output to be played right through the radio without sacrificing the AM portion of the radio. Such devices like an MP3, Ipod, or portable CD player, or android phone with Pandora app. You won’t need any separate switch. The stereo jack used will give priority to any device plugged into it. And when the device is remove from the jack your AM radio will function as it normally would. This is a pretty basic install and with a few basic tools and a careful approach nearly anyone should be able to do this for about $20 including the 3’ patch cable. You’ll need to visit your local Radio Shack and obtain a pack of small resistors 1k or 2k ohms part # 2710153 $1.49 and an 1/8” Stereo Phone jack (Closed circuit). part # 2740246 mini jack -CLS $2.99. Also, If you don’t have one already grab a 3’ or so patch cable. (This is a standard headphone type end) 1) Remove the top cover of the radio and locate the blue wire from the volume potentiometer to the circuit board. You’ll be installing the input inline between the board and the pot in this circuit. Clean the interior of the radio gently. 2) Assembled and soldered input jack. There are 5 connection points on the input jack. If you are installing the jack in a ground metal opening like our trucks then there is no need for a ground wire and the #1 terminal of the jack need not be used. The two resistors get soldered together at the #5 and #2 Terminal and then one lead gets attached to them that will be later go to the potentiometer. The #3 and #4 terminal get “jumped” together and a second wire lead will be added that will be soldered to the printed circuit board. Old speaker wire will work fine. 3) Remove the chrome face of the radio and locate and drilled a 15/64 hole all the way to one side. (Be sure the AM dial needle will not hit stereo jack inside the radio). Be sure to carefully de-burr the inside and outside edges of the new hole. I drilled my hole too far over making it difficult to install the AUX jack connector! I had to remove material with a rotary tool to the connecter to mount inside the face plate. NOTE: The terminal lugs on the back of the stereo jack are very close to the edge and once installed they could ground out on the inside edge of the faceplate. So slightly bend the terminals inward with a needle nose pliers and put a few small scraps of heat shrink tubing in different spots. I used liquid tape. 4) Carefully install and tightened the stereo jack into the faceplate. 5) Re-installed the faceplate onto the radio. 6)“Un-solder” the blue lead at the circuit board (or cut the blue wire at the board). 7) The lead made from the jumper of the 3 and 4 terminals (without the resistors) is soldered to where the blue lead was soldered into the circuit board. 8) Strip the end of the existing blue lead going to the potentiometer and solder the lead with the resistors to the blue lead going to the potentiometer. Protect exposed connection with heat shrink or liquid tape. Use a small wire tie to keep all the leads away from the dial and put the top cover back on. 9) And that’s it! |
#843 |
That is something to remember! Great idea!
I still have a few more stupid questions left to be asked. '72 C-10 LWB step side "Old Red" '71 C-10 Cheyenne "Blue" |
#844 |
I need pictures, but I know have the Cheyenne stripped down further than I have ever taken down a truck. Basically she is a rolling chassis and a cab.
Every panel on the truck will need attention, I repaired the passenger side fender yesterday. (Most of the "Bulb" was rusted out). Now I know my truck, while a factory Cheyenne with all the chrome trim, was a white top and blue all below, without the white band. ![]() I also found out that the drivers side door is unusable, It shut and lined up so I never paid much attention, but closer inspection revealed that at some point in it's life somebody backed into a very solid object with the door open! Good thing we had a spare door in the parts stash. One of the benefits of rebuilding a truck that was beyond economical restoration is that it will probably never have any collector value. So I'm going to put the white stripe back on. Along with every other option I can find. In the end I hope it's a real sharp ten foot farm truck.
#845 |
did my seals and corner glass today
one step closer to being on the road ![]() |
#846 |
Technically this was an off and on project from the last couple of days.
Having spent her life in and around the Toledo area old Blue has a few extra holes. ![]() Poverty is a great motivator. ![]() A little more work and it will be good enough.
#847 |
Finished the rear fenderwells today.
#848 |
Very nice work, super paint, how much did you add to them?
#849 |
I delivered the spare un rusted , un damaged radiator core support to the new paint jail......
He says they're getting ready to bead blast my spare cab and begin working on it . I have some ' better ' (not as loose) door hinges , is there any one who's re - bushing them ? . I'd love to mail these away and get 'em back all new and tight again .
#850 |
I walked by it..
