Old 12-22-2015, 10:16 AM   #826
Advanced Design
Advanced Design's Avatar
Re: 48 Burb, bagged, 5.3, 20 year wait
Google is my friend...though I haven't found Camaro dimensions yet.
Here is truck and Corvette.
Advanced Design is offline   Reply With Quote
Old 12-22-2015, 10:18 AM   #827
Advanced Design
Easier to see. Corvette.
Old 12-22-2015, 10:20 AM   #828
Advanced Design
And truck.
Old 12-22-2015, 10:22 AM   #829
Advanced Design
Can anyone find Camaro stock dimensions?
Remember back in the day when all we cared about was hanging an alternator?
Old 12-22-2015, 12:04 PM   #830
FarmerSid
FarmerSid's Avatar
I'll look for some dimensions too. Do you still have your inner fenders on? if so, what dimensions do you get from the crank center pulley to the inner fenders on both sides? what about the same but from the water pump pulley to the inner fenders? Cheers!
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 12-22-2015, 12:21 PM   #831
Advanced Design
I do and was thinking those dimensions would be handy so I will get them. There will probably be variation depending on engine placement....up, down, fore, aft.
Old 12-22-2015, 12:49 PM   #832
FarmerSid
FarmerSid's Avatar
From the few minutes I have to search. It looks like earlier Vettes (1998) had the alt up top and a newer (2002) had it down low. Still on the look out but thats what I found so far.
C4 IFS & D44 IRS
5.3 HO L33
Old 12-22-2015, 01:30 PM   #833
Advanced Design
Here is Camaro.
Old 12-22-2015, 01:50 PM   #834
Advanced Design
Here are the dimensions in my Burb. The dimensions will be varied based on engine placement as the inner fenders are not squared up and down or fore and aft. You can see that in the second picture.
This engine is 2" above radiator support cross member as measured from the outside bottom of the truck balancer. Left rocker cover is about an inch forward of the toe board.
I heard back from R & D, their radiator measures 3 1/2" from mounting flange to the back of the slimline Spal fan.
Old 12-22-2015, 02:56 PM   #835
FarmerSid
FarmerSid's Avatar
Thanks AD. That will help a lot. It's gonna be tight with the rad and e fan in there. Hope it fits perfect.
C4 IFS & D44 IRS
5.3 HO L33
Old 12-23-2015, 12:34 AM   #836
99 to Life
99 to Life's Avatar
Nice specs you dug up there doug! helpful stuff, I like to keep stuff simple if possible. LS stuff is far from simple! I personally don't even like the look of full serp setups. I still like the ol' two belt sbc stuff! ironically I do like seeing coils and the modern look of an LS, just not the front of it. Its always something, I'll be on the hunt and or right in your position in a few weeks when I get engine plopped in and start seeing what the heck I gotta REDO.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-23-2015, 10:39 AM   #837
reaper71
reaper71's Avatar
Really nice info Doug!
The truck setup is much tighter and cleaner look. (my 2cents)
Mark...
reaper71 is offline   Reply With Quote
Old 12-23-2015, 11:28 AM   #838
Advanced Design
Sid, thank you for doing the research too. I didn't know about the different Corvette configuration. I think working together we will all figure out what will work for our builds.
99, This information is probably in a sticky somewhere though I didn't find it in one place. So many variables here. Sometimes I think I would like to build something that bolts together without all the configuring and fabrication. We dropped an LS in a friends 65 Pontiac wagon in like 10 minutes. Would have been 5 except we had the engine mounts in backwards. So easy.
Mark, I agree on the truck set up, especially for an AD truck. Corvette is way too wide and I think the Camaro will put the alternator into the frame. Rub is the Camaro intake won't work with the truck accessories.
Thanks to a member here who pointed me to the instructions for the Holley A/C bracket to see the dimension from cl of engine to outside edge of R4 compressor is 16 1/4". I am pretty sure that will put the compressor slightly into the inner fender. Sanden dimensions are 18 1/4 inches. Tried to copy the picture to here and couldn't figure it out on this Ipad.
Here is my engine location to firewall...about a finger width. Pretty sure I am going to copy Iceburgh for firewall modification. Right after we deliver Christmas cookie trays to neighbors.
Old 12-23-2015, 11:36 AM   #839
Advanced Design
Just for reference comparison here is the firewall modification Iceburgh did on his Burb. Biorn123 is going a similar route.
Thanks guys. I am copying shamelessly!
Old 12-23-2015, 03:49 PM   #840
FarmerSid
FarmerSid's Avatar
There is a way where you cut a portion off of the truck ALT mount and relocate the idler in order to put a car LS intake on. Check this out.
http://www.ls1truck.com/forums/front...take-swap.html
Maybe I'm fussy but the ALT sticks up quite high above the intake.
Any chance you can try again to post the pictures of the Holley bracket dimensions?
Happy cookie drive'in!
C4 IFS & D44 IRS
5.3 HO L33
Old 12-23-2015, 05:05 PM   #841
lower50's
lower50's's Avatar
Isn't copying the best form of flattery.?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 12-23-2015, 05:11 PM   #842
Advanced Design
Great information Sid! I agree, the alternator sticking up doesn't look great.
Since I can't figure out copy and paste from the pdf document, here is a copy paste of the post from another member who helped me find it.
Held off on cookie delivery due to heavy rain.
Re: Hooker 73-87 GM truck LS swap system
Page 2 of the instruction manuals for the complete accessory drive kits shows the dimension you are looking for.
20-136 R4 Complete Accessory Kit product page:
20-136
Deep link to instruction manual:
20-136 Manual
20-137 Sanden 508 Complete Accessory Kit product page:
20-137
20-137 Manual
Old 12-23-2015, 05:15 PM   #843
Advanced Design
Try try again...
Sanden..http://documents.holley.com/199r10638rev2.pdf
R4....http://documents.holley.com/199r10638rev2.pdf
Now cookie delivery...
Old 12-23-2015, 06:36 PM   #844
BlueJeep
BlueJeep's Avatar
I did quite a few little things to mine to get it to fit how I wanted it. I did a similar firewall mod, trying to make it appear somewhat factory. I took a leftover piece from a patch panel and used it to fill in the gap, worked very well.
I also ditched my stock inner fenders in favor of custom ones I made. I just couldn't stand how much wasted space there was with the originals, and also didn't want all the road debris thrown by the front tires to hit the back sides of the fenders. I ended up with a lot more room to stuff things.
Lots of room for the compressor:
And I'm left with a nice place to be able to run wires and hoses that won't be seen:
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-23-2015, 08:10 PM   #845
Advanced Design
Yep, it usually is!
Old 12-23-2015, 08:15 PM   #846
Advanced Design
Very cool mod's Blue Jeep! I like them!
Is the box on the left one for PCM mounting? Looks like the fabricated ones completely replaced the original inner fenders?
Old 12-23-2015, 09:06 PM   #847
BlueJeep
BlueJeep's Avatar
Yes and yes. The PCM mounts between that inner fender and the firewall, on the driver's side. The truck harness is the perfect length to do that with, and it uses the flat s10 mount to fasten the PCM down.
Lots of room for mounting it down there:
Also lots of room on the front side for the air filter:
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-23-2015, 09:31 PM   #848
Advanced Design
Great ideas and fabrication BlueJeep. Love it!
The fabrication shop in town just installed a new waterjet. Exciting for we folks out in a rural area to have this available....so I had them cut out new frame tab engine mounts. Really, nice, clean and precise cuts.
Will someone please remind me to build in adjustability on the next set of mounts I do? I did the current mounts out of what I had in the shop. They will work fine once I get the engine in the right place. Just too much work when I need to make an adjustment because I didn't plan ahead properly.
Christmas cookie trays delivered. Wife is wearing me out...she is making more fudge tonight. Awesome! Praise the Lord!
Old 12-23-2015, 10:45 PM   #849
65sub
65sub's Avatar
I'm glad yo hear Mrs A.D. is feeling better and it's also good to see you back in the shop. Fitting the accessories looks like an interesting challenge. If everything just bolted together everybody would be doing it.
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 12-23-2015, 11:16 PM   #850
Advanced Design
Thank you 65sub! I will admit sometimes I would like to build something that you can unbolt, clean up and bolt back together....then I start having so much fun with the welder, grinder and figuring things out that I come back to my senses.
