Old 10-07-2009, 11:31 AM   #851
MacAttack
283 Drama Queen
MacAttack's Avatar
Re: Daverods project 66
Ah, now I get it - in the vertical more than 3 degrees is okay.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 10-07-2009, 12:26 PM   #852
padresag
yes and it can be offset to the side at the same time, as in the pinion being offset to one side. the ujoints should be sync also with one another for it to work properly.
the same if you have bag suspension and you can raise and lower the car at a whim. the d/shaft compensates through the ujoints
simple things can be quite complex at times even if the same theory has been used now for over 100 years
ron
padresag is offline   Reply With Quote
Old 10-10-2009, 12:08 AM   #853
daverod
SSN 706
daverod's Avatar
Been working on removing my 3 speed from my 64. I have it almost all the way out the problem is I can't seem to get it to clear the trans mount. It does come out the bottom right? I don't have to remove the trans hump do I? Are there any tricks to getting it out. I have removed the mounts. Can seem to get it the last inch?
daverod is offline   Reply With Quote
Old 10-10-2009, 12:25 AM   #854
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
If you cant get it to clear the mount, take the mount out.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 10-10-2009, 12:27 AM   #855
daverod
SSN 706
daverod's Avatar
I guess its not the mount it the cross member and its studded in not bolted. That would be to easy.
Old 10-10-2009, 09:44 AM   #856
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
take out the crossmember i think thats what ruffrida was saying
just get an air chisel and pop the rivets off then replace them with grade 8 bolts
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 10-10-2009, 01:12 PM   #857
Strodder
Daring to be Different
Strodder's Avatar
BFH, or do you have a Plasma Cutter.
Just kidding. I have no idea.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 10-10-2009, 01:38 PM   #858
watahyahknow
watahyahknow's Avatar
eeehmm maibe loosen the cab and raise it of the mounts a little
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 10-10-2009, 02:02 PM   #859
daverod
SSN 706
daverod's Avatar
It's 64 Chevy not Ford. I have a hard time believing I have to take the member out. I'm thinking just more time, more sweat clean some of the crap off it oh ya and a BFH. Plasma for christmas.
Old 10-10-2009, 02:03 PM   #860
daverod
SSN 706
daverod's Avatar
I was thinking that too.We'll see I think I just have to turn it just right.
Old 10-10-2009, 03:18 PM   #861
ruffrida2005
Dave while you have a chance now I would take it out like Gage said and put grade 8 bolts back in it. I would do that to every crossmember. Makes it a lot easier to work on when you need to. Just make sure you use loctite and lock washers.
Paul
Old 10-10-2009, 06:03 PM   #862
daverod
SSN 706
daverod's Avatar
The tranmission is out. Taking it down tomorrow to see whats up. Came out easy when I took the bell housing off. Guess I better do somthing to the clutch too, eh.
Old 10-10-2009, 10:41 PM   #863
daverod
SSN 706
daverod's Avatar
Do you think a 4 speed would be stronger than a 3 speed?
Old 10-11-2009, 12:08 AM   #864
Captainfab
60-66 Nut
I've not had a 3 speed, but the SM420's and SM465's are pretty damn tough.
You still only have 3 forward gears that you use most of the time, but you have the low 1st gear for those times when you need that extra low gear for pulling.
Old 10-11-2009, 02:08 PM   #865
daverod
SSN 706
daverod's Avatar
The 3 speed I have is a 344. I never pull anything so I don't think a 4 speed would be any better, unless it's a lot stronger. Most the time with a 4 speed you take off in second anyway.
Old 10-11-2009, 03:34 PM   #866
Strodder
Strodder's Avatar
You don't start out in 1st with these trannys. Your talking about a 4 speed transmission with a compound low.
http://www.nastyz28.com/chevy-manual...tification.php
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 10-11-2009, 04:31 PM   #867
daverod
SSN 706
daverod's Avatar
I would'nt I start out in 1st? What gear would I use?Relax it's bezel time again.
Old 10-11-2009, 07:59 PM   #868
Strodder
Strodder's Avatar
First is the first gear you start out in, then shift into second, then third, and finally shift into the 4th position. That is 4th
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 10-11-2009, 08:02 PM   #869
Strodder
Strodder's Avatar
Now if you can do that really fast you might churp the tires in second gear.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 10-11-2009, 08:02 PM   #870
Strodder
Strodder's Avatar
I bet Gage can do it.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 10-11-2009, 08:03 PM   #871
daverod
SSN 706
daverod's Avatar
Did you say no beer? I was thinking just one might help to relax. I'm getting pumped. Bezel ,bezel, bezel. I ewas thinkinh maybe two on each side one set hooked up to a cut out and the other to the mufflers.
Old 10-11-2009, 09:20 PM   #872
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
yep i can do it with an automatic too
with a shift kit of course
Gage
Old 10-12-2009, 09:24 PM   #873
daverod
SSN 706
daverod's Avatar
Started thinking about my front end parts. I want to get everything powder coated. I'm going with 2 1/2" dropped spindles and air bags. My cross member has been pancaked 1 1/2". Do you think I'll need to remove the rubber bumper and its bracket to lay frame. What about the shock mount location? Does this stay in the same location or will this also have to be moved? I'm also thinking about the steering. If I lay frame do I need to go with rack and pinion or can I do it some other way.
Old 10-12-2009, 09:48 PM   #874
daverod
SSN 706
daverod's Avatar
Found these pictures of some steering stuff and stuff. Ruff have you any of your rack and pinion?http://www.thehollisterroadcompany.com/rackpinion.html
Old 10-12-2009, 10:05 PM   #875
ruffrida2005
I think you will still have to cut off the bump stop, since it sticks up over a 1 1/2" Best thing to do is just put it together and ley it on the floor. And about the steering look at the post before mine. I've sent you those pics before!
Paul
