Closed Thread
Old 02-23-2010, 09:18 AM   #851
menace121978
menace121978's Avatar
Re: Finally "Silvers" build thread!! ('78 swb 2wd silverado)
you got it buddy...
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline
Old 02-23-2010, 09:35 AM   #852
Thealien
Thealien's Avatar
Next time I go to the garage I will take a couple of pictures. If there is a part number on it I will get it. There is a 10mm bolt that goes in the hole to attach the transmission to the engine. There is an 8mm stud that comes out the head of that bolt that the transmission dipstick tube goes on then a nut holds it on.
Here is s great place to look up part numbers
IT TAKES A LITTLE SEARCHING THOUGH
THIS LOOKS LIKE THE TUBE
AND THIS APPEARS TO BE THE DIPSTICK
I'll check those part numbers when I go to the garage.
Thealien is offline
Old 02-23-2010, 11:40 AM   #853
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
As long as the OE dipstick will fit in the truck, I say use it. No sense making new holes if you don't need to.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline
Old 02-23-2010, 11:39 PM   #854
85burb
85burb's Avatar
Sorry to but in but do the factory manifolds fit in a square body good? Nice work buy the way.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline
Old 02-24-2010, 06:21 AM   #855
menace121978
your not butting in man... yes they actually fit great but the passengerside frame rail needs to be notched just a little bit. a shape like ( about 1/4".
late night last night draggin86 came by and we got the floor pan cut out! Amy took a few pics that i'll post after work. i have to get to work. crazy... i was up till 11pm slept till 2am and going to work by 3am! have a good day guys!!
oh yea, i got my fuel line flared in the mail today!thanks Bob and i sent a message to the trans Xmember guy asking what was up and he responded in less than an hour and said sorry for the delay we'll throw in a tranny mount for free and it will be shipped as soon as the paint dries!(tomorrow) awesome service
"Dennis the Menace"
Old 02-24-2010, 01:47 PM   #856
Thealien
Thealien's Avatar
Here are some pictures for you!
showing how the bracket looks
side view showing how it bolts to the specisl bolt
And the part number off the tube itself
Thealien is offline
Old 02-24-2010, 08:56 PM   #857
85burb
85burb's Avatar
With that being said a set of truck shorty headers may fit good? Thanks for the info.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
85burb is offline
Old 02-24-2010, 11:15 PM   #858
draggin86
draggin86's Avatar
All I have to say is Dennis is a spot weld drilling machine!
draggin86 is offline
Old 02-24-2010, 11:18 PM   #859
fpjr0
fpjr0's Avatar
thealien where did you get those fittings on the transmission.. I found some 1/8 18 npt fittings but then I read that they are supposed to be 1/4 18 national pipe straight thread what are those you used? thanks ...
fpjr0 is offline
Old 02-24-2010, 11:44 PM   #860
Driveway Dreams
I have car A.D.D.
He has a passion for his truck that comes from a rich history with it. I am sure that is what motivated him to drill out all the spot welds. Cause it sure wasn't for the enjoyment of drilling...I'd hope.
Dennis, lets see the pictures man!
-Gerald
Old 02-24-2010, 11:54 PM   #861
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
This looks like a 4l60, is it the same for the 4l80? My 80 doesnt have the cooler fittings on top of one another, thats why I am asking.
--Josh
STOCKISH is offline
Old 02-25-2010, 07:41 AM   #862
Thealien
Thealien's Avatar
Yes mine is a 4L60 but a 4L80 will attach the same but I believe to be a different part number.
If you go to the first link in my post above (it takes a little searching though) compnine. Click on the left panel where it says chevy light truck. Then click the year that the transmission is for. Then go through until you see a picture of a transmission. You will look at a bunch of additional pictures until you see one with a picture of a dipstick and then click on that picture. Below that picture will be a list with all the part numbers.
You can then just take that part number to a dealer, GMparts direct, bygmpartsworldwide, or ask for one at your local pick and pull. The tube only lists for about $20. Its the dipstick that is expensive but they are the locking type with the red cap/lever.
Thealien is offline
Old 02-25-2010, 07:47 AM   #863
Thealien
Thealien's Avatar
My local transmission shop got them for me. Be advised they are not national pipe taper thread. You can crack your transmission if you install NPT too tight. Transmission cooler line fittings on these newer transmissions are NPST national pipe straight thread. My fittings are to inverted flare so I can try to use my original cooler lines.
If you are going AN fittings they make an adapter to go from the factory quick disconnect to the AN Or they also make AN to NPST.
Fittings which are linked to in my swap thread!!
Thealien is offline
Old 02-25-2010, 09:02 AM   #864
menace121978
good times! thanks again for the help bro. i'll bbq up a few steaks for us next time
I LOVE DRILLING!! dont let him kid ya Gerald, he drilled quit a few also i have to see whats up with my camera... doesnt want to down load onto the computer.
Alien, thanks for the pics man. wierd that there is so many different style dip sticks. i'll either mod this one or put a few threads in the bell housing...
"Dennis the Menace"
Old 02-25-2010, 09:36 AM   #865
menace121978
either the camera or the computers acting up. cant tell it where to put the pics! so i have to search for them... btw, Amy took these so of course im in them more than the truck
"Dennis the Menace"
Old 02-25-2010, 09:38 AM   #866
menace121978
last of them
"Dennis the Menace"
Old 02-25-2010, 09:44 AM   #867
menace121978
today i have to get some weld through primer, seam sealer, and por15 to coat the inside rocker panel just in case. hope the xmember gets here today so i can get that on. and maybe start cleaning and grinding the fire wall down to weld that seam. my goal is to have everything ready on the fire wall and get painted by the 1st. then off to the line x place for the bottom of the cab. then set her on!
"Dennis the Menace"
Old 02-25-2010, 10:11 AM   #868
N2TRUX
Happy to be here
N2TRUX's Avatar
Great progress. Looks like your moving along...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
N2TRUX is offline
Old 02-25-2010, 12:47 PM   #869
STOCKISH
STOCKISH's Avatar
Great work man. Glad to see someone is making progress.
--Josh
STOCKISH is offline
Old 02-25-2010, 12:53 PM   #870
JohnC
JohnC's Avatar
Great progress man. Looking good!
JohnC is offline
Old 02-25-2010, 02:51 PM   #871
Driveway Dreams
I have car A.D.D.
Do you need some advice about good steaks to grill?
Looks like good progress man, now you can make good use of those Lamborfeeti's you have Mr. Flinstone! Get a face shield too, then you don't have to wrinkle up that face of yours when you are grinding.
-Gerald
Old 02-25-2010, 03:16 PM   #872
STOCKISH
STOCKISH's Avatar
I have to admit, I kinda laughed at the wrinkled face too! It just always looks funny when people do that. Again, great work.
--Josh
STOCKISH is offline
Old 02-25-2010, 03:32 PM   #873
Driveway Dreams
I have car A.D.D.
It should be his profile picture...or better yet, in a rotating avatar.
I can see it now TRUCK, WRINKLE FACE, TRUCK, WRINKLE FACE.
-Gerald
Old 02-25-2010, 03:59 PM   #874
draggin86
draggin86's Avatar
Hahaha you guy need to make him that avatar!
Old 02-25-2010, 05:01 PM   #875
silvereagle07
silvereagle07's Avatar
Nice progress Dennis!
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline
Closed Thread
