#851 |
Re: What did you do to your truck today?
Looks great. Don't you love doing things twice.
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
#852 |
Installed license plate lights on the bumper. One on each side of the plate.
#853 |
Doin' it live!
Last night actually, but I got my power steering running. Been driving the thing around without since the motor swap... that sucked. When I did the motor swap, my cousin pulled the power steering pump off and I hadn't made a mental note of how the brackets went together so it took a little while of playing to get it back together. Not sure if it is right but at least it works! Sure made driving in to work this morning a lot more enjoyable. Still have some kinks to work out though... like a tune up.
-Panelrodder 1953 GMC Panel truck - 'Curly' 1961 Chevy Suburban - 'Larry' - Sold 2005 Harley Sportster - 'Shemp' |
#854 |
thought about digging it out from under 3' of snow,then said f**k it went back inside and drank a beer =)
big old burb in primer.lot of work to do. |
#855 |
Stopped by the painter today and approved the primer coat. This is getting so close I can see the light at the end of the tunnel. Or is that a freight train?
http://s1299.photobucket.com/user/jb...23904108567829 |
#856 |
One more. Now comes the seam sealer and a second coat of primer then the paint.
http://s1299.photobucket.com/user/jb...23904108567829 Last edited by jbgroby; 02-16-2010 at 07:18 PM. |
#857 |
Jake I'm glad to see some work on the old girl. Hadn't kept up on your's much since Katrina!
Rob 72 C/10 (under reconstruction)(destruction ? LOL) 48 Willys CJ2A 1952 Super "A" Farmall (Grandfather's) |
#858 |
Senior Enthusiast
Looks beautiful. Now all you have to do is the easy part - putting it all back together!
#859 |
Sunburst C10!!!
man i love the way those gmc dashes look
Gage 1967 C10 Shortbed Stepside |
#860 |
I finished up my truck-arm spacers....
#861 |
Well i put some custom cruiser wagon rear springs in cut those cut all bump stops new brakes up front new shocks up front have some for rears but working on getting the bolts off...may need to cut...new exhaust with a off brand cherry bomb but dont like it gonna try straight pipe out back see what it sounds like...this wasnt done today more like last week but my computer has been down so heres the update sorry pic sucks....
96 Burban Sold 99 Z71 Sold 65 C10 Sold 72 C10 Sold 87 Short Bed Lowered Daily Driver ![]() http://s623.photobucket.com/albums/tt314/sswagon/ http://www.chevygmcofkc.org/forums/forum.php |
#862 | |
Believe it or not, to me that is the easy part. Hell, think about it - It's nothing more than a 1/1 scale model, Right? ![]() Can't be no harder than this. http://news.webshots.com/photo/12085...54402330TJdQix Jake
http://s1299.photobucket.com/user/jb...23904108567829 Last edited by jbgroby; 02-17-2010 at 12:03 PM. |
#863 |
Senior Enthusiast
My relays arrived today, so I plugged them in and completed the headlight relay project. What a difference in light output. Been reading every thread I could find on headlight relays, and how a 10% reduction in voltage to the lamps can mean a 30% reduction in light output. After seeing the improvement, I'm inclined to believe those numbers.
I also made up a jumper harness to keep the low beams on when running the high beams. It simply reroutes power from the headlight switch to the low beam circuit, and the dimmer switch only operates the high beams. The benefit being the low beams operate normally, but do not dim out when running the high beams. I happened to have enough parts from left over projects to build the jumper without spending a dime. Here's a picture of the jumper harness. ![]() |
#864 |
Member of the longbed union.
Hey Mark can you post a setup that you ran for the lights? or link it to your thread if it's in there.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#865 | |
I got my rear bag 'hats' welded up. I just need the right length bolts for some upper 'studs' & I'll have them finished up. Pics are in my build thread.
#866 |
Put it in the shop to install headlight relays and thought jeez why cant it be summer again!
#867 |
Senior Enthusiast
#868 |
![]() Join Date: Aug 2005
bought a SWB bed, gate, and rollpan (may not use the rollpan), for the six fo! one of these weekends I'll take a break from the clowncar and chop that sucka! also have a big window inner panel, glass, seal and SWB side trim ready to go.
#869 |
installed cherry bomb!!!
#870 |
More slicing & dicing..... You need to hang a sign outside of the garage: Mike's Chop Shop.
#871 |
finally a day above freezing,So I took a snow shovel and dug mine out,then went inside and had a beer!!!!!!!!!!!!! Can't wait to move back to CALIF!!!!!!!!!!!!!!!!!
#872 |
i am doing the headlight harness upgrade on my 66 & finishing it today & seen this jumper harness & would like to know more about it...i am running the halogen bulbs & was wondering about the heat from running both high & low at the same time...i like the idea & want to know more about this setup,thanks
![]() Quote:
#873 |
I just spent 2 hours welding up the seam on the front of my hood. I still have to grind it back, and drop off the front inner hood support at the blasters' shop.
Chopzilla |
#874 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=387693 They have some good tech covering this question & other good ones.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-20-2010 at 02:13 PM. |
#875 |
Senior Enthusiast
Actually, here's the link to the MAD Enterprises article:
http://www.madelectrical.com/electri...adlights.shtml Regarding the jumper - since the second (high beam) filament in the low beam lamp is the dimmer of the two, I don't see it pulling all that much additional juice, and it's being powered by the high beam circuit - so it's not like it's doubling up the draw on the low beam circuit. Regardless, this is why I changed out all the wiring to 14 gauge. Long ago I used to run halogen low beam lamps, but they are known to have the shortest bulb life of anything on the market, and I got tired of replacing them. I drive with my headlights on all the time, so I switched back to standard sealed beams which last for decades. When replacing the headlight harness recently, I discovered the dimmer switch connector on the the low beam wire was deformed from heat. I'm assuming this happened back when I was running halogen bulbs on the 18 gauge wiring. With 14 gauge wiring throughout the system, I don't see running both filaments in the low beam bulbs as a problem. |
