Old 12-11-2012, 12:31 AM   #851
thelonerife
thelonerife's Avatar
Re: Chucks SWB Fleetside
Hahaha
http://youtu.be/LMMUYQp_XRA
thelonerife is offline   Reply With Quote
Old 12-11-2012, 12:32 AM   #852
thelonerife
Choncho!
Old 12-11-2012, 12:34 AM   #853
JRANGER
JRANGER's Avatar
lol
JRANGER is offline   Reply With Quote
Old 12-11-2012, 12:36 AM   #854
Rusbuilt
Rusbuilt's Avatar
haha I thought so, I just wanted to say stretchy pants! lol
Rusbuilt is offline   Reply With Quote
Old 12-17-2012, 11:16 PM   #855
thelonerife
small update- I got the dash printed circuit from sduckworth (thanks!)in the mail today. I'm going to use a driver dash in it while I'm getting it running and while its gone to the painter. tomorrow I'll be working on the truck, I'll update it tomorrow night.
Old 12-17-2012, 11:22 PM   #856
JRANGER
JRANGER's Avatar
sweet!!!
Old 12-18-2012, 10:02 AM   #857
cubber
Looking forward to some pics! I'm glad both of your projects are moving along.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 12-18-2012, 10:13 AM   #858
67cheby
67cheby
67cheby's Avatar
looking clean, nice work
67cheby is offline   Reply With Quote
Old 12-18-2012, 11:20 AM   #859
thelonerife
Thanks. Your truck is so nice.
Old 12-18-2012, 08:30 PM   #860
thelonerife
Did a little on Choncho today.
I got my new front rotors on and calipers and new hoses all hooked up. While doing this I noticed there was a lot of loose slag inside of the rotors between the bearing races. I took a drill with a small wire brush on it and cleaned it out. I showed a couple pics of the excess slag that was in there. This would eat bearings I presume.
I also took the steering link off and replaced one outer tie rod end. I painted it also. I will have the guys that do the alignment replace the other outer and both inners.
I got my temporary dash ready to go in. I took the steering column and brake booster off so I can do my firewall.
Old 12-18-2012, 08:33 PM   #861
thelonerife
I also got the rearend sealed up.
Old 12-18-2012, 09:45 PM   #862
Rusbuilt
Rusbuilt's Avatar
Nice Chuck! I can't believe all that crap came out of those rotors!
Old 12-18-2012, 10:10 PM   #863
cubber
I totally agree with BOTH of these statements.
=MATTHEW
Old 12-18-2012, 10:49 PM   #864
thelonerife
Thanks guys.
Yeah me neither. Its been a long time since I've bought some rotors, but I don't remember ever having that stuff on the inside.
Old 12-18-2012, 11:48 PM   #865
sduckworth13
sduckworth13's Avatar
Looking good Chuck, you do some nice solid work. I'm glad I read your thread. Found some useful information on here. I was wondering how I was going to fit my sheet metal patch on fuel filler neck and get it right. I noticed you cut the lip off the back which seems like it made it easier to fit. Now I have the patch, not real sure if I want to take the plunge and spend the extra cash on the tank conversion.
Scott
sduckworth13 is offline   Reply With Quote
Old 12-19-2012, 12:48 AM   #866
thelonerife
Thanks Scott. I know what you mean. I didn't know for sure if I would like it the first time I did one but I do know that I'll do it from now on, on my project trucks. The only problem I've had were the sending units. Some would go out and others had bad floats.
As far as cutting the lip out, this was the first time I did that. And it does make it easier to adjust the metal to weld it together, by using a small flat blade screwdriver to manipulate the metal up or down. Also if you have to dolly it a little it makes it easier.
Old 12-19-2012, 12:53 AM   #867
sduckworth13
I'm heading to harbor freight to pick up a dolly tomorrow. Your welds look perfect too Chuck, are you using a mig welder with gas? My welds don't turn out that nice.
Scott
Old 12-19-2012, 01:09 AM   #868
JRANGER
JRANGER's Avatar
man chuck your really getting at it... Good job man
Old 12-19-2012, 01:12 AM   #869
thelonerife
Yes I am. I got one of those H-F migs (220volt) and argon mix tank. I think they have a hammer and dolly set there.
Old 12-19-2012, 01:13 AM   #870
thelonerife
Thanks Jeff. I hope to be ready for all you guys to help me get it stopping and running.
Old 12-19-2012, 01:13 AM   #871
JRANGER
JRANGER's Avatar
^^---I need that in 110v lol Stupid FLux Welder
Old 12-19-2012, 01:17 AM   #872
sduckworth13
Thanks Chuck, nice work.
Scott
Old 12-19-2012, 07:38 PM   #873
thelonerife
I got a very late start today. I helped the wife with some stuff she had to get ready and take to work. I started sanding the firewall. I thought I was done until I pushed the truck back in and saw a row of factory runs right in the middle. So more sanding. The spots of primer showing through are where there were scratches and runs from the factory. Theres quite a few. 1st one is the before.
I also got the steering link back on and tightened up.
Old 12-19-2012, 08:35 PM   #874
Rusbuilt
Rusbuilt's Avatar
Cant wait to see it painted!
Old 12-19-2012, 11:36 PM   #875
JRANGER
JRANGER's Avatar
good work chuck
