Old 03-15-2011, 04:35 PM   #851
68 TT
Still plays with trucks
68 TT's Avatar
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
Originally Posted by drewskiren View Post
Good plan. After I responded to that message I walked out and looked it over and decided I had room for 4 inch by 6 inch quarter plate on the rear mounts, I may just do one plate like you are thinking. Paint the bar first, mount seat with nuts and bolts and Locktight, then seam sealer the perimeter of the flat stock, finish with undercoating.
I would weld the plate to the floor in a few places so it couldn't shift under load. This way you are not relying upon the single thickness stock floor for resistance to fastener shifting. At least with the welds too you have multiple points of contact to spread out the forces.
If you weld the bolt heads to the plate before you paint it they will stick up through the floor and act like mounting studs that one person can deal with without someone under the truck too.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 03-15-2011, 05:06 PM   #852
maynardtruckin
maynardtruckin's Avatar
The "doors" are stock suburban doors, but really there is only one. 33 inches long. Give me a couple of months and I'll take pictures of the seats installed and measure it for you. Remember also that I am using the 2002 extended cab seat and not the huge crew cab seat available starting in 2003.
I have a friend with a 02 extended cab and its tight for rear leg room. I just know that leg room is very important for the people sitting back there. Last year I saw one built that was done with stock burban doors and no stretch in the back of the cab and there was no leg room and he was using a 89 extended cab rear seat. Will be watching the build to see the finished build.
Chris
67 c10 swb build in progress
70 c10 lwb driver pending parts for drastic overhaul
70 c20 lwb parts truck for above mentioned drastic overhaul
71 k20 lwb building for off road use and towing
maynardtruckin is offline   Reply With Quote
Old 03-15-2011, 05:58 PM   #853
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Well ok - I had it installed 2 days ago and it was fine. I have also ridden in the back of a 2001 from Memphis to Houma La. for Katrina support. It was 7 hours and I chose to ride in the back on the way home too. Maybe an 89 is a tighter fit???. Also my crew cab is longer inside than the 2002 donor vehicle the seats come from.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 03-15-2011, 06:10 PM   #854
drewskiren
drewskiren's Avatar
I'll be needing this this weekend. 1972 Chevrolet truck medium blue.
Drew
Old 03-15-2011, 06:17 PM   #855
67cheby
67cheby
67cheby's Avatar
WHAT.....paint already....HOLY SMOKES, you are cooking man !!
67cheby is offline   Reply With Quote
Old 03-15-2011, 06:56 PM   #856
drewskiren
drewskiren's Avatar
I just went out to measure and my new crewcab is 4 inches longer from the heel area of the front floor to the cab back that the rear seat mounts to. I also measured my seat bolt holes, and without realizing what I had done exactly, I have 1 inch extra legroom in the front and 3 inches extra in the back. Of course I will probably adjust the front seat to fit me, so the rear will end up getting all 4 extra inches.
To clarify - I was comparing my new 1972 Crew to my 2002 parts truck Silverado.
Drew
Old 03-15-2011, 07:54 PM   #857
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
If drew can paint his im thinking you can tooo... Drew looking good and nice color choice..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-15-2011, 08:29 PM   #858
drewskiren
drewskiren's Avatar
Ok, got the brakes all finished up. Time to mount the steering column and see if calculations were correct. Guess what....
Column fits just barely and all is well as long as you don't ever need to put the vehicle in PARK. Argh. There is no more moving the booster up because the fluid cap would rub on the hood, don't want to move the column down because of the factory hole and rubber seal. Soooo, I loped off the shift ear that was making contact and will have to weld a new piece on a little lower to clear.
Tell me something, is there a part missing to hold up my steering column? I found the 1 inch wide strap, but isn't there something else? I can't find it in my parts boxes.
Drew
Old 03-15-2011, 08:33 PM   #859
drewskiren
drewskiren's Avatar
I knew somebody would freak!!!!
Don't panic, I'm only edging in the firewall and interior.
Drew
Old 03-15-2011, 08:35 PM   #860
Pop's C-10
Pop's C-10's Avatar
Nice..i might of missed, but are you running ABS...Not like you need more wires to deal with...lol
Pop's C-10 is offline   Reply With Quote
Old 03-15-2011, 08:36 PM   #861
drewskiren
drewskiren's Avatar
Painting is really just some practice and a little instruction. If you want to come to Memphis, I can show you what I know (not much) - then just practice on some old sheet metal.
Drew
Old 03-15-2011, 08:37 PM   #862
drewskiren
drewskiren's Avatar
Yes - ABS.
Drew
Old 03-15-2011, 10:06 PM   #863
dougminton
dougminton's Avatar
dang you're flying man, if I could do things as fast as you I'd be done,
The TEAL GMC build thread is HERE
1972 GMC SWB
454 oval ports
TH400
fastest 1/4 mile time so far
13.05 @ 104
If you think you have too much horsepower
you obviously have a traction problem !
dougminton is offline   Reply With Quote
Old 03-15-2011, 10:10 PM   #864
VA72C10
VA72C10
VA72C10's Avatar
There is the big rectangular thick piece that reinforces the area but doesn't really hold up the column. There is a piece that bolts to the firewall...can't see if that's on in your picture or not.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 03-15-2011, 11:58 PM   #865
drewskiren
drewskiren's Avatar
I have the big part that the brake pedal hangs from, and a 1 inch wide strap that clamps the column to that. At the firewall I have a football shaped piece that the column goes through with 2 screws to the firewall. My problem is the the column still wiggles. You can actually see the column move at the firewall and if you pull it enough you see daylight at the rubber grommet to column. Is there a clamp outside the firewall?
Drew
Old 03-16-2011, 12:05 AM   #866
drewskiren
drewskiren's Avatar
It's a little tight in here tonight.
I hooked up my previous steering mount old to new conversion and it still works fine, no binding. Man, look how close it is under the booster. You can see the brake fluid cap is also going the be close to the hood. I am figuring about 3 eighths of an inch, I may put a felt hat on it just in case.
Drew
Old 03-16-2011, 12:08 AM   #867
VA72C10
VA72C10
VA72C10's Avatar
yes, there is a bracket that clamps outside the firewall. One bolt on the column and two on the firewall...
Old 03-16-2011, 12:12 AM   #868
drewskiren
drewskiren's Avatar
Anybody have a picture to remind me what I'm looking for?
Drew
Old 03-16-2011, 12:13 AM   #869
VA72C10
VA72C10
VA72C10's Avatar
It's the piece shown with the big arrow B pointing to it (note the three bolts)
Old 03-16-2011, 12:14 AM   #870
silverboy02
You could get a lower profile reservoir for you brakes to free up some clearance.
silverboy02 is offline   Reply With Quote
Old 03-16-2011, 12:14 AM   #871
VA72C10
VA72C10
VA72C10's Avatar
I was working on it
Old 03-16-2011, 12:21 AM   #872
drewskiren
drewskiren's Avatar
Now you tell me!!! Where were you yesterday?
Drew
Old 03-16-2011, 12:27 AM   #873
silverboy02
I was lurking around...haha I probably have one that would work for you. Give me a measurment of the height of yours and the distance between where it plugs in the master and I will check.
Old 03-16-2011, 09:45 AM   #874
drewskiren
drewskiren's Avatar
It's done now, but thanks for the offer...... until I can't shut my hood.
Drew
Old 03-16-2011, 11:23 AM   #875
drewskiren
drewskiren's Avatar
A few more pics from last night showing my reinforcing sleeve and a shot of my seat fully back in relation to my steering wheel. The eyelet end piece is the old trucks mount that connects to the brake pedal arm. It is threaded for adjustment and here I have it turned out about 1 turn.
I went out to my current driver truck and I have the seat adjusted a few inches forward of where this picture is showing. I'm 5-10 so any 6 foot plus guy should fit in here no problem.
Drew
