Closed Thread
Old 06-19-2012, 11:06 PM   #851
mknittle
mknittle's Avatar
Re: What Did You Do With Your Truck Today ?
Originally Posted by Amorget View Post
Do you have a PlasmaCam or something like that?
No, I just use straight edges and come up guides and fixtures.i have a collection of washers with bolts welded to them and My home made circle cutter.for the round stuff.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 06-20-2012, 12:08 AM   #852
DMViergever
Bought a 96 caprice cop car for the motor and tranny. Will probably rebuild both but I got the entire car for 200 bucks.
DMViergever is offline
Old 06-20-2012, 12:09 AM   #853
OrrieG
OrrieG's Avatar
Hit a milestone. Finished up the major body work (except for the gas tank door) and will prime for final block sanding on bumpers, grille and some other small pieces that will be silver. I am sure there will be somethings I need to address when I hang the doors and front fenders, but no more welding, bumping or plastic work.
OrrieG is offline
Old 06-20-2012, 12:09 AM   #854
Daze57
Daze57's Avatar
great price for the cop car - they usually have good strong trannys
Daze57 is offline
Old 06-20-2012, 12:10 AM   #855
Daze57
Daze57's Avatar
congrats orrie
Daze57 is offline
Old 06-20-2012, 01:33 AM   #856
Amorget
Good deal, that is what my engine and transmission came out of, though it was a 91 and we paid a little more for it, but you got a screaming deal. Does it have the LT1 or baby LT1?
Amorget is offline
Old 06-20-2012, 06:40 AM   #857
lowdownstar
big guy
lowdownstar's Avatar
wow talk about high tech!!! that looks cool as hell, i can't wait to see more pics mknittle.
Ray
lowdownstar is offline
Old 06-20-2012, 07:34 AM   #858
DMViergever
Its the 5.7. Since I got it so cheap I will probably rebuild the motor and tranny both. I am hoping to use as many parts as possible from this thing. Now I need to start getting ideas how far back I need to mount it in the S10 frame so I can get the cab and stuff mocked up.
Old 06-20-2012, 09:18 AM   #859
mknittle
mknittle's Avatar
Ray
It really is pretty old tech the autocad is 2002. I use it quite a bit for sketching my parts. Its kind of nice to see what the parts will look like.
The rest is the same way you do things.I spent morethan a few yearsas a prototype machinist so I just am more used to thinking that way.
if you look atmy steering coulmn threat I used simple tools. and got a decant result.
http://67-72chevytrucks.com/vboard/s...d.php?t=474288
Mark
My GMC build.
mknittle is offline
Old 06-20-2012, 09:37 AM   #860
mknittle
mknittle's Avatar
this is one of my fovorite tool that i made. It will cut from 2.5 to however long the 1/4" all thread is.. works great for fan shrouds.
Mark
My GMC build.
mknittle is offline
Old 06-20-2012, 12:02 PM   #861
nacho55
Originally Posted by mknittle View Post
Thanks Ray, It seems like it takes me longer to decide what do next than to do it
I'm the same way, ill staire at something for hours trying to build it when it could have been made already, or purchased..lol I had to just start telling myself to do something, right or wrong just move forward on this thing. I even put a note on my wall at my work bench that says "get to work" I like your cutting jig.. what is that part you used for the plasma tip holder.
nacho55 is offline
Old 06-20-2012, 12:09 PM   #862
nacho55
Originally Posted by npetric View Post
Test fitting the motor....
Npetric
What headers are those I'm running a 5.3 w/ s10 front end also how do they fit.
nacho55 is offline
Old 06-20-2012, 12:19 PM   #863
CountryGirlT
CountryGirlT's Avatar
Talking Re: What Did You Do With Your Truck Today ?
Today I drove around the neighborhood blasting Kenny Chesney in my truck!
CountryGirlT is offline
Old 06-20-2012, 03:04 PM   #864
mknittle
mknittle's Avatar
I made that when i worked in a machine shop.I think it would be pretty easy to make one out of a piece of tubing though.
Mark
My GMC build.
mknittle is offline
Old 06-20-2012, 03:05 PM   #865
mknittle
mknittle's Avatar
Mark
My GMC build.
mknittle is offline
Old 06-20-2012, 03:06 PM   #866
mknittle
mknittle's Avatar
progress for today. the first this is how i shorten up my cutting fixture. I was shooting for just over 3" looks like I am good. Next is how I use a 1/8" spacer to set the distance from the flame to the line I want to follow.The next two are a washer tacked to a bolt for the small radius. This works good for around holes. if there isn't a hole I use a needle nosed vise grips to clamp a washer to the part.
Mark
My GMC build.
mknittle is offline
Old 06-20-2012, 03:20 PM   #867
lowdownstar
big guy
Nice work, it's all those little things that make the most diferents. One cool jig always works wonders.
Ray
Old 06-20-2012, 03:36 PM   #868
mknittle
mknittle's Avatar
and the finished parts after clamping them together and grinding then sanding each to remove burrs.
Mark
My GMC build.
mknittle is offline
Old 06-20-2012, 03:41 PM   #869
mknittle
mknittle's Avatar
Ray
Thanks Ray, I have a lot of fun making things like this. I made that jig to cut tops out of beer kegs for home brew boil pots.
Mark
My GMC build.
mknittle is offline
Old 06-20-2012, 03:46 PM   #870
lowdownstar
big guy
lol !!!!!
Old 06-20-2012, 03:46 PM   #871
mknittle
mknittle's Avatar
Now if I could get my fingers to hit the keys I want
Mark
My GMC build.
mknittle is offline
Old 06-20-2012, 04:28 PM   #872
Amorget
That is a very nice setup! That plasma cutter looks identical to mine.
Amorget is offline
Old 06-20-2012, 05:48 PM   #873
mknittle
mknittle's Avatar
Thanks,
It's a Hypertherm 600. Whenever I make a fixture i save it.
I have just gotten pretty used to setting the thing up over the years
Mark
My GMC build.
mknittle is offline
Old 06-21-2012, 10:51 PM   #874
mknittle
mknittle's Avatar
I cut out the other four parts plus two spares for my lower coil over brackets. now all I have to do is bend them so the shocks fit
Mark
My GMC build.
mknittle is offline
Old 06-21-2012, 11:01 PM   #875
OrrieG
OrrieG's Avatar
cleaned up the garage so I can paint this weekend.
OrrieG is offline
Closed Thread
