Old 10-12-2009, 10:07 PM   #876
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: Daverods project 66
check out my photobucket. http://s581.photobucket.com/albums/ss260/ruffrida2005/
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 10-12-2009, 10:07 PM   #877
daverod
SSN 706
daverod's Avatar
Now I have to build stuff and rember too. Good thing I kept my rear notch maybe I can use it in the front.
daverod is offline   Reply With Quote
Old 10-12-2009, 10:10 PM   #878
daverod
SSN 706
daverod's Avatar
Now that's more like it. All I wanted to know. Whats the diff between the mustang one and the pinto one? Is yours a mustang?
Old 10-12-2009, 10:21 PM   #879
Strodder
Daring to be Different
Strodder's Avatar
Originally Posted by daverod View Post
Started thinking about my front end parts. I want to get everything powder coated. I'm going with 2 1/2" dropped spindles and air bags. My cross member has been pancaked 1 1/2". Do you think I'll need to remove the rubber bumper and its bracket to lay frame. What about the shock mount location? Does this stay in the same location or will this also have to be moved? I'm also thinking about the steering. If I lay frame do I need to go with rack and pinion or can I do it some other way.
U need shorter shocks.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 10-12-2009, 10:22 PM   #880
daverod
SSN 706
daverod's Avatar
Do they go in the same spots? Did I tell you I screwed up and fell asleep and missed out on some more bezels. Sold for like 60 bucks some used ones for 40 somthing. Woke up missed them by 15 min.
Old 10-12-2009, 10:44 PM   #881
Strodder
Strodder's Avatar
It does help if you stay awake.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 10-12-2009, 11:12 PM   #882
bubba327
HOW long until spring??
bubba327's Avatar
What's the update on the transmission? Now that it is out.....Keep me posted-- mine comes out maybe next week if time and weather permits.
Something to add to "This I Know thread"--- "Take the crossmember out and un-bolt the bell housing...."
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 10-12-2009, 11:37 PM   #883
daverod
SSN 706
daverod's Avatar
I did'nt have to remove the cross member. Once I saw I could unbolt the bell housing it came right out. The bolts for the bell housing where on the inside. It like a 2 part bell housing. Unbolt it from the engine, then slid it back enough to get a wrench inside to undo the two bolts on the side. Unbolt the last two transmission bolts and bam it's out. I took it down this afternoon should know tomrorrow.
Old 10-12-2009, 11:44 PM   #884
daverod
SSN 706
daverod's Avatar
Just wait when the time is right, bam! I'll have me some bezels. For cheap I just have to stay awake and relax. And no beer or Rockstar. Damn, it might be awhile. Any idea how to tell a 71-72 front a arm from a 73 a arm. I took my arms off a sub. The guy said it was a 71. I don't have the title or anything so I don't really know? The sway arm was rubber mounted.
Old 10-12-2009, 11:52 PM   #885
ruffrida2005
Mine is a mustang rack, 79-93. I'm not sure what the diffrence between the musgang and pinto. I think the pinto may be a little shorter though.
Paul
Old 10-12-2009, 11:56 PM   #886
ruffrida2005
My understanding is that the 63-87 are all the same, 63-72 use pressed in bushings. Then you know the ball joints are diffrent from 63-70; 71-72; 73-87
Paul
Old 10-13-2009, 09:58 AM   #887
daverod
SSN 706
daverod's Avatar
I was wondering if the arms are the same except for the bushings I wonder why the ball joints are different? I need to get new ball joints. Just want to make sure I get the right ones.
Old 10-13-2009, 10:05 AM   #888
ruffrida2005
balljoints are diffrent because the spindles are diffrent. You know GM has to change something to make more money. It just depends on what spindles you wanna use, if your going 5 lug go look for some 73+ spindles, the other 2 are 6 lug.
Paul
Old 10-13-2009, 10:08 AM   #889
daverod
SSN 706
daverod's Avatar
The guy said mine was a 71 and it has 5 lug. I'm starting to think maybe it was'nt a 71. Anybody know if this is a 71?
Old 10-13-2009, 11:41 AM   #890
bubba327
bubba327's Avatar
71 & 72 were the first year of standard issue disc brakes and are 5 lug. I think that I heard that the 71 and 72 were steel on steel in the upper and lower control shaft threaded ends and that 73 and up were rubber mounted in the shaft ends. Does yours have grease zerks in the ends??? if so, it is probably is 71/72,
Bubba
Old 10-13-2009, 02:33 PM   #891
daverod
SSN 706
daverod's Avatar
I don't get it now I can't post pictures?
Old 10-13-2009, 03:03 PM   #892
watahyahknow
watahyahknow's Avatar
dunno why , do you use photobucket.com? you should at least be able to post the links to the pics
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 10-13-2009, 04:03 PM   #893
Strodder
Strodder's Avatar
I've been using smugmug.com for years. Mention my name if you use it. I get a discount for the year.
Check out my Smugmug.
www.belair.smugmug.com
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 10-13-2009, 04:16 PM   #894
watahyahknow
it might be site related or you just have to much pics in youre account
photobucket is free you could open one just to see if that helps you posting the pics here
Old 10-13-2009, 05:10 PM   #895
daverod
SSN 706
daverod's Avatar
I can't believe they limit the pictures. Look at Allans site. I'm pissed. It just not the same unless I get to post pictures.
Old 10-13-2009, 05:22 PM   #896
ruffrida2005
Man i keep forgetting that 71-72 are 5 lug, I need to drill that in my brain. But if your going to go 5 lug go with the 73-87 since it doesn't use the crazy bushings.
Paul
Old 10-13-2009, 07:21 PM   #897
daverod
SSN 706
daverod's Avatar
to late.
Old 10-13-2009, 08:30 PM   #898
joe231
joe231's Avatar
I always upload pics from my computer and have never had problems with any limit... Are you sure your pics aren't too big?
CHEVY ONLY
Old 10-13-2009, 09:01 PM   #899
ol Curt
Junior Member
ol Curt's Avatar
Or that you didn't fall asleep while posting them?
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 10-13-2009, 09:36 PM   #900
joe231
joe231's Avatar
CHEVY ONLY
