#876 |
Re: What did you do to your truck today?
My mistake. I was reading through all their tech info & thought I reached it from a link on that thread.
#877 |
![]() Join Date: Aug 2009
went outside and uncovered my 62...looking at it wondering why the hell I took apart a good running truck without a job or funds to complete the work
#878 |
Junior Member
Put my Hurst floor shifter in.Got most of it done, except for the trim. I broke two bits drilling thru the carpet before I quit for the day!
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! ![]() |
#879 |
Senior Enthusiast
We've had such a mild winter I pulled the snow tires and put the mags and street tires back on.
#880 | |
I am blaming you Mark for the 7" of snow we got last night! ![]() Last edited by lakeroadster; 02-21-2010 at 08:56 AM. |
#881 |
Senior Enthusiast
Oops - sorry I should have thought this through better - it's not the first time I've been in trouble for causing the weather. Back when my truck was shiny black, if I washed it the next day it would always rain! Then people would be mad at me for ruining their picnic plans!!
#882 |
i drove my daily driver for the first time in four weeks
![]() i seperated my right shoulder 4 weeks ago in wrestling practice so i couldnt shift my 5 speed until now ![]() ![]() |
#883 |
#16876
It took longer than I thought it would but if it don't leak it's done. I got lucky and did not have to loosen the motor mounts and jack the engine. The pan dropped out cleanly. I used Permatex Right Stuff to place the gaskets and seals on the pan. While it set up I cleaned the block. Had to go to Schucks for a couple items including my missing gasket scraper. I had to improvise because they did not sell scrapers, although they had a hell of a deal on mini bikes, chinese generators and ****ty chrome dress up parts. With a little care the pan went back up without goofing up the gaskets or seals. I opted to put two small bolts in the center on each side first then the rest. I had big trouble getting the four large bolts started on either side of the rubber seals front and back. I finally realized that the seals were not compressed so I tightened a couple center bolts. After using a screwdriver to align the bolt holes I got the last four in. That only took and hour. As per the directions of the sealant I snugged the bolts and am waiting the suggested one hour before I tighten the bolts the rest of the way. There was a lot of sludge in the pan. I ran a magnet around and came out with a split washer on the end. I did not find a bolt though. It did not appear anything was missing from my view underneath. I suppose it could have been dropped through an oil port from above? I guess I'll just forget I saw that? I have a vague memory of dropping and never finding a washer from the timing chain cover. I think I know where it went. It was chrome and did not appear to have been in there very long. The culprit of my leak was the front seal. You can see the twist in it. I'm going to let the sealant cure for 24 hours which means I won't be putting oil back in it today. Next thing will be to bend new brake lines. My '63 is an outdoor project so its all weather permiting.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
#884 |
Installed my Porterbuilt suspension, airbags, front steering components and gas tank.
#885 |
Member of the longbed union.
I cleaned out the garage and cut off the saddles on the diff to mock of my wishbone set up. Sorry dont have pics
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#886 |
I cleaned out the garage so I could find my truck project!
GMCMG 1964 GMC 1/2 ton LWB project - 1982 GMC 6.2 diesel engine/suspension donor - 1966 Chevy 3/4 ton frame/doors/fenders donor - tons of parts - cause you can't build a truck without 4 of everything! 2001 3/4HD Duramax Diesel extended cab lwb4x4 1984 Chevy C30 6.2 diesel lift truck (project) 1962 GMC w/5 lugs, 350/350 auto (was for parts, but couldn't bring myself to do it!) glascock.m@hotmail.com |
#887 |
Junior Member
Finished up my shifter. Had the rods on the wrong arms. I had to get my wife out to run it thru the gears while I watched from below. She couldn't figure out why I kept calling her Linda (AKA Vaughn)!
![]() ![]() She didn't find the humor when I explained who Linda Vaughn was/is!
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! ![]() Last edited by ol Curt; 02-21-2010 at 08:45 PM. |
#888 |
Senior Enthusiast
Ah yes, Miss Golden Shifter!
#889 |
![]() Join Date: Aug 2008
Added some trim rings-
#890 |
How are you keeping those center caps on?
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
#891 |
3 self tapping screws through the original rally wheel holes into the center cap. Enough room to get to the original lug nuts with an impact as well.
#892 |
![]() Join Date: Sep 2006
If all goes by plan. This truck will be cut up into manageable pieces and the good stuff is going to be used on my 66. You know, front disc set up, maybe the rear end, and whatever else I can use. OH yeah. And a big bucket of nuts and bolts.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#893 |
'67 Chevy C-50
I looked at mine for a brief second as I pulled my daily driver into the garage next to it. Haha. Its too cold here in Iowa right now and I dont have the privilege of a heated garage.
Bad Riv '67 C50 Flatbed Dump '98 Z71 Ext. Cab |
#894 |
I like cheap. PM sent.
#895 |
Shaved the seams on my dash to pillars.
1960 Chevy Short Wide Truck(being restored) 1962 Pontiac Parisienne Bagged 1996 Chevy Caprice 9c1 ![]() |
#896 |
DiablosWeldingFabrication
way better look! today i changed my valve covers and air cleaner..what do you guys think? The before and after pic..
#897 |
picked me a up a 64 short stepper project 350 3 speed on the floor....lots of work here
![]() ![]() ![]() ![]() ![]() Last edited by thunder71; 02-25-2010 at 08:52 PM. |
#898 |
#899 |
Justified!
Cut the front springs on my truck, put on my new rims and tires, and then found out my alternator was bad..........
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny ![]() |
#900 |
[QUOTE=thunder71;3825197]picked me a up a 64 short stepper project 350 3 speed on the floor....lots of work here
![]() Looks like a good starting point |
