09-22-2010, 07:25 PM | #876 |
Redefining LowBudget
Re: What did you do to your truck today!
Wahed it..well after I pulled the trany pan put in a filter kit changed the modulator on the trans and painted the pan...swapped the 3 core rad for the 4 after I added a return for the heater hose...plumbed up the heater ....and then I put a set of points and wires in the Cady motor twisted the key to make sure it was still runnig well...and hell yea it shifts like a million $$$ and got rid of that small stumble on the bottom...stay tuned saturday is speed runs @ the air port..wish I had a bottle kit for it..
I think its about as good as its going to get...but dont we all want a bit more!!! |
09-22-2010, 08:54 PM | #877 |
Removed Front Bumper Sent To Chromer and the Rear One i Got From DPassmore NOS Parts Are So Sweet. Put AXtra Bumper i had on And lost one Bumper Bolt....
4 Lights Are Better Then 2 |
09-22-2010, 09:56 PM | #878 |
ithought i might give you some insight on oreilly parts,I run a auto repair shop in Arlington,Tx and i buy about 10,000.00 per mounth in parts and i have less warranty issues with them than my other suppliers but some times it happens,however i aways buy new not reman.hope that gives you some insight.
09-22-2010, 10:13 PM | #879 |
What?
Chased an electrical bug, and still haven't found it.
Came to terms that the T case needs to be completely resealed. $$$$$
Chris 1968 K20 Suburban 1972 K10 LWB PU |
09-22-2010, 10:54 PM | #880 |
well i installed my newly aqquired 67 bed
09-22-2010, 11:03 PM | #881 |
Finished installing my large hump. Hush Matted everything an started to reinstall stuff.
Looks like new. Very happy. |
09-22-2010, 11:07 PM | #882 |
Put some eastwood tank tone on my fuel tank.
1977 Chevy C10 RWD long bed |
09-23-2010, 02:06 AM | #883 |
Got my cam in and put my heads on and torqued everything...and sanded the chrome two piece timing cover to paint it....
09-23-2010, 03:39 AM | #884 |
Hmmm let me see installed a tach then promptly blew the freaking motor that is only about 200 miles old, blew chunks of the piston on #5 cylinder right out the side of the block. Hmmmmm I think a bad day overall.
09-23-2010, 08:45 AM | #885 |
BLACK SATIN
Put on the diamond plate bed & tail caps & the newer style tail light bezels
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new 67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering 85 C10 Silverado- 305ci |
09-23-2010, 10:34 AM | #886 |
RAT1968 '68 Cab/'71 Parts
Ohhhhh! Sorry. That's serious.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
09-23-2010, 10:51 AM | #887 |
I had a good day,I pulled the gas tank,cleaned it, sealed it,got it ready to put it back in.I made a new transmission crossmember so my headers can tuck up nice and tight in the framerails and last I re-built my edelbrock carb.Now just have to put it all back together.
big old burb in primer.lot of work to do. |
09-24-2010, 10:45 PM | #888 |
Got the 69 Camaro tank fabrication done and installed. I will bend the fuel lines and install them tomorrow. I like the way it came out.
[IMG][/IMG] [IMG][/IMG]
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
09-24-2010, 11:05 PM | #889 |
Took the bracket for the steady bearing off the crossmember. The PO put a one piece shaft on but left the bracket, when I lowered it down it hit the drive shaft when I hit bumps. What a B*$*# of a job grinding the rivets off while lying under the truck.
09-24-2010, 11:10 PM | #890 |
Grandpa in the rustmobile...
67slider, that tank is AWESOME! More pictures please. How many gallons..is that the original filler area? Where ya get it at, how much? Will the behind the plate filler work?...
Drove to get gas for the first time in months! Hopefully gonna get it tuned morrow maybe?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
09-25-2010, 02:01 AM | #891 |
drove it to my shop, ran fantastic! love our trucks! cheers, Pat
09-25-2010, 02:07 AM | #892 |
What do you think about a 2/piece drive shaft while using a 4/6 drop? All top notch stuff was used in the drop, including shock re-locator kit from ECE, if that makes any difference.
09-25-2010, 08:38 AM | #893 | |
Hopefully be done today!
09-25-2010, 11:00 AM | #894 |
What do you think about a 2/piece drive shaft while using a 4/6 drop? All top notch stuff was used in the drop, including shock re-locator kit from ECE, if that makes any difference.[/QUOTE]
I would go with a 1 piece, especially if your going to be putting more HP under the hood. Looks better also, in my opinion. |
09-25-2010, 02:26 PM | #895 |
Pulled a motor out of the truck and pushed it out of the way outside. Almost done with a motor for a car. Need to finish a car first. After I'll decide what to do with a truck.
09-25-2010, 06:22 PM | #896 |
It's 107 deg right now,the only thing I did was sift some sand getting it ready for my sandblaster.does drinking some beers sitting in the truck count as doing something?
09-25-2010, 06:25 PM | #897 |
I was thinking of putting in a one piece,do they have them or is it a custom made one?
09-25-2010, 06:35 PM | #898 |
Took my truck for a flogging!!!
yep local car club did 1/4 mile speed runs at the airport Back to back 91 mph with over 150' of burn out......1 wheelie squilies sucks even with a 16.5 inch wire M/T
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
09-25-2010, 09:09 PM | #899 |
PROJECT 7DEUCE
I did a big fat smokey burn out in the garage tried to take pics but they sucked.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
09-25-2010, 09:14 PM | #900 |
new dash and will put column in tomorrow
