Old 01-02-2013, 04:31 PM   #876
Strodder
Daring to be Different
Strodder's Avatar
Re: Daverods 52
Looks like they are adjustable push rods for the power brake unit?
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 01-02-2013, 04:59 PM   #877
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
So do I need them? I hooked everything up I didnt see anywhere to put them?
daverod is offline   Reply With Quote
Old 01-02-2013, 05:13 PM   #878
99 to Life
99 to Life's Avatar
Re: Daverods 52
you sure those are for your brakes? Looks like the needles for a carb.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-02-2013, 05:18 PM   #879
99 to Life
99 to Life's Avatar
Re: Daverods 52
oh and what brake set up you have? You gotta bench bleed the MC before you hook the lines up. Then bleed brakes from Rear to front and cylinder farthest away from MC. I had a problem getting fluid to my cylinders and it was killing me, rebled the MC and that stuff came gushing out. Once you bench bleed they say hook it up and bleed system asap I waited months and that was probably my problem.
Old 01-02-2013, 07:19 PM   #880
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
bench bleed? Its in so should I just disconnect the lines then bledd it and hook the lines up again? The parts came with the MC just no instructions. maybe just left over parts?
Old 01-02-2013, 08:37 PM   #881
99 to Life
99 to Life's Avatar
Re: Daverods 52
well, do you have a pic of your MC? if you have lines that run off your MC into a proportioning valve you can use them and leave the MC hooked up to the truck. IF you have those (see pic), take some rubber hose and put it on the ends of these little brake lines, put both lines in the MC reservoir so they are fully submerged in fluid. Then have someone push your pedal while your lines are submerged, pump until you see no more bubbles. Or if you take it off, just take big screwdriver or something and push the plunger. Same concept either way. this will solve your problem most likely. Your proportioning valve most likely won't cause you any issues, just bleed the MC then hook up all your lines and you should be good to go with bleeding all your lines.
Old 01-03-2013, 09:03 AM   #882
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
last night I tried just unhooking the lines from the mc and pumping the brakes. very little came out. I did find a couple leaks so there is fluid getting in the lines. My p valve is only on my rearline and its under the truck.
Old 01-03-2013, 09:53 AM   #883
99 to Life
99 to Life's Avatar
Re: Daverods 52
dave, well you can still have fluid in your lines when your MC needs re bled. So if you pumped it and not much came out, there is your main problem. Did you flair any of the lines on the truck? If you have leaks after all that, could be your flairs. Your valve in the back lines could be a residual valve which keeps a little bit of pressure on the back breaks since you have drum breaks. I'd give that MC a good bleeding and hook it back up, key note, don't ever let the fluid run too low in the MC when bleeding or you'll have to bench bleed the MC again and re bleed the whole system.
Old 01-03-2013, 10:06 AM   #884
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
I thought more fluid should come out. All my lines are store bought. Disks in the back with a p valve on that line. I guess Ill just hook up some short lines out of the mc put some hoses on those and run them back into the top of the mc. Then pump the air out and hook everything back up?
Old 01-03-2013, 10:13 AM   #885
99 to Life
99 to Life's Avatar
Re: Daverods 52
yeah you got it, you'll have brakes in no time if you do that.
Old 01-03-2013, 10:23 AM   #886
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
-14 brr good day to turn on the heat and work on brakes. Surprising how much heat you can get just by running the engine for awhile.
Old 01-03-2013, 10:54 AM   #887
Strodder
Strodder's Avatar
Re: Daverods 52
Good thing you have those exhaust hoses installed.
One tip with the master cylinder is make sure there is a little free play in the brake pedal. No play or too tight can affect bleeding by not letting the master cylinder piston to return all the way. That's why that rod is adjustable. Just a tip incase you didn't know that.
STAY WARM MY FRIEND!!
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 01-03-2013, 11:19 AM   #888
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Thanks .You do know I dont know chit. Your help is the only reason I made it this far.
Old 01-03-2013, 11:21 AM   #889
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
You dont think that piston looking thing is spost to go inside the mc anywhere?
Old 01-03-2013, 11:32 AM   #890
99 to Life
99 to Life's Avatar
Re: Daverods 52
strodder, good point, maybe thats why they say bench bleed it first, that way your definitely bleeding it without other variables. Daverod, either way you do it you should see lots of bubbles, bleed until you don't see any bubbles and you should be good to go. this weather blows, had nothing but rain rain rain, begged for some snow and got too much snow and have to shovel everywhere I go. not to mention the cold will totally kill your work buzz.
Old 01-03-2013, 11:55 AM   #891
Strodder
Strodder's Avatar
Re: Daverods 52
Is this what your talking about?
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 01-03-2013, 11:57 AM   #892
Strodder
Strodder's Avatar
Re: Daverods 52
This is from CPP
Check Booster Pushrod Adjustment
The pushrod that actuates the master cylinder must be properly adjusted. Ideally there should be only slight clearance between the booster pushrod and the master cylinder pushrod. Interference will preload the master cylinder. When the system is preloaded, it builds pressure each time the pedal is pressed. Since the master cylinder is not allowed to fully release the pressure from the previous stroke, the system will eventually lock the wheels. Too much clearance will cause excessive freeplay in the pedal. In almost every case, if you bought your booster and master cylinder from us, we pre-adjust the booster pushrod and master cylinder for you so this is not a problem.
To make 100% certain of a properly adjusted booster pushrod for your master, we offer a master cylinder depth gauge (PN: CP2003) to determine correct pushrod length. The following illustration demonstrates the proper usage of this tool. First measure the length that the booster pushrod extends past the face of the booster with the "head" of the pin. on the tool. Then measure the depth of the master cylinder piston with the other end of the pin on the tool. If the pin hits or there is too much space on step two, then adjustment is necessary.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 01-03-2013, 12:00 PM   #893
Strodder
Strodder's Avatar
Re: Daverods 52
Here's a link for more troubleshooting.
http://www.classicperform.com/TechBo...just_tool1.gif
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 01-03-2013, 01:27 PM   #894
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
That's the piece. It came put together. I bet I was spose to take it apart and put that part in?
Old 01-03-2013, 01:46 PM   #895
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Works a lot better when you put the right parts in it.
Old 01-03-2013, 01:56 PM   #896
99 to Life
99 to Life's Avatar
Re: Daverods 52
learn something new everyday, didn't know they made a tool for this. great post
Old 01-03-2013, 02:45 PM   #897
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
spose=suppost Did want Strodder thinking that was the way you spelt it. Thanks Guys I think I'm on my way to haven some brakes. I'll wait till the wife gets home then I'll have her bleed them.
Old 01-03-2013, 03:30 PM   #898
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Pumping some juice. One down 3 to go. and some goats.
Old 01-03-2013, 03:36 PM   #899
Strodder
Strodder's Avatar
Re: Daverods 52
Have your wife test drive it too...
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 01-03-2013, 03:39 PM   #900
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
We all went for a drive already. The dogs been on a few high speed runs.
