04-02-2021, 08:34 PM | #876 |
I'm trying....
Re: 67 GMC super custom build
That looks good.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
04-05-2021, 02:34 PM | #877 |
After pulling the cowl off and on a few times the screws that go into the sheet metal always stretch the metal out and they became hard to tighten down . Here is the fix. Keeps the cowl and hood aligned better too when it's all in good condition.
04-05-2021, 02:38 PM | #878 |
That is a great idea. Do you think that these would work as well?
04-05-2021, 03:00 PM | #879 |
Yes you could but won't use them. Aluminum on metal I don't like and I'f you strip it you have to drill it out to replace. If you strip the clip you simply replace it.
04-05-2021, 03:02 PM | #880 |
Yeah that is a good point. I like that idea
04-05-2021, 07:17 PM | #881 |
I also cut the hole into the cowl for the cold air piece just like the factory did it. First pics are from the truck that this set up came off of factory.
04-05-2021, 08:57 PM | #882 |
That's is cool. I have never seen that option. Have you got a picture of it all together .
Bret Here's a link to my build http://67-72chevytrucks.com/vboard/s...d.php?t=577889 |
04-05-2021, 10:43 PM | #883 |
Here's what it looks like. This is mocked up on my truck. The hoses are not original. The air cleaner is not correct I this photo. The bottom one has it In it
04-07-2021, 09:58 AM | #884 |
That is a sweet setup, it may be the answer for my TPI set up, what is it from, I will have start looking for one
Ps, I always follow your thread, just don't post up Great build
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
04-07-2021, 12:53 PM | #885 |
The air cleaner setup is a option from 63 to 68 possibly 69 gm trucks. Rpo K46. Was probably mostly found on larger trucks but was available on all of them except tilt cab I believe
04-07-2021, 07:45 PM | #886 |
I'm trying....
Rod...c'mon....you are killing me. That is ridiculous AND AWESOME. Where are you coming up with this stuff?!! I keep thinking you have got to be done with mods...but nope. BAM!! Hit em again.
04-07-2021, 08:56 PM | #887 |
I'm all out of mods now. Cab goes for metal work in May so that is the beginning of the end. Then assembly!
04-09-2021, 06:01 PM | #888 |
I bought these clips from 60s car and routed my washer hose inside the cowl. They mount with the screws that mount the wire gutter so you won't notice this too much. Also my washer pump is now engine bay mounted so the hose will travel under the fender lip and go into the cowl on the lower right side.
04-19-2021, 01:46 PM | #889 |
These are available in steel. I have a hand tool and a pneumatic tool for installing them.
Saskatoon, Saskatchewan Canada |
04-21-2021, 09:29 PM | #890 |
Those nut rivets are awesome. I’ve used a few on my truck and several on the Jeep.
I have the Cornwell tool for install. It works well, you can use a drill or a hex driver.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
06-29-2021, 12:58 PM | #891 |
Well I decided that I didn't really like the oak all that much. It's very common and it wasn't the finished look I was looking for. So today I got my new wood. Curly maple. A little more design to it. So it is still raw. I am going to attempt on the scraps I have to stain it charcoal grey like the picture below. Should pop nice with the stainless straps.
06-30-2021, 09:53 AM | #892 | |
John 3:16 - Saved me... God Bless |
08-13-2021, 01:31 AM | #893 |
I had jason do my curly maple boards and it was nice cause he Is local to me and saved some shipping . We had a mix up on the boards that the frame bolts go thru and he milled the holes quite a bit larger than they are supposed to be...... but he remade those 2 boards for me with no fuss and was great to deal with so if your in need of bed wood in the north this guy is a good resource to look at. https://www.hindsightbedwood.ca/
08-13-2021, 01:43 AM | #894 |
Very nice! Can't wait to see the wood finished.
09-09-2021, 06:36 PM | #895 |
My cab repair started today! Hope I have a better experience this time from the last time. I did my homework this time and waited in a long line of ppl who all recommended him so I feel much better about this time. He says in a couple week he should have it completed and then it will get sealed. I'm so excited. I'll post pics of it if I can get him to send them to me.
09-09-2021, 06:37 PM | #896 | |
09-09-2021, 06:39 PM | #897 |
I got Todd from crusin metal to do it.
09-09-2021, 06:41 PM | #898 |
Is that out of province?
09-09-2021, 06:45 PM | #899 |
No. He used to be in warman but He built a shop on his acerage between Martensville and saskatoon. He only does vintage vehicles. Lots of the vehicles at the draggons he Has done. Threefourty-six in warman will be painting it.
09-09-2021, 06:47 PM | #900 |
Awesome. Sounds like a way better deal than the last go round
