01-04-2016, 06:10 PM | #876 | |
Re: 1976 Square "Simple Green"
That made me think today I was under the truck and my 5 yr old said. Daddy we got a problem your tires are dirty lmao. I said it's ok he said daddy we have a major problem I see rust on the frame daddy. I said that's not rust that's dirt. He gets up walks off and is digging in my tool box I said what are you doing he said getting some sandpaper and paint we got to fix that lmao. |
01-04-2016, 06:19 PM | #877 |
Unlike diceman50 I just ran a ground strap from the mounting stud to the valve cover bolt.
Also I forgot I removed a ground from the firewall to the valve cover that was original to the truck. I used that hole for the clamp that hold my return fuel line. So I added it back like it was originally just moved it up and over a little. |
01-04-2016, 06:22 PM | #878 |
Ray here.
Air control solenoid on back of body their is the spring loaded shaft. STD one I can move in and out by hand... my mean nothing........ find out in time.. Ray. |
01-04-2016, 07:05 PM | #879 |
01-04-2016, 07:09 PM | #880 |
Email from Ken.
Rodney, When you open the throttles it lets in air which leans out the mixture. It seems to me that you need to take some fuel out at this temp. Im going to give you over to Jeremy who is the Super go to for this!. Try pulling some fuel out at cranking temp and see if it works. You may just need some more air. Also Im sure that you have the throttles set correct but maybe just a crack of throttle blade opening may help as well with a little less fuel. I feel like you just need a bit more air and a little less fuel from what you are describing. With no data it's a blind guess but give it a try and see if Jeremy can add something to this. He is the man and has tuned cold start on every corner of this earth! Please copy him on all of the tech calls or go direct to him, he is the best you will find and can make changes to code if need be. Im sure its just adjustment. Thanks and give it a try |
01-04-2016, 07:13 PM | #881 |
But Found Her 25yrs Later!
Yeah, I got replies to both of my emails today.
They're back in the office catching up on emails.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
01-04-2016, 08:21 PM | #882 | |
71 C10: Crush10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=650510 |
01-04-2016, 08:31 PM | #883 | |
I just think it is odd that Ray and I have the same issue with the adders. |
01-04-2016, 08:39 PM | #884 | |
Let us know if pulling fuel out works...thx for your continued efforts...
01-04-2016, 10:55 PM | #885 | |
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
01-05-2016, 08:55 AM | #886 |
Ray here.
Its early and a bit cold 3.5 outside...38 were the car is stored....and still dark... SO you ask how did it GO? The motor tried to start but without rolling on the throttle it wasn't going to happen! The battery is two days old with a over night charge....so that's out... When it did run it was like having a sticking float or a fully closed chock blade.. The RPMs did not pick up and the room is so full of fumes I had to leave.... You get the idea. So at this time am going to walk away for a while.. After last nights Fitech tech moment (controller) Am taking some cool down time. Ray.. |
01-05-2016, 09:15 AM | #887 |
Ray Back..
There was a gentleman on a chevelle forum with the same problem.. Going to see if I can find that and see how he made out.. Ray. |
01-05-2016, 09:25 AM | #888 | |
01-05-2016, 09:27 AM | #889 |
01-05-2016, 09:35 AM | #890 |
01-05-2016, 12:15 PM | #891 |
Ray here.
I have a hard time giving up.... This thing should self learn but maybe its a slow learner? NOS can do that. On that note am going to start moving numbers around... Nothing to lose.. This is the car and where am working on it...I have a 40-40 shop and a 40-60 show room plus a 26-30 at home with heat and this is were am working on it. Someone slap me... Ray. |
01-05-2016, 12:18 PM | #892 |
You can thank me later lol. |
01-05-2016, 01:08 PM | #893 | |
Yup, sounds about right.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
01-05-2016, 01:10 PM | #894 |
The reason I'm not doing my FiTech until spring isn't really because I'm waiting for GP to to get his up and running all the way first. It's because I can't fit my Jeep in the garage (height and to much **** in the garage) and I would have to be outside in the elements to do anything to it. Today it's a high of 29, brrr
Be happy you got some cover. |
01-05-2016, 01:13 PM | #895 |
Ray here.
Going to thank you now in case I die of carbon monoxide poisoning. Ray.. |
01-05-2016, 02:47 PM | #896 |
01-05-2016, 04:07 PM | #897 |
Ray here.
I do. I have.... Manual changing setting has not changed things much. I can swap back to the std unit and all this would be over but that's not what I paid for...Something's wrong. Calling Tech has been a bit stressful...I have not called them on this yet... I think its TIME...I have had no response on my e-mails.... Have they mailed you back anything that my be helpful???? Hope I don't seam pissy This really is not My tread so unless I find out something useful am going to sit back for a time... Ray. Last edited by ray1970; 01-05-2016 at 04:25 PM. |
01-05-2016, 04:11 PM | #898 | |
01-05-2016, 06:13 PM | #899 | |
I think he said you need to lean out some fuel.
01-05-2016, 06:32 PM | #900 |
Ray here.
I was going just run and hide from all of this mostly from frustration and the fact I have more posts in the last week than you and this tread is not about me....On the flip side trying to help someone can help me in the end.. YOUR MY ONLY FREIND This is were I pass out and hit the floor..... SO what am I doing now? I have one that work just fine and one not so much! Going to make all the settings from the bad one the same as the good one. From my first look they are a lot different... Let you know how it works.. Ray. |
