#876 |
Re: A 15 year old's project. Rusty 62 stepside
Your truck is coming along great! Before long you will have it done and driving! Irefully like that you are doing it yourself.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
#877 |
Post Whore
![]() Join Date: Mar 2013
Looking good dude!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#878 |
![]() ![]() Join Date: Jul 2002
#879 |
Looking great!!! wish my project was moving like yours is... mine will be on hold for a little as i got a wedding to pay for now.
#880 | |
![]() Thanks tj, glad to see you getting back to two tone now that crustine is back on the road. Thanks bill ![]() Thanks man, I'm really trying to make progress but it can be hard with school and work, and of course I know what it's like to be on a tight budget. Keep on plugging away at it and you'll be done eventually
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
#881 |
last night I made a template for the booster and clutch master and brought it in to shop class today to make it. I used 10 guage cut on the plasma cutter and cleaned it up with the grinder. This is uses the exact same dimensions as captainfab's bracket except it doesn't push it outwards as I need as much room as possible to clear the oilbath aircleaner. I still will need to drill the holes in the firewall for the booster but the hole point in this bracket is to reinforce the area where the clutch master goes since it is only 18 gauge and a lot of pressure will be on it while pushing in the clutch
#882 |
Here is both the brake booster and clutch master mocked up on the bracket
#883 |
Another
#884 |
Post Whore
Nice!
#885 |
HI Nik I just got caught up on your progress.Looking good. Keep up the good work
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
#886 |
![]() ![]() Join Date: Oct 2011
Very nice!
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" ![]() Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
#887 |
im a 16 y/0 also restoring a truck,
1967 GMC C25 305 V6 1969 K20 CST 1994 k1500, Oldredz71(ext shorty 4x4 6 in lift) 1998 S10ZR2 2001 Silverado 2500hd 8.1L 2003 Silverado 2500hd Crew cab |
#888 | |
Thanks tj
Thanks Craig Greetings, always good to see more young guys
#889 |
So today after school I got the four holes drilled in the firewall for the booster, they were not a piece of cake but not terrible either. The top two holes had multiple layers to go through which was pretty easy but the bottom two holes were a bit more trouble, once I got through the first later the drill bit hit the second layer which was on an angle and the bit kept on wanting to jam up but with some patience I was able to get through just fine. Here is the bracket mocked up on the firewall.
#890 |
I also have some more news, this project just keeps on snowballing. First it was "if I'm going to switch the x member then I might as well take the engine out" then "if the engines out I might as well clean it up and paint it" and then "while I'm at it I might as well do power steering, power brakes" and so on. Well I've done it again, I decided that while the engine is out I might as well paint the firewall since I don't want to take it this far apart in the future. So I have just put in an order for 503 glenwood green with one of my friends that is a painter so he can get very good paint for very cheap. I'm hoping to have the firewall in paint and the engine back in before it gets too cold
#891 | |
![]() Join Date: Jul 2014
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827 62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583 |
#892 |
Oh yeah, that list.....since I am this far why don't I also do......
#893 |
Post Whore
Heck man, that's what my 66 was supposed to be...and look what happened.
#894 | |
Oh yeah it should be
Yep lol, yours has gone from a daily driver build to a frame off restoration. seems like all projects go that way
#895 |
Got the booster and bracket fitted up against the firewall, I had to open up the hole for the pushrod a bit so the rubber boot would fit. Now all that needs to be done is to drill the holes for the clutch master cylinder.
#896 |
02
#897 |
03
#898 |
Looks good Nik! Nice progress
#899 |
#900 |
![]() Join Date: Jul 2015
Very nice! You are doing an amazing job.
I bought my first truck ('72 c10 swb) when I was 16 years old. drove it for a few years and then started striping it down but with minimal tools and money I did not get past that point, so now I'm 38 and still have the truck in pieces. I bought a '62 GMC roughly twelve years ago and drove it most of that time, now I have it ripped down as well, yes two trucks in pieces. Every time I see your posts I kick myself in the butt for not working on my truck more. I'm not letting that happen to the GMC! Thanks for all the motivation, looking forward to seeing you complete your truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=675881 1972 C-10 SWB 1962 3/4 ton LWB 2011 GMC Sierra LML Z71 crewcab shortbed |
