01-30-2015, 10:21 PM | #901 |
Re: How about some pics of "4x4" Blazers, Jimmy's & Burbs?
68 Crew Cab Too many trucks... |
02-01-2015, 12:29 AM | #902 |
I drug this 84 home a while back.
The motor is shot and I don't have a clear title for it. It's in real good shape otherwise so I'm not sure what I'm going to do with it. |
02-02-2015, 01:52 AM | #903 |
Windy Corner of a Dirty Street
That is a clean K5 STREET BLAZIN! Good bones to start some kind of project. Title work shouldn’t be too big of an issue to work out. 83’/’84 Chevrolet grills are my favorite of all the squares.
Somehow I missed this thread. Might as well throw the Polar Bear Burb in the mix. How he looked when I brought her home in Oct 2011 While giving the interior a major cleaning. Factory stick shift truck! How she looks now NV4500 swapped in This is going in to replace the wheezy TBI 350 in a few weeks. Updates will be HERE
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
03-03-2015, 09:05 PM | #904 |
This is my wife's 1987 Jimmy. All original paint top and bottom. No rust anywhere! 35" BFG KM2
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
03-09-2015, 07:25 PM | #905 |
These were our 4x4 we had a couple of years ago. The lifted one was mine
1970 Camaro 1970 Monte Carlo 1982 Jimmy K5 2WD 1979 Blazer 2wd 1986 Silverado 2012 Silverado |
03-09-2015, 08:04 PM | #906 |
I know the pieces fit
Nice trucks!
03-10-2015, 09:15 AM | #907 |
78K & 79C Jimmys
Nice seeing others still in Ont.
Salt use has been real bad this year,getting fewer and farther between seeing them
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
03-10-2015, 09:56 AM | #908 |
Ya I feel the same way. We bought it in Arizona last April and drove it home. We got it oil sprayed in the fall and kept it washed top and bottom. Just got it oil sprayed again. All looks good. The original paint marker from factory is still on the frame.
03-27-2015, 11:37 AM | #909 |
Updated pictures. Added a 14 bolt with 3.73, 6 lugs, and disc. Also put a new engine cover on.
03-27-2015, 09:04 PM | #910 |
Looks great! Tell us more about that 14 bolt...
03-27-2015, 09:12 PM | #911 |
It's a 14 bolt semi-floater out of a 96 2500. 3.73 w/ gov lock. Slid in new 6 lug axles and converted it to disc. All new bearings, seals, brake lines. Blue torch fabrication diff cover. Had to move some perches around.
03-28-2015, 11:24 AM | #912 |
Thanks! It looks really well done. I guess there isnt a way to do ff with a six lug axles come to think of it.. I probably will have this swap to look forward to one day, but the ten bolt has served me well so far
03-28-2015, 11:49 AM | #913 |
The 10 bolt that I took out was a peg leg, drums, and 3.08 gears. Figured if I was going to complete a gear and diff swap might as well get a 14 bolt. So I went to a u-pull-it locally and started the process.
03-28-2015, 12:20 PM | #914 |
Those drums from the 14 bolt are massive! I'll bet it was handful to move around. The 14 bolt was a sf then?
The swap for the disks..are they gm parts from a nnbs truck? |
03-28-2015, 04:14 PM | #915 |
I got the conversion from lugnut4x4.com I believe the calipers are from a mid 80s gm front rotor, not 100% sure on the rotor. The owner is real customer helpful so I'm sure he'd be glad to hook you up. Yeah the 14b is a semi-float and yes the drums weighed a ton.
04-03-2015, 02:18 AM | #916 |
Work in progress. 89 6.2 soon to have a turbo 6 lug sf 14 bolt w lock rite and 4.56 gears. Front 10 bolt open 4.56s. 6" lift 37" crappy military tires
Future plans rust free body and full topper conversion
Eric 89 diesel jimmy 86 crew dually 87 truggy Horton |
04-13-2015, 12:56 AM | #917 |
04-20-2015, 03:01 PM | #918 |
Here's my hoopty, 79 K5 Blazer, 350/TH350/NP203/10b/12b, all original; A/C and cruise control, manual windows door locks and tail gate. She's a California truck but no smog pump or AIR. Does have a cat converter. She's been non-op'd since 2003. She has what sounds like a lifter knock (smooth constant hollow knock from top rear of engine). Got a full tank for fuel from 2003. Shes dirty rusty and tired. Straight body panels. She's perfect. Total investment, including new Craigslist tires and a new ignition lock cylinder, and a uhaul trailer rental to get her from the previous owners house to mine, under $1,000. She's been parked at my house waiting for my time and dollars. I recently got engaged and switched jobs so after a few weeks of catch up I'll be replacing lifters pushrods and rockers and then the fun begins. Powerplant swap is in the future. Either a 5.3 LS or a 6.2 diesel (to swap to diesel at the DMV, plans for a 4bt swap later down that road, if that is the road I choose.)
Posted via Mobile Device |
05-01-2015, 11:55 PM | #919 |
Local mud hole and Moab last year. Doing Rubicon in 2 weeks But mainly hang around here for my '68 and appreciate the info!!
'68 C10 SWB '85 K30 Blazer |
05-04-2015, 06:57 AM | #920 |
I guess I'll post pictures of my '85 Jimmy with hard top on while it's still mine:
05-19-2015, 06:45 PM | #921 |
http://67-72chevytrucks.com/vboard/s...d.php?t=670449
Started a build thread, thanks for looking guys!
Jeff '86 K5 Blazer / Turbo 5.3/80E/NP208C/14BSF
05-28-2015, 02:42 PM | #922 |
Was cruising craigslist early this morning and ran across this 85 Jimmy at a crazy price, listed pretty much in the middle of the night. Went over as fast as I could and now it's mine. Little rust in the drivers rocker and bottom of passenger front fender but very solid otherwise. Gotta fix the transfer case as it sheared off the selector rod flush with the case.
07-14-2015, 10:30 AM | #923 |
Heres a better pic in my driveway. Transfer case is fixed and she's on the road!
07-15-2015, 08:46 AM | #925 |
Thanks Bruiser...and thanks for your help regarding my transfer case issues!
