#901 |
Re: Project '86
He has it for sale on the c10 forum
WillieloRidez Drive em in Drag em out! Projects: 1956 Chevrolet 210 2dr post 58 chevrolet 2dr delray 58 chevrolet belair 4dr hardtop 1965 Chevelle big block 4spd 88 crewcab 1/2 ton long bed aka STRETCH Lt1-4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=388445 |
#902 |
Registered Cruiser
Re: Project '86
I don't think it is for sale any longer, he said he was going to keep it and move forward with the build, gonna be awhile though... Glad he's keeping it
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
#904 |
Re: Project '86
Having kids changes your life jis' a bit. Ask me how I know......
#905 |
Re: Project '86
He's sooooo close. He's got to finish it!!
I saw it on the C10 forum 4 sale too. I was saddened that it was not going to be finished after all that workmanship. I have been in his shoes & made the wrong decision ... damb that '66 chevy II .... Ratty 46 |
#906 |
Re: Project '86
Oh man, I hope he kept it. This truck is F&%#ING AWESOME! Hope he's continued working on it.
1975 Chevy Cheyenne w/ v8 350 and TH350 Siverado interior Fleetside bed aka "The Beast" aka "Cheyerado" |
#907 |
Re: Project '86
I still have it. Just been real busy with work and family and haven't worked on it for about 3 months.
#908 |
Re: Project '86
Should be picking up a rear mount suburban gas tank this weekend. Any suggestions on the best way to plumb it? Was looking in a Speedway Motors catalogue and they had 3/8" aluminum line and compression fittings. Looked to be a good inexpensive route to go. Anybody have some input?
#909 |
Re: Project '86
Nobody here running fuel lines?
#910 |
Home Built '87
Re: Project '86
I think it depends on how much you want to spend and if you want rigid lines verses braided/flexible lines.
I have a different motor & dual tanks so I went with rubber fuel injected lines from the tanks to the tank selector switch/valve, then I went with braided. If you are running one tank I think you could do either, but it would depend on your clearances around your bagged frame and where you think the lines need to run (If you were to go with rigid pre-bent lines).
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
#911 |
misshape grape
Re: Project '86
Great thread! Excellent thread, and one hell of an attention to detail on the truck!
Don't you just love rumors? I always find out stuff about myself that I had no idea I even did.. |
#912 |
Re: Project '86
Will anyone see your fuel lines, when your truck has it's frame laying on the ground? I think hard lines look cleaner when done well. Run hard line up to the engine bay then some short piece of braided where people can see it. (I have only ever run fuel lines on something that was leaking and needed sections replaced, thus only working with steel, rubber and plastic lines.)
#913 |
Re: Project '86
Great to see ya keeping it! I think the aluminum line would be the way to go..
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
#914 |
Gearhead
Re: Project '86
I would say the 3/8" aluminum hardline(s) to braided at the engine (and a short braided line at the tank for ease of connection and all) My truck has a fuel cell in the back and I ran aluminum lines all the way to front and have short sections of braided from the top of the frame to my engine (LT1 though).
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
#915 |
Re: Project '86
Thanks for the replies guys. I talked to a buddy of mine yesterday and he has some left over 3/8 stainless I can have. I figure I can just run that front to back and put a foot of rubber line on each end. It won't be seen and doesn't have to be pretty. Just needs to work and be safe.
#916 | |
Re: Project '86
Using the 3 sections allowed me to tweak each section as close as possible to my chassis. Once everything was assembled & the placement was how I wanted, I took it/them back out & painted the lines black. Once done, they disappeared into the frame channel (except for the SS cushion clamps & mounting hardware).
#917 |
Re: Project '86
you could always go stainless braided or the black braided, and depending on ur color scheme your could do black AN fittings, thats usually looks clean.
but im sure alum or stainless hardline will look clean to. |
#918 |
Re: Project '86
Wasn't able to find a blazer/suburban tank like I wanted but I found this Ford tank.
Cut out the factory crossmember and it fits in there pretty good. Just need to make some mounts and get it plumbed. ![]() ![]() |
#919 |
![]() Join Date: Jul 2010
Re: Project '86
what is that..a bronco tank?
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
#920 |
my short bus
Re: Project '86
I just started back on my burb after it sitting for 6+ months family first then the toys
**90 burb**bagged,shaved**(about done)********* **91 burb**stock worker for now**************** *********only squares for me****************** |
#921 |
I'm just glad to be here!
Re: Project '86
Are you going to bring it out to Turkey Drag in Tyler this weekend?
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#922 |
Re: Project '86
#923 |
Re: Project '86
Tank mounts are done! Only down side is that I wasn't able to get it low enough to allow me to mount the fuel filler where I wanted to. Probably going to use the stock tank filler as the vent and use the vent as the filler.
![]() ![]() Doesn't hang too low but since it's plastic I will eventually make a guard for it. ![]() |
#924 |
Re: Project '86
Nicely done so far ...
R46 |
#925 |
Re: Project '86
Looks good! Is a Chevy pump going to fit or will you just use the ford pump?
