Old 08-02-2010, 10:45 PM   #901
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: 198Plus build
Originally Posted by Strodder View Post
It's amazing how hard they work to patch things up, instead of doing it right the first time. It's actually easier to do it the right way.
Originally Posted by daverod View Post
Good ,your not done yet. I went away for the weekend and I was worrieed that you would be done with everything by the time I got back. I have a set of rockers I need to put on my 64. This winters project. Or the winter after that.
Ronnie wishes I was that fast. LOL
Originally Posted by FRENCHBLUE72 View Post
Wow Is all I can say those patch areas make me look like a damn good body man thats for sure...
That goes for me as well.
I didn't have much time today. It figures I get some work at home then we get really busy at work. It's all good. Throw piano lessons in with a sick wife= no extra time today.
I did go out at ponder some. I had originally thought of letting the sand blaster discover what else is in the A post patch work, but decided to remove the rest of the boogered up patch work so the blaster can get to everything. I will also cut off a portion of the inner rocker at the cab supports so the blaster can access the inside of the cab supports some. Before doing so I will add a little more (not much) bracing for insurance.
I explained to Ronnie that the only way to eliminate all of the rust is to bust ALL of the panels apart clean and treat and weld them all back together. But with mig welding corrosion can form at the welds even when using weld thru primer. Or I guess a person could have it dipped.
I will also be taking some measurments for comparison when I go back with the replacement panels. The main measurment I'm concerned about is the drip rail down to the bottom of the inner rocker. His inners are original, so it should be a good referrence point. That has given me the most trouble in the past. Maybe it will save some time. I will take some pics of the measurements the next time I work on it.
For you body guys out there what would be an estimate of time to replace the inner rocker front to back with a portion of the floor. I'm having him order the full inner with about 2" of the floor (one piece), toe kick, dog leg, rear pillar section, outer rocker, and cab corner on one side? I gave him a number and he screamed like a girl J/K I never kept track of the time I had in mine. I based my number off of Shannon's cab. The estimated time is to get it ready to wipe. I'm not going to divuldge my quote just yet. I don't want it to be biased. I think I'm too low and will fill bad if I go over it. But, it is what it is.
I also gave him a price to replace the inner/outer portions of the bottom of the doors.
Alan's Classic is offline   Reply With Quote
Old 08-02-2010, 10:56 PM   #902
198plus
198plus's Avatar
Re: 198Plus build
Dang I had a good day today, finally got the bleeding to stop....... Thanks for not posting any pictures on Monday.......
198plus is offline   Reply With Quote
Old 08-02-2010, 11:10 PM   #903
Alan's Classic
Re: 198Plus build
I didn't think your old ticker could take much more, so I gave you a day to rest.
Old 08-03-2010, 07:01 AM   #904
Alan's Classic
Re: 198Plus build
To clear things up some, my guesstimate starts once everything is apart and cleaned up. This is a special needs case.
Old 08-03-2010, 10:33 AM   #905
Strodder
Daring to be Different
Strodder's Avatar
Re: 198Plus build
It's hard to estimate how much to charge, or how long it will take. Even after you finish the job. You don't want to over charge, but want to be fair also. I stand back an look what I did, and always think I didn't charge enough. But what ever you charge would be fair, because regular Body Shops, and Repair Shops wouldn't even touch the job.
Here's an example. I installed a 350 Chevy engine in a Vega. I had to fab some stuff to make the kit work. I even made a transmission cross mount and cut a notch in the oil pan. I only charged $650.00. That was way to cheap. It took me a week, so I guess that's OK.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 08-03-2010, 06:12 PM   #906
198plus
198plus's Avatar
Re: 198Plus build
First job I got at the new shop....... A roll over
Old 08-04-2010, 10:03 AM   #907
Strodder
Strodder's Avatar
Re: 198Plus build
I'm surprised it wasn't totaled.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-04-2010, 02:51 PM   #908
daverod
SSN 706
daverod's Avatar
Re: 198Plus build
I think Ronnie is ready for my pictures now. Ronnie I don't get it, if you have your own shop why are you always giving your truck to other people? Guy here said he would put a LS 1 in my 64 for $800. I thought that was cheap. Maybe I should let Strodder do it.
daverod is offline   Reply With Quote
Old 08-05-2010, 12:17 PM   #909
Strodder
Strodder's Avatar
Re: 198Plus build
Bring it over.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-05-2010, 12:39 PM   #910
Jonboy
Slots go on anything!
Re: 198Plus build
Realistically, I would guess 20-25 hours per side. Our door rate is $44 per hour, so that's $880-1100.
That being said, everyone here would be crying their eyes out to actually have to do it.
1974 Jimmy- 5.3/4L80e/NP241
Old 08-05-2010, 08:53 PM   #911
Strodder
Strodder's Avatar
Re: 198Plus build
Wait a minute!!! You think I'll be cheaper. $800 is a good price. That is if he does a good job.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-05-2010, 11:15 PM   #912
198plus
198plus's Avatar
Re: 198Plus build
Still haven't named my new company yet. I'm going crazy trying to come up with a name for it, I want something different.......Suggestions would be great.
Bouncing this around in my head a little
Old 08-05-2010, 11:16 PM   #913
Strodder
Strodder's Avatar
Re: 198Plus build
What does 198 stand for???
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-05-2010, 11:43 PM   #914
198plus
198plus's Avatar
Re: 198Plus build
Well when I bought this.......
Top in speed was rated at 198 from the factory but after a few add owns and a dyno tune I thought 198plus would be a good user name. Since alot of people know me by 198plus.
Old 08-06-2010, 11:34 AM   #915
Strodder
Strodder's Avatar
Re: 198Plus build
That's Kewl. Strodder175 would be a good one for me.
SAVE THE WAVE.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-06-2010, 08:05 PM   #916
tiggamonsta
tiggamonsta's Avatar
Re: 198Plus build
I think the name works. My dad's shop was Witchcraft Body and Paint. The local school mascot was a Witch.
tiggamonsta is offline   Reply With Quote
Old 08-06-2010, 08:28 PM   #917
198plus
198plus's Avatar
Re: 198Plus build
Nice car.......175 works. I really should be called 185 plus I backed out of it at 185, a lot of things start running through you mind at those speeds......Like a dog, deer, or even a possum.
SAVE THE WAVE.
Old 08-06-2010, 08:44 PM   #918
Strodder
Strodder's Avatar
Re: 198Plus build
Thanks, I'm not saying I did 175. That's what it's expected to do from the spects.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-06-2010, 11:11 PM   #919
Alan's Classic
Re: 198Plus build
I had a 99 for a while. I miss that car. I also toured the Corvette assy plant in Bowling Greene Kentucky and also the museum right across the street. It was well worth the trip. If some one tells you they didn't build any 1983 vettes you can prove them wrong. I can't remember how many were built, not many. They crushed all but one and it is on display at the museum.
I vote "Hack Shack-n-paint inc" J/K Ronnie. Your logo looks good.
Old 08-07-2010, 09:27 AM   #920
Strodder
Strodder's Avatar
Re: 198Plus build
Yes I knew that there was only one 83. In 2000 we went with our Corvette club to Bowling Green with 12 other Vettes. It was the 5 year anniversary. The police closed the Freeway north and south. It was open to only Corvettes. At the off ramp to the Assembly Plant there was nothing but Corvettes on every street, and in all the gas stations. It was an amazing site. We took Route 66 when ever we could. It was a great trip driving across the country with 12 Vettes. We got honks, and waves every where we went. I want to go back some day. When I hit the Lottery I'll pick up a new one at the Assembly Plant.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-08-2010, 07:18 PM   #921
Alan's Classic
Re: 198Plus build
Ronnie, you ready for more surprises?
First I put a few more braces for support just in case. That way if it does want to sag down it won't. I did it on all four corners.
Rt A pillar cut out, almost. It took a while to see how they put everything together. I need to cut the kick panel higher, but don't want to until I get the patch panels.
Here it as of now.
I didn't realize that they replaced this much of the floor. My question is do you want to remove everything they did and start over? I will let you make that call.
You can see the burn thru marks in this pic and the double wall on the kick. Maybe the patch panel will enable me to cut all of this out.
The rear cab support has some pin holes in it.
They wiped right over rust. Gotta love that. It was flaking off in spots when I was grinding.
I figured I would see where the patches stopped on the lt side.
You didn't know you had a double walled floor did you. I left it that way for now. Because the patches I listed for you will not repair this.
Lt A post
More pics coming in a few minutes...............
Old 08-08-2010, 07:27 PM   #922
Alan's Classic
Re: 198Plus build
I quoted him 20. I asked Shannon how much time we had in his so far and guess 30-40 hrs. 20 hours really isn't enough time. Especially now that I have discovered more that is wrong.
Continued from before:
Left cab corner
Here are some referrence pics for later
This is where I measured from.
Front of inner rocker straight down from the rain rail at the top of the A post
Top of rain rail to bottom of the rear inner rocker. Both measurements are the same side to side.
Rear brace I put in to prevent any height changes.
3.0 hrs today.
Old 08-08-2010, 08:35 PM   #923
Strodder
Strodder's Avatar
Re: 198Plus build
Allan your brave, but that's what you do for a living. Nice work so far.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-09-2010, 12:06 AM   #924
198plus
198plus's Avatar
Re: 198Plus build
Hell there's not much more you can find.........There's nothing left of the cab
Old 08-09-2010, 09:55 AM   #925
Strodder
Strodder's Avatar
Re: 198Plus build
It might have been cheaper to find another parts truck, or cab. We're lucky here in California. Not too many rust buckets out here.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
