#901 |
Re: Chucks SWB Fleetside
I think I might have a battery if you need it!! It oughta do for a while.
=MATTHEW 69 Stepper...Stroked & Bagged ![]() 2003 Chevrolet Z71 Ext. Cab 1995 Cavalier gas saver! |
#902 |
![]() Join Date: Jul 2007
Yep and the one on my Colorado is going out too. Its down to 400 ca. Its going on 5 yrs old tho. Its still cranking good right now.
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
#903 |
Dang bro!
-Rus |
#904 |
When it rains it starts snowing. lol. We had less than a 1/2'' here today. I did get the rear brake lines on except for where the connect onto the wheel cylinders. I have new ones to put on on the 19th when the crew shows up. I did get some of the firewall stuff put back on. The power wire for the dizzy. The wiring for the taillights. I have started cleaning up my oil pressure line. I did put the purple wire onto the starter ''S'' terminal. I think that I have that correct by the wiring diagram I had found. I also ran my speedo cable through but didn't hook it up yet.
#905 |
Keep up the good work Chuck!! The 19th isnt too far away
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
#906 |
Nice bro!!
-Rus |
#907 |
I put the vintage air in today. The underdash unit and the lines. I still have the ductwork and wiring to do but I'll wait till the truck is painted for those items. I need to get a 3/4'' to 5/8'' reducer or 90 degree for the connection to the radiator. After that it'll be done for now on the v.a. I will have to replace the a/c compressor belt and get one another inch longer. I do wish that vintage air would make the pressure hoses 3'' longer. Not much maneuverability while adjusting the belt. I couldn't get the hose closest to the motor on the compressor at all without removing the belt.
I got a couple pics of the oil line .
#908 |
rear brake lines and new speedo cable
#909 |
looking very clean chuck..Great job
#910 |
Nice job on the a/c!
#911 |
Looks good, are you happy with the vintage air? I have been looking at putting in air but not sure if I should do it now or wait till after I get her running and on the road.
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 ![]() |
#912 |
Looking good! Sorry about the one a/c line being short
-Rus |
#913 |
Project collector
Coming right along!
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel Jezebel 3.0 NEW!!! 2020 GMC 3500 Denali Duramax 2016 Harley Street Glide CVO Roll Tide! |
#914 |
Thanks guys. I got another belt and its about an inch and a half too long. So I'll have to try again. I did find a temp sending unit connector and got that installed. I will put the new fusebox seal on and connect it all back up. I'll be ready for fluids and a battery after that. I still need to find a muffler and a tailpipe for it. I also started cleaning up the steering column. I'll just paint the intermediate shaft and clean the rest. I will use the column temporarily. I don't want to put my rebuilt tilt in till its painted.
sourkraut- I'm pretty happy with it. The lines could be about three inches longer on each for more adjustability. The one seems very short and I have to change belts because of it. Other than that I will still be happy with it. This is my second one to install.
#915 |
Not sure if you want them or not but your more then welcome to the mufflers I cut off the 78 if you would like them...2" pipe going to em
#916 |
Chuck I still have one magnaflow muffler and we could get some pipe and make you one like I had on my short bed!
-Rus |
#917 |
Okay Rus, I remember you telling me about that. Jeff, I appreciate it. Rus has one and thats all I need.
I filled the rear end with oil, added some other fluids. I need to get some more. I opened the bleeders on the front calipers and added fluid to both reservoirs, after a while the fluid started coming out of both and a little plug on the front of the proportioning valve. I marked with an X. This plug is for if you are running two lines for the front. I think I have the leak stopped. I closed off the bleeders too lol. The rears bubbled a lot and I just put some rubber block-offs on the new lines and I'll keep an eye on it. I plugged up the holes for the windshield washer nozzles. I won't be putting that stuff back on.
#918 |
I had to plug off that hole on my cpp master cylinder also
-Rus |
#919 |
I haven't put any real hard pressure on the pedal yet. I may see some more leaks pop up when I do. I had to do a search on here to see what that plug was. At first I thought it may be an adjustment screw.
#920 |
I wish I was moving as fast as you, Chuck. You are tearing it up!!
#921 | |
Thanks Matt. I can get stuff done when I don't work lol. I also got my big apes on one of my old Schwinns. I did get my lower shaft that connects to my steering column cleaned and painted. I'm not going to worry about the rest of the column since it'll be coming out later.
#922 |
better pic
#923 |
C10 Club Tennessee
Yea, Chuck you don't need that line on the front. I'm glad you're doing the VA. I'll be bouncing my install off of you when I get to it.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
#924 |
Sure thing Bryan. I still need to go get the right belt for the a/c.
#925 |
C10 Club Tennessee
I'll be using the original compressor from the 5.3 so I'm sure that's a whole new wasp's nest.
