Old 12-16-2011, 08:31 PM   #901
85burb
85burb's Avatar
Re: 85 burb meets 6.0 lq4
The core is the same i guess it says. The core width is about 1 inch wider. Maybe i will install it sunday. Or atleast take the old one out and see what will be needed to make this one fit.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 12-16-2011, 11:11 PM   #902
85burb
85burb's Avatar
The fans and shroud came in tonight. The only prob is the holes in the fan shoud where you bolt it to the rad dont quite line up with the rad. They are a 1/4 inch too long. If i line the two tops up the two bottom holes are off the rad. I guess i will have to bend the ends a bit. But for what i payed i was not expecting perfection.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-17-2011, 12:47 PM   #903
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
That ought to keep it cool!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-17-2011, 10:31 PM   #904
85burb
85burb's Avatar
If i ever get it in. Have ben working on it for a few hours now. Got old one out in like 5 mins. Did not have as much coolant as i was expecting in it but was not low. I guess i am just used to having to fill 3 5 gallon buckets when draining coolant at work. But i need to find some lower rad bushings and long bolts to mount shoud and short ones to mount fans. It is not exactly a bolt on deal i guess. I wish it came assembled. Hope to morrow i get it in.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-18-2011, 12:30 PM   #905
68GMCCustom
that's part of deviating from stock....things aren't always as plug and play as we'd like them to be!
Kurt -
Old 12-18-2011, 01:10 PM   #906
85burb
85burb's Avatar
Yes that is part of the fun. I just need to bolt it in and bolt the fans on and figure out how to make my efi ecu turn the fans on and off and i will done. I just hope i didnt remove the wires.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-18-2011, 07:45 PM   #907
85burb
85burb's Avatar
I got it installed and running. Holy cow does it cool off fast. I have fans kicking on at 210 and off at 185. I can not change the off temp. The only way the efi controlls it is comes on at whatver you set on at and turns off 20-25 degrees cooler then on temp. Thermostat closes at 195 so they never turn off. The air coming threw fans and rad is cold. Any one know what temp the fans are supposed to come on at? Will post pic later.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-18-2011, 09:03 PM   #908
85burb
85burb's Avatar
Here is reallt crapy cell phone pic in the dark.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-18-2011, 10:55 PM   #909
85burb
85burb's Avatar
Today was a historic day. My little girl tightined here first 4 bolts today. She also inspected his under carage with my flash light. I will get pic uploaded.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-18-2011, 11:39 PM   #910
85burb
85burb's Avatar
Here is pic
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-19-2011, 01:05 AM   #911
okieraptor
okieraptor's Avatar
Wish my girls would do that. They get bored with it and leave me hangin!
82 chevy longbed(grey truck)first truck when i was 15!
okieraptor is offline   Reply With Quote
Old 12-19-2011, 01:11 AM   #912
63chevyll
gets board easy.......
63chevyll's Avatar
good read, thanks for sharing. I would love to yank my BB and put a LQ9 in my burb
63chevyll is offline   Reply With Quote
Old 12-19-2011, 06:45 PM   #913
68 TT
Still plays with trucks
68 TT's Avatar
Stock GM dual fan setups run one fan as primary and the second comes on at a higher temp or when you turn on the A/C. Any way to set yours up that way?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-19-2011, 09:26 PM   #914
68GMCCustom
that's how mine is. has a relay for each fan. fan 1 (low speed) is set for key on. fan 2 (high speed) is activated by the adjustable temp. switch w/probe, or by the manual switch I have on the dash. 2nd relay will also be connected to an a/c compressor one day.
Kurt -
Old 12-19-2011, 10:10 PM   #915
85burb
85burb's Avatar
I will keep them the way i have them set up for now. I really dont want them on all the time. I may do something in the way of a manual swith tho. I will wait tell summer to make adjustments i guess. Thanks for the input.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-25-2011, 02:01 PM   #916
85burb
85burb's Avatar
Well i found out this fuse is no good. Was at the drive threw light park last night and about half way threw we all smelled a burning smell. Temp was fine. So i kept going. Then afew mins later when fans were supposed to be on i relaized what was the smell. And buy that time there was no place to stop. So i turned heater on full blast and hoped for the best. About 15 mins later temp maxed out the 260 degree gauge. Finally we were at the end. So i punched it and hoped to at least make it home. Temp went to normal when driving and oil psi was at 60 when driving. So i looked at the wiring and found my fuse had melted. I guess it was a crappy fuse. Installed the new fuse holder and bigger fuse. Test ran it for 45 mins fans kicked on and off 3 times and did not blow new fuse. So i will be ordering some water proof fuse holders and relays. I will wire them seperate. One relay and fuse per fan. Both turned on by ecm.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 12-25-2011, 09:28 PM   #917
68GMCCustom
thats how mine are.....one relay per fan.
Kurt -
Old 12-27-2011, 08:40 PM   #918
(541)COLD_beer
(541)COLD_beer's Avatar
Did you have to modify your motor cross brace to clear the oil pan?
(541)COLD_beer is offline   Reply With Quote
Old 12-27-2011, 09:46 PM   #919
85burb
85burb's Avatar
Nope. I used dirtydingo mounts. They lift motor .5 inches. It just bearly clears. Has not hit it yet tho.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-01-2012, 02:19 AM   #920
85burb
85burb's Avatar
Well i changed the oil today and will take a sample to work and run it threw out oil analysis machine and see if any things are wearing. Sometimes working at a diesel shop is handy!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-02-2012, 07:10 PM   #921
85burb
85burb's Avatar
I ran my oil sample today. The only thing that is hi was soduim levels. It says it can be a oil additive or coolant. But the glycal level was 0 ppm. Water was less then 0.1 ppm and no signs of any kind of metals wearing at all. So over all pretty happy and sad at same time......lsx 454 will have to wait i guess.....
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-06-2012, 03:08 AM   #922
68 TT
68 TT's Avatar
Some valve grinding compound added to the oil at the next service interval will fix that.
Old 01-06-2012, 10:15 AM   #923
kp110477
kp110477's Avatar
What an incredible build thread, kudos! I was actually looking for a more stock build up to follow, but this caught my attention and I've been reading it for a few days now. By the way, that dude that said he read the whole thread in 40 mins (a couple pages back) *cough* *cough* bull**** *cough*. Great build man! I'll continue to follow your progress.
kp110477 is offline   Reply With Quote
Old 01-06-2012, 09:02 PM   #924
85burb
85burb's Avatar
I think i may skip the valve compound. With my luck the wifes car will crap out and leave us screwed.
Thanks for the comlements kp110477
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-08-2012, 12:18 AM   #925
85burb
85burb's Avatar
So had a little fun today. Wife was on phone with her dad in the garage when i was backing in. So i decided to let buddy "mark" his spot. So i may or maynot have stomped the breaks and put it in drive and gave it some gas. It would seeem the the truetrac i installed is working perfictly. I laid 3 yes 3 marks on nice concret floor. 2 dark ones from the rear and one from one of the fronts being pushed. It was so funny. She was not so happy about it but the burned rubber smell was nice for about 20 mins. Love owning my own home.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
