#901 | |
Re: 72 k20 project
its just rustoleum enamel. normal stuff from a plain white can. where i live, it could go a thousand years with no paint and still only have surface rust. i would have considered heavier coating, possibly even PCing if i still lived in the rust belt. Thanks! i got some black on it, im sure i missed it somewhere else though... flash photography will expose my inadequacies later i am sure. its semi gloss, so far anything black on this truck has been. just a little more shine than flat, but not full out! No gloss in this joint! |
#902 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: 72 k20 project
I'm having a beer to celebrate your accomplishments!
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#903 |
Re: 72 k20 project
Have two Pete! i got some more done today.
paint was dry enough to assemble. ran a tap through the threads to get the last of the dirt that was leftover. ![]() put the kingpins back together and installed the steering arm with ARP studs and fresh nuts. it looks like i missed a lot of paint, but its the strap reflecting off the black. ![]() you can see the fresh stover nuts on the spindles. i have never heard of any news headlines caused by reusing mechanical style lock nuts, but i got a bag of 50 for less than ten bucks so i replaced them. also intstalled the hubs with the fresh studs. havent decided what i am doing for brake rotors yet and i need to clean and paint the abutments before i install them anyway so i left them all off. you can see the bolt in the bracket that holds the abutment. in order to keep the best thread engagement i installed them first so i would not need to make them shorter in order to install while the bracket is bolted to the knuckle. ![]() put the cover on temporarily for now. i think i will order a lubelocker gasket for it. used button head bolts, since, because. i think i will order new lower and upper kingpin cap bolts. i need to order my new lower pin plates and install them as well. i commited to the plan and drilled my knuckles. i stole the tie rod from the other axle and put it on so it will roll somewhat. i need to order the tie rod ends and tube to put the correct tie rod on this one and put this one back on the other axle before it dissapears ![]() Last edited by ryanroo; 04-26-2014 at 06:39 PM. |
#904 |
Re: 72 k20 project
Some more tidbits of fun.
a hone job ![]() then a wash ![]() nice and clean, back on the stand. oiled the bores and the mains. hope to drop the pistons back in soon. ![]() made up a filter mount bracket. now i just have to figure out if i can get it mounted the way i want and have space for the plumbing. not positive how i am going to deal with that just yet. ![]() and then... ![]() ![]() |
#905 |
Vintage 4x4s
Re: 72 k20 project
Looking great!!!!!!
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#906 |
Re: 72 k20 project
That cab looks sweet!!
#907 |
Carpe manana
Re: 72 k20 project
Downhill from here on out I'd say!
#908 |
Re: 72 k20 project
Looks great
BRIAN 1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater. My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509 ![]() |
#909 |
![]() Join Date: May 2013
Re: 72 k20 project
I need that cab !
Looks great Ryan.
Tom 71 K2500 71 K5 Jimmy |
#910 |
Re: 72 k20 project
Love that colour . Is that blue or green or what ? Looks close to what my 56 was new .
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 |
#911 |
Re: 72 k20 project
Cool color Ryan.
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
#912 |
Re: 72 k20 project
That cab is to die for! What is the color code?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#913 |
![]() Join Date: Jul 2012
Re: 72 k20 project
Shweet!
Nick Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986 http://67-72chevytrucks.com/vboard/s...d.php?t=545356 Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck. |
#914 | |
Re: 72 k20 project
Thanks! i was pretty excited to see it. first time its had any real color in a while
Its rolling good right now, hope i can keep up the momentum. Thanks! and you'd have to fight me for it... ive been waiting for that for the last 16 years! Quote:
Thanks. i used to hate the color, but now i really love it 518 medium green. it is the original color for the truck, just looks really bright now since it hasnt had any sun fade. i was excited to see the pics, i was standing in my living room dealing with a sewer back up when the painter sent them to me. perfect timing Thanks! |
#915 |
Re: 72 k20 project
Todays progress.
got the crank washed and rolled the new shells in. crank back in and mains torqued. spins like a top. we also got the new rings in the pistons and re-assembled the pistons and rods. hope to slide them back in the holes tomorrow. i ordered a set of studs for the head that have arrived as well. as long as the head checks out, i should have all the needed parts for the engine. after some talking i think we are going to send the pump to a friend of my buddy Sean's. Sean is a bosch pump guy but lacks all the fancy tools his buddy has. so for a nominal fee, the pump will get the dope treatment. i need to start working on my oil pan soon as well ![]() |
#916 |
Re: 72 k20 project
Ok then.
But i must tell you,I was trained by John Rambo in street fighting. ![]() Motor is looking good.
#917 |
Re: 72 k20 project
Looking good . Soon it will be ready for a coat of detroit green to blend in with the orriginal colours on the rest of the truck !
#918 |
Re: 72 k20 project
Ryanroo love the build so far. Took me a few days at work to read your thread. You have crazy good skills at fabricating. Excellent choice of truck and engine. Love the color! I'd like to see a video of you truck driving by this summer!
#919 | |||
Re: 72 k20 project
Todays work The gear housing and cam are back on/in as well. phone died before i could take the end of the session pic. ![]() i grabbed this box, as we are getting close to needing it. i didn't realize that the pedestals required machine work... i guess i know what i am doing tomorrow. ![]() i also started another garage furniture project. despite the fact that my garage is already to small, i really want a heavy table to work on. here is the pile of steel, ready to be glued together. 3'x4'x.75" plate top. 3" tubular legs and assorted sizes of angle iron(GASP!) to construct the frame. ![]() |
#920 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: 72 k20 project
That cab looks sweet, and the engine is coming along nicely too! That fab table sure will come in handy!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#921 |
Re: 72 k20 project
#922 |
Junk Yartist
Re: 72 k20 project
Slightly jealous.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#923 |
Re: 72 k20 project
Looks great. Have you decide on if the stock pan will work, or is it still going to be a custom aluminum one? (I hope aluminum one because that will be BA.)
#924 |
Re: 72 k20 project
Looking good Riley!
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
#925 |
Re: 72 k20 project
Nice. That was a quick rebuild !
And trained by McClaine huh ? Lets do this ! ![]() (This will sound very random,but my mother actually went to HS with him.No BS. Said he was very quite.) And take care of that cab.Or i will show up with a viking and take it. ![]()
