Old 08-09-2010, 10:19 AM   #926
OLDIRON69
Re: 198Plus build
Can you body wax the rust on the inside of the braces that you can't get to or shoot POR up in there?
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 08-09-2010, 11:22 AM   #927
Strodder
Daring to be Different
Strodder's Avatar
Re: 198Plus build
My friend that owns a body shop for 35 years said he uses diesel fuel to spray the rust where he can't get to.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 08-09-2010, 06:57 PM   #928
198plus
198plus's Avatar
Re: 198Plus build
Your right, but since my grandfather bought it new and left it to my dad and then my Dad left it to me...........I'm just sayin
Originally Posted by Strodder View Post
It might have been cheaper to find another parts truck, or cab. We're lucky here in California. Not too many rust buckets out here.
198plus is offline   Reply With Quote
Old 08-09-2010, 08:31 PM   #929
Strodder
Strodder's Avatar
Re: 198Plus build
In that case, what ever it takes. I don't think Allan will hurt you much..
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-09-2010, 08:46 PM   #930
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: 198Plus build
The only original piece of the truck is the cab, hood and frame I think.
Alan's Classic is offline   Reply With Quote
Old 08-09-2010, 10:15 PM   #931
Alan's Classic
Re: 198Plus build
Here is the left floor that has been replaced prior.
Old 08-10-2010, 07:14 PM   #932
MacAttack
283 Drama Queen
MacAttack's Avatar
Re: 198Plus build
I see Alan has resorted to the Boring Electron Microscope for the last shot.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 08-10-2010, 08:40 PM   #933
Strodder
Strodder's Avatar
Re: 198Plus build
Yeah looks like it needs rings.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-14-2010, 12:05 AM   #934
198plus
198plus's Avatar
Re: 198Plus build
I'm finished with my new shop logo.......I think.....
Old 08-14-2010, 12:10 AM   #935
tiggamonsta
tiggamonsta's Avatar
Re: 198Plus build
The black box and then the black oval behind the text does not seem right. Does it not stand out enough without them? Maybe if they were both the same shape? Overall I like the concept & colors.
tiggamonsta is offline   Reply With Quote
Old 08-14-2010, 12:13 AM   #936
Alan's Classic
Re: 198Plus build
Looks saweet!! You gonna put that logo on the door of your old truck when it gets done?
Old 08-14-2010, 12:16 AM   #937
198plus
198plus's Avatar
Re: 198Plus build
Now that I look at it, you're right........Changes in the works
Old 08-14-2010, 12:25 AM   #938
198plus
198plus's Avatar
Re: 198Plus build
Thanks Allan.........Only thing going on my doors will be wax
Old 08-14-2010, 06:11 AM   #939
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: 198Plus build
Nice shot Alan
As we know,when the support rots out (and/or the floor) the small tube that surrounds the mounting bolt is usually rotted too.
That piece doesn't come with the replacement support nor the floor section.
Can you post up some dimensions on this tube,ie length, diameter and wall thickness,also I assume it's welded to the support?
I have never seen this part in any calalogs
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 08-14-2010, 10:29 AM   #940
Strodder
Strodder's Avatar
Re: 198Plus build
Looks great. Have a magnet sign made so you can take it off your truck when you don't want it. Just use it when your parked in front of your shop. Should be an attention getter.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-14-2010, 06:53 PM   #941
Alan's Classic
Re: 198Plus build
Originally Posted by 63sbssbbw View Post
Nice shot Alan
T
I won't be able to post up any deminsions on the tube. My truck is all back together and I'm not going that far on Ronnie's. It's not welded to the cab support, but is welded to the front/back floor support as seen in the pic. Sorry I couldn't be much help.
More updates coming in just a few minutes...........
Old 08-14-2010, 07:05 PM   #942
Alan's Classic
Re: 198Plus build
I advised Ronnie that we should go ahead and cut out the metal that had already been replaced. That was a good idea. Because the drivers side wasn't welded to the cab support.
Here it the driver side patch that was removed. Notice the spot welds, not good.
Here's the double floor on the drivers side.
Still something going on on the Left kick panel to fire wall.
Did some more digging and found this.
The passenger side was welded better.
I believe I got all the patch work out on the passenger side. The sand blaster might reveal something on the pinch weld. It is loaded with filler.
I ground some of the filler on the A post gutter. I knew there would be issues after seeing it covered up. They need to be drilled off and replaced. I have to look to see if they are available. Both side are the same.
More decisions to be made in the next post...........
Old 08-14-2010, 07:15 PM   #943
Alan's Classic
Re: 198Plus build
Firewall decisions................Need to determine which holes to weld up. Here are some pics for Ronnie to edit and circle which ones he wants filled.
Rt side
Lt side
What about these extra holes somebody added?
I know the clutch rod goes thru one of these but what is the other? Maybe the speedometer cable goes in the smaller one.
Here are some of my recommendations. Double check me Ronnie.
Referrence pics of mine.
Old 08-14-2010, 09:30 PM   #944
198plus
198plus's Avatar
Re: 198Plus build
Well it's got to get better
Old 08-14-2010, 11:06 PM   #945
Alan's Classic
Re: 198Plus build
Ronnie wanted the tar removed from the bottom of the cab. It's a good idea to remove this stuff before the blaster. The blaster won't remove it.
Before
Driver side after
Passenger side had more on it.
Old 08-14-2010, 11:10 PM   #946
daverod
SSN 706
daverod's Avatar
Re: 198Plus build
Firewall on your truck rocks.
daverod is offline   Reply With Quote
Old 08-15-2010, 10:36 AM   #947
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: 198Plus build
Thank you Alan
I have my floor piece and support so shouldn't be too hard to get the right length.
as for wall thickness I'll just go overkill, 1"x .125w
T
member#7816
'61 GMC in progress
Old 08-15-2010, 07:48 PM   #948
ConnDemned
Re: 198Plus build
Not to change this from a build thread to a graphic design thread, but I would suggest doing your logo in a vector based program in greyscale ( black & white tv ish) a program like illustrator or corel are probably the most commonly used. The reason for a vector image is they can be scaled up or down indefinatly without messing up clearity of the picture. Also wikth using no colors you can save money on print and get a clearer idea of how clean it is, readability and brand recognition are key to good logos. I know you won't put a b&w sign on the side of a building or anything but you can always have color added to a different image file. Also if you have a very well designed simple logo in b&w adding color is easy, I can't think of the universal inks at the moment, I want to say pms but it could be that time of the month around here is why that's what I believe it is. I don't mean to sound like your logo isn't good or anything just helping before you "waste" time on something that can't really be used easily and possibly cost more time and money. Ok back to truck building, good luck with the new business adveture and getting your truck going
ConnDemned is offline   Reply With Quote
Old 08-15-2010, 11:21 PM   #949
Alan's Classic
Re: 198Plus build
Thanks Dave!!
Thank you Alan
T
Old 08-18-2010, 09:46 PM   #950
198plus
198plus's Avatar
Re: 198Plus build
Parts on the way Alan Since there's nothing going on with my build thought I would share some pic's of my shops next few projects.
Our first total repaint.......More pic's when finished
Total restoration starting soon.
New shop bike
My office if I ever get done
