#926 | ||
Re: 72 k20 project
I am very happy, if not a little broke. rings and bearings with gaskets, all OEM is a little more on a 6bt than your average GM v8... haha
Thanks Mister Quote:
i have camoflaged the house so now i blend in to yuppieville. no way to find the house now... it is safe |
#927 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: 72 k20 project
Haha, park a high dollar SUV in your drive way and now you're camoflaged?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#928 |
Re: 72 k20 project
you got it. i can tell the neighbors are confused. i dont think they know how to process it. haha
#929 |
Re: 72 k20 project
made a little headway on the fuel filter silliness.
![]() this involved a little creativity. or stupidity... the line gets a little fuzzy. i wanted the filters up as high as possible, hopefully out of the way. this was about as far up as i could go without hitting the cab. its still going to be close, but ill hope my measuring is good. i need to get a few fittings for the heads before i nail it down for good. i used the pipe nipples to help with alignment when i tacked the bracket. the plan right now involves some double ferrule compression fittings and stainless hard line in the center part of the frame where hopefully you wont ever need to be removing anything, and transition to braided soft lines closer to the front of the truck and the area near the lift pump/tank at the rear. i've been debating on using PTFE braided line and fittings vs the conventional braided over rubber hose. ![]() |
#930 |
Re: 72 k20 project
Ryan your truck is looking SWEEEET! I'm gonna have to sign up for some lesson from CHUCK NORRIS.
1987 GMC R2500 SC 454 T400 1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors |
#931 |
Re: 72 k20 project
Man that's a lot of work for the fuel filters, but if anybody has the fab skills its you.
I am kinda surprised your putting the batteries on the inside of the rails, hard to reach the terminals of you ever need to jump someone. Actually my first thought was is there any chance of a driveline breaking loose from a U-joint failure and hitting the batteries? Safety cage for the shaft or batteries?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#932 |
I had a V-8
Re: 72 k20 project
Is the fuel particularly terrible in your area that you need that much filter?? Maybe it's just the angle of the picture, but that seems ridiculously long??
As far as Teflon vs. rubber in the braided line debate, there is no comparison between the two. Teflon liner or nothing--that is unless you really like making hose assemblies, if so, then you should go with the rubber liner. Over the past five years, I have slowly been removing all the rubber lined braided hose from service in my fleet. Teflon costs more, but it's service life is infinite.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE. |
#933 | |||
Re: 72 k20 project
that is a possibility. i don't plan on running a battery with liquid solution in it. so if it does blow up and ruin my batteries and exhaust, i will deal with that then. with the above average number of things to hang off this truck, i have to use what space i can. i still have to find space for a reasonable amount of air storage, plumbing and associated items. and all the stuff i am sure i have forgotten about. oh yeah, oil filters and air horns... |
#934 | |
Re: 72 k20 project
i knew i could rely on you to argue the teflon hose. i do think i will use it for my fuel and oil lines. i think the air system will get regular rubber though. i guess we'll see when i get to the point of ordering it. |
#935 |
Re: 72 k20 project
Nice mount Mr.Roo. The only thing I'd add to your list is a battery disconnect switch just in case. That way if there's ever a need to disconnect battery power if your starter stays engaged, you aren't left with a big pile of molten metal because you couldn't get under there in time to get your cable ends off. Those big filters restrict less at the rate of fuel you will be pushing through them too. Not what a stock diaphram lift pump puts out.
#936 |
Re: 72 k20 project
I have toyed with the idea of a disconnect and isolation set up. i have even been secretly thinking about stashing a third battery for the winch and isolating it from the two chassis batteries. i do plan on running 200 amp circuit breakers to protect the cables, but i dont know if that will do me any good in the event of the starter sticking. id really like to have a disconnect but id have to figure out where it would be reasonable to inject in the circuit and still be accessible. one hurdle at a time i suppose. i am not particularly looking forward to the investment in copper. i have a top of the line taste when it comes to battery cable, and i need a lot of it.
#937 | |
Re: 72 k20 project
Let me know on cable, I have about 400ft of it. I just finished wiring my remote batteries. |
#938 | |
Vintage 4x4s
Re: 72 k20 project
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#939 | ||
Re: 72 k20 project
this is the cable i am looking at running. very flexible and finely stranded. http://www.ceautoelectricsupply.com/...erCable_lg.jpg Quote:
that would probably work, so long as the solenoid could handle the load. i havent looked, but i am sure there is something that would work. |
#940 |
Re: 72 k20 project
In the effort of getting the frame rail fab as complete as possible before the cab is on, i finished the welding on the link brackets both front and rear. slathered them in paint and did the links as well.
![]() the other side is curing now. i did them one at a time so i didnt have to worry about the axle rolling away... ![]() |
#941 |
![]() Join Date: May 2013
Re: 72 k20 project
Looking good.
![]() Your making some good progress with everything.
Tom 71 K2500 71 K5 Jimmy |
#942 |
![]() Join Date: Jul 2012
Re: 72 k20 project
This is really cool.
Nick Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986 http://67-72chevytrucks.com/vboard/s...d.php?t=545356 Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck. |
#943 |
Re: 72 k20 project
Looking nice Ryan!
#944 |
Re: 72 k20 project
Thanks Guys!
i got a little box today with these cute little three gallon tanks. i sure wish i had more room. i think i may be able to add two more if i need the volume, but i don't think it'll be an issue given the mount of air the compressor can make. also pictured is the fab table in its finished albeit shabbily painted state. i need to brush some of the surface rust of the work surface, and figure out where to put it in the way. ![]() |
#945 |
Re: 72 k20 project
Nice fab table and air tanks man!
#946 |
Re: 72 k20 project
Thanks!
i got a box with some fittings delivered the other day. for anyone that has done any instrumentation or controls work, this is the run of the mill. they are double ferrule compression fittings that adapt tube to JIC and tube to NPT, in this case the npt adapters are 1/2"x1/2" and the JIC are both -6x3/8" and -8x1/2" ![]() here are the tubing benders for the 1/2" and 3/8" stainless tube. and the Npt adapters twisted into the filter head. ![]() the heads mounted. i bet anyone watching me turn the fittings in bit by bit so the pairs are exactly the same height, might have thought i had a stroke. ![]() and the first dastardly piece of line. this is the fuel feed line. i started the forward piece but it is not done yet. i need decide where i want to terminate the hard line and all that. the pictured piece was a bit awkward due to the bend radius and the proximity of the fittings. it clears everything but looks a little silly. whoops. ![]() |
#947 |
Re: 72 k20 project
so.. what to do, i guess i'll drink coffee and stare at it...
![]() I need to buy or make some separator/mounts, but for now Blue Tape! the rear end of the line may be terminated differently so it is just raw for now, but ill decide what i want at some point. ![]() ![]() ![]() then i hung these back on just because. ![]() then i mocked this up. i need to fit the inner fenders for the charge pipes, and i need to see about an air box. the one i want is huge, so i will see how much ill need to cut and see if it is practical at all. ![]() ![]() |
#948 |
Re: 72 k20 project
Thats a nice tubing bender. Makes for some accurate bends.
#949 |
Re: 72 k20 project
They are nice. i borrowed these from the boss. i bet just between the 3/8" and 1/2" there is over 500$ worth of bender there. i would like to buy a set for myself, but for no more than i bend tube at home, the price was a little hard to swallow.
#950 |
Re: 72 k20 project
Buy a set? **** man I thought as crafty as you are, you would make your own. Buy a set, says the man that has the baddest engine stand on the planet, ha!
Link to my 69 Camaro 6.0/T56 swap: http://ls1tech.com/forums/conversion...69-camaro.html |
