Old 10-11-2012, 10:27 AM   #926
VA72C10
VA72C10
VA72C10's Avatar
Re: Project Grande Slam: Coley's Hot Rod Shop
Looks great!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-11-2012, 12:00 PM   #927
Rusbuilt
Rusbuilt's Avatar
Nice work! Very clean!
Rusbuilt is offline   Reply With Quote
Old 10-11-2012, 12:54 PM   #928
Graham57a
Graham57a's Avatar
Very nice work. This is going to be a beautiful truck when you're finished. Might end up so nice you're not gonna wanna make it your DD
Graham57a is offline   Reply With Quote
Old 10-11-2012, 01:06 PM   #929
CC69Rat
CC69Rat's Avatar
Yeah, you're probably right ..
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 10-11-2012, 02:17 PM   #930
Bennett68C10
Bennett68C10's Avatar
Looks good, I like the look of the gray with the black
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 10-11-2012, 02:34 PM   #931
CC69Rat
CC69Rat's Avatar
Thanks for the compliments!
Chad
Old 10-12-2012, 04:28 PM   #932
nlped
nlped's Avatar
Looks phenomenal!!!! Love IT!!!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 10-12-2012, 04:41 PM   #933
CC69Rat
CC69Rat's Avatar
Dad is picking up an Air Chisel today..
What's the best way to get the rivets out of the Trailing Arm brackets? My cut off wheel / disc is just a 4 1/2 and I'm not sure drilling them out would be the best option? How do you guys get them out?
Dad had the trailing arms blasted yesterday and I think he painted them today. New Prothane bushings are going in and we'll mount them up as soon as the flip is finished up. By that time I hope the drop blocks and Ubolts come in.. But I gotta wait on my PB brackets and stuff.
One step at a time. ..
Chad
Old 10-12-2012, 04:54 PM   #934
nlped
nlped's Avatar
I used my Plasma cutter to get the rivets off on my '70 model last week. Just slice the head off and knock it through with a punch and Whammer.
Carter
Old 10-12-2012, 05:05 PM   #935
gringoloco
A guy with a truck
gringoloco's Avatar
Cut an x in the head, then use a flat bit to chisel it off. Chisel again with the pointed bit to push th through. They're easier to get to from the trans side....
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-12-2012, 05:10 PM   #936
big_al_71
big_al_71's Avatar
exactly how we do it!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-12-2012, 05:54 PM   #937
69gmcc10
69gmcc10's Avatar
I remove all of my rivits, trailing arm rivits included, by drilling a small hole in the center of the rivit about 1/2 way throug and steping up in size until I just knowck the shulder off the rivit and then I smack it with a mini sledge and a punch in the hole. they are easyier to get at from the trans side. I found grinders molest alot of steel and the result never looks good to me.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 10-12-2012, 06:50 PM   #938
Bennett68C10
This is how I do it too, I use an air hammer to chisel the head off and then switch the bit and use it to hammer them out. Works really good.
Keith
66 Suburban
IG: bennett68c10
Old 10-12-2012, 07:40 PM   #939
NoNeck
NoNeck's Avatar
I am with you. Chad and I tried the "X" method, drllling down the center, and the Makita grinder. All of them are a pain in the a$$ and take forever. After researching online, I watched YouTube videos of guys removing riveted ball joints in our trucks with an air hammer/chisel. This one guy removed the heads from 4 ball joint rivets, changed to a sharp pointed bit and knocked them out in less than a minute.
The transmission is still in Chad's truck, but the bed is off. It looks like the rivets are more acessable from the trailing arm side. The one thing that worries us is the gas line that enters the cab floor close to that passenger side bracket. We really don't want to be throwing sparks anywhere near that line. So, it just makes more sense to use the air chisel. We will still use a welding blanket to shield the gas line, but sparks should be at a minimum.
POP
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 10-12-2012, 11:45 PM   #940
lolife99
67-72 parts collector,…
lolife99's Avatar
I have a couple $100 air chisels.
They suck for knocking rivet heads off.
I cut an "X" in the head and then use the air chisel to finish the rivet head and punch the remainder thru the hole.
I've heard from my buddy n2billet that the "high dollar" Snap On type air chisels will peel the rivet heads off with no problems.
But the air chisels are expen$ive!
http://buy1.snapon.com/catalog/item....re&dir=catalog
Keith
Convert to disc brakes.
Old 10-13-2012, 12:50 AM   #941
gringoloco
A guy with a truck
gringoloco's Avatar
I dunno, lolife. There are times I'd gladly pay that to not have to deal with the rivets. There's a vid around here from ridetech using the snap-on air chisel and it makes quick work of them. Hard to beat the $20 HF special though...
-Chris
Old 10-13-2012, 01:20 AM   #942
lolife99
lolife99's Avatar
Me too.
I hate rivets.
I always look for the "good" air chisels when I go to swap meets.
I may have to break down and buy a new one.
Keith
Old 10-13-2012, 09:15 AM   #943
N2TRUX
Happy to be here
N2TRUX's Avatar
I was with Keith (n2billet) one day when he did a rear notch. It took every tool he had in his well stocked box to get the rivits out. Yeah, that high dollar Blue Point chisle set did remove the heads nicely. Unfortunately some of the rivit bodies would not budge. We used quality step bits, real bits and BFH blows and they still fought us.
Rivits are evil, and there is no easy way to get all of them out. Plan on being there a while, and cursing a lot.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-13-2012, 09:23 AM   #944
CC69Rat
CC69Rat's Avatar
Ive never dealt with them till we dropped this truck. Yes they are a pain. Ill probably just do the whole cross member swap on my stepside. Im somewhat of a perfectionist so I have a whole lot of patience.. we'll get them out.
Why is the Hotchkis anti-squat kit so expensive? Wouldnt the bracket flip do the same thing? I understand 1* of pinion adjustment per hole.. but do I really need their brackets?
Chad
Old 10-13-2012, 09:26 AM   #945
NoNeck
NoNeck's Avatar
We have some friends that have offered to loan us a Snap-On air hammer, so that's the best option. Both Ricky (Flintstone Media Blasting, Flinstone, GA) and Tony (Tony's Auto Body, Soddy Daisy, TN) are always willing to help us out when they can. It's nice to have good friends! We will probably get a gift card to Summit or Jegs for the use of the air hammer.
Eventually, we will need to buy one because Chad is talking about notching his stepper next. Have I said that I HATE RIVETS?
POP
Old 10-13-2012, 11:11 AM   #946
RRC
RRC's Avatar
POP
Snap-On air hammer is the only way
RRC is offline   Reply With Quote
Old 10-14-2012, 05:31 PM   #947
CC69Rat
CC69Rat's Avatar
Trailing arm brackets are off.. gosh I hate rivets
Hotchkis anti-squat kit on the way tonight. More coming soon
Chad
Old 10-14-2012, 08:31 PM   #948
Bennett68C10
Nice can't wait to see some updated pics
Keith
66 Suburban
IG: bennett68c10
Old 10-16-2012, 12:38 PM   #949
superflysteiny
superflysteiny's Avatar
Frame looks great as do the notches
superflysteiny is offline   Reply With Quote
Old 10-16-2012, 12:46 PM   #950
CC69Rat
CC69Rat's Avatar
I appreciate it fellas.
I have 1.5" blocks, new U bolts, shims, etc. on the way. The trailing arms were blasted and came out like new. Dad is finishing them up now. We're about ready to start bolting things back up.
When we were taking the brackets off, we kinda chewed them up in places so I just got another set. One of the guys on the forum had a set of the Hotchkis adjustable brackets, so I'm going with them on this truck. That kit is almost $300 from Summit, but you get extra U bolts, shims, and grade 8 bolts .. That I don't need (?) All I need are the brackets I'll get for $50. So, .. saved a little on the whole kit. He was using everything but the front trailing arm brackets, so it just workd out.
I'm just waiting on my bolts and blocks now, next will be the 5 lug swap over and mounting up my rear brakes, wheels, etc.
Dad is working on the initial sanding on my bedwood this morning. Spar coat #1 should go on today (on the backsides first)
Chad
