03-02-2020, 06:26 PM | #926 |
Re: What did you do to your truck today part IV
About $400.00
03-02-2020, 07:46 PM | #927 |
Finished removing rear springs and mounts today in order to put new drop springs on my ‘63 longbed. Problem is the bottom bolts on both trailing arms are stuck in there. Heads snapped off while trying to remove them. Looks like tomorrow I will be drilling them out.
Posted via Mobile Device |
03-02-2020, 07:50 PM | #928 |
Who Changed This?
From a quick GOOGLE search:
Safety fuel cells work just like the gas tank on your street car, but they are designed to prevent spilled fuel in the event of a racing incident. ... Fuel cells generally consist of three parts: The outer can or enclosure, the bladder, and the foam baffling. The fuel cell enclosure is typically made of steel or aluminum.
03-03-2020, 10:09 AM | #929 |
1962 C-10
From what I've heard, and it could be wrong... a fuel cell is usually made for racing, it is not metal, usually plastic and has foam inside for baffling for hard accelerations. I'm sure there are probably more to it than that, but that's my $0.02...
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
03-03-2020, 05:28 PM | #930 |
Definition wise I don't know but i can tell you why I bought a tank to replace my cell.
1. the cell started to warp. The top started sagging inward and the bottom started bowing upward. Yes it was vented, and no, the straps were not to tight. 2. The sending unit did not go all the way to the bottom of the cell, so I never had a correct reading of how much fuel I had left. 3. It came with AN -8 fittings so I ran an -8 fuel line that I think has been causing all sorts of problems sense I installed it. I know I could just replace the line but I needed an excuse to replace the cell with a tank 4. I was constantly smelling gas around the cell. If that doesn't convince you, would you like to buy a used jazz fuel cell? |
03-10-2020, 05:20 PM | #931 |
Installed a pol rear sway bar on my 62. The truck is Still up in the air so I have not tried it out yet
03-12-2020, 05:05 PM | #932 |
That sway-bar reminds me I need shocks on my own Kidney Bouncer.
I've been pulling my hair out trying to figure out why my battery isn't charging and staying away from hammers and large wrenches so I don't do anything I might seriously regret! |
03-21-2020, 02:37 PM | #933 |
Todays day of self isolation included installing the new front park lights on the GMC. The counterpart lenses come with rivets which are way bigger than originals, and don't look good installed...5/16" as apposed to the lense openings of 3/16"...you can see the difference in the picture before and after. I filed down the rivets by hand to fit. Drilled out the holes on the housing as the rivet stems are a little larger too. Used an oversized punch with the lenses placed on an anvil to gently splay the hollow core aluminum rivets. Thinking I might try a felt pen or paint to tone down the color of the aluminum heads...Were the originals brass or metal? Problem solved, and they look great
03-21-2020, 03:36 PM | #934 |
But Found Her 25yrs Later!
Got the bumper installed. And mocking up the tailgate.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
03-22-2020, 11:06 PM | #935 |
More life hours into floors. I'm over it.
03-23-2020, 12:09 PM | #936 |
Finally got the Vintage Air installed and charged. I didn't like the look of the plastic box. Built this carpeted cover to reduce the fan noise and attempt to improve the look. It didn't turn out quite like the idea in my head, but it did reduce the noise and is easy to install and remove. The back was left open for air flow, only sides, front, and bottom are covered.
03-23-2020, 12:20 PM | #937 |
Most tinkering on these trucks is therapeutic for me. But, for some reason the patch panels seem like work to me.
03-23-2020, 03:01 PM | #938 | |
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! |
03-23-2020, 04:07 PM | #939 |
Took a break from refitting the front suspension to throw on my 'new' Road Runner camper shell.
I'm thinking it needs a chop (lose half the height of the chicken light strip?) but I'll have to see it on its wheels to be sure..
Barney, in the UK 1962 Chevy C20 1974 Ford Econoline 1987 Peugeot 205 GTi 1991 Peugeot 205 GTi |
03-23-2020, 07:49 PM | #940 |
Did final install (Lord willing) of my new gas tank. Next run a fuel line.
03-23-2020, 08:37 PM | #941 |
Installed the hood I bought from a guy on OfferUp, only to find that the passenger-side is dented, and I'll probably have to remove it to try to bend it back
1964 C10 LWB->SWB, 283->454, SM420->200-4R MECHANIC: "ME" |
03-24-2020, 12:46 PM | #942 |
I patched the passenger side cab corner.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
03-24-2020, 05:53 PM | #943 |
I would be interested in seeing this bracket.
My build link.. http://67-72chevytrucks.com/vboard/s...d.php?t=285353 |
03-25-2020, 11:10 PM | #944 |
I added some door switches and floor lamps to Frankentruck today. So much nicer being able to see when getting in or out of the truck at night
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
03-26-2020, 04:33 PM | #945 |
I ordered a Summit Trans Jack to help with the transmission switch, made in China, you can almost see the hand sanitzer stains........ It went together very well with no missing parts, even though the box was torn in one corner. The base on the unit is very heavy duty, there are 1/2" bolts under to holds the footing agains the verticle part of the base as well. Although I'm only going to use it once, I split the cost with a buddy who will need it as well, the total was only $175.00 with shipping ($10.00 more due to weight).
We considered renting one for a week but that ran $81.00 so it was cheaper to simply buy it vs. having to pick it up & delivery back to the rental place.
http://s1299.photobucket.com/user/jb...23904108567829 Last edited by jbgroby; 03-27-2020 at 09:35 AM. |
03-26-2020, 05:02 PM | #946 |
Probably a good move. Never know how long these 'simple' things end up taking.
03-27-2020, 09:33 AM | #947 |
Thats exactly what we were thinking.
http://s1299.photobucket.com/user/jb...23904108567829 |
03-30-2020, 08:29 PM | #948 |
Registered Loser
Finished up installing the Street Demon 750 on my 383.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
04-03-2020, 08:55 PM | #949 |
Installed Russell an-6 fuel line today
It fired up and no leaks (so far). Have not gotten to drive it yet |
04-12-2020, 03:33 PM | #950 |
A few weeks ago I went up with my son and put the rebuilt cross member back in the truck. The calipers would not fit and I remembered I had to do some grinding the last time I put drop spindles in one of my trucks. Went back up and got that all sorted out and was able to get the truck back on the ground. So right now I have a 3" drop in the front with stock springs in the rear. I am sure it will drop down more when I put the engine back it. I also have new springs in the front.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
