Old 12-29-2021, 06:12 PM   #926
65Custom
Re: Frankentruck
Originally Posted by cwcarpenter98 View Post
Ok, I got the arms flipped around to the correct side. It drove way better to the alignment shop, and overall just looks better. You learn something new every day!
Guessing the alignment turned out ok this time.
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=366677
I must be
65Custom is offline   Reply With Quote
Old 12-29-2021, 07:06 PM   #927
cwcarpenter98
cwcarpenter98's Avatar
Re: Frankentruck
It turned out much better this time.
The truck no longer wanders between the lines like it did before, and there's no bump steer.
I highly recommend the caster mod, even on a bone stock truck. Every other c10 that might come along in my future will get the caster mod
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 12-31-2021, 08:40 PM   #928
cwcarpenter98
Re: Frankentruck
I "cleaned up" the wiring under the hood by wrapping it in electrical tape. It was just the wires ziptied together before, so you could see all the different colors It looks less sloppy now
Christian Carpenter
Old 01-01-2022, 09:41 PM   #929
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Frankentruck
I replaced the rear shocks after over a year of driving it. The front shocks were replaced when the disc brake kit was installed.
So you used a disc brake kit using you stock A-Arms and crossmember?
The reason I ask is I wonder if the caster got increased with the 73+ trucks in that they all had power steering. The way I understand it is the older non-power steering trucks had less caster because more caster makes them more difficult to turn the steering wheel without power.
66 C20 Service Truck:
Old 01-02-2022, 01:22 AM   #930
cwcarpenter98
Re: Frankentruck
When I was looking for a kit over 6 years ago, I didn't find a kit that had a spindle using the stock ball joints and tie rods. The kit I chose came with a set of stock height, Western Chassis spindles manufactured to squarebody specs. The kit also came with new ball joints and outer tie rods to squarebody specs, a tie rod adapter sleeve, and new inner tie rods to work with the adapter sleeve and my stock centerlink. Since those wear parts needed replacing anyways, it worked out well.
I'm not sure on the squares if additional caster was used compared to the 63-72 stuff that was more commonly manual gears. What I do know is that the steering feel on the road at speed has improved so much that I wish I had done this years ago. How much it has affected the parking lot/low speed turning, I haven't done enough to really tell, but hasn't seemed too bad yet. As I drive the truck more and break the trailer out of hibernation if the back yard isn't too soft, I'll update on how it feels in parking lots and dealing with a trailer.
I believe I have what I need on the engine side of things for a power steering conversion if I decide to go that route, but since I replaced the manual steering gear with a Redhead gear, I'm not too inclined to change it just yet. If the manual steering with additional caster ends up being too much of a pain, I will probably convert to power steering before I revert to stock caster.
Another note on the steering feel. I've really only driven my truck, so I haven't felt how a truly stock suspension c10 drives. When I bought my truck, the previous owner had put the upper control arms on backwards at some point. I did not know that at the time, and since I didn't remove the uppers until last week for paint and new control arm shafts, I didn't know that they were on backwards. I only found out when I ended up with +11* of caster on one side and +9* on the other. The shop couldn't align it like that. I also can't find the alignment sheet from when I first got it aligned after installing the disc brake kit. It's possible that I already had some additional caster, but camber was more on the positive side of life. That might, and I mean might, be why the steering input doesn't seem more challenging that before.
Sorry for the essay, but I hope that answers your question!
Christian Carpenter
Old 01-05-2022, 07:33 PM   #931
cwcarpenter98
Re: Frankentruck
Ok, a report on the caster mod. I took an hour drive to a junkyard to get some parts. It had a couple miles of interstate driving. I don't have to steer between the lines anymore! There's no more heavy steering fatigue, so I definitely feel like I could drive all day without getting really tired. A couple years ago, I would have been completely worn out from driving over an hour one way. I definitely recommend this mod. The parking lot turning has not gotten harder, and almost seems a little easier. I believe that since the arms had been swapped before I purchased it, there was already some additional caster, but I had way too much positive camber. Unfortunately, I can't find the alignment sheet from 6 years ago, so I can only guess at this point.
Now on to the parts I went to get. The last modification I plan to do before heading back to Milledgeville for my last semester is new door check links. The aftermarket, stock set I got a couple years ago have already failed. I harvested a pair from a decent XJ Cherokee to swap in. The driver's side door of the Jeep was wedged against another truck, so I had to take it out of the driver's door and reinstall in the passenger door to make sure that it was still good. Thankfully it was, because most of the XJs there had already been picked over on the door checks. Best part was someone had already pulled the inner door panels, so I didn't have to fool with that
Christian Carpenter
Old 01-05-2022, 08:54 PM   #932
SkinnyG
SkinnyG's Avatar
Re: Frankentruck
Increased caster improves road "feel," self-centering, and stability at speed.
While you are attributing the "Caster Mod" as a worthwhile improvement (and it is, it is), what you are really seeing is your truck's "UNcaster mod" - getting the caster angle back to sensible.
I would imaging with 11° caster, you would have very heavy steering effort, which no doubt would tire you out.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 01-06-2022, 12:30 AM   #933
cwcarpenter98
Re: Frankentruck
I had not thought of it in that way, but you're probably right.
It drives about as good as my 95 Dakota now, so I'm going to have a hard time choosing which one to drive until summer rolls around and the no a/c makes the decision for me on most days
Christian Carpenter
Old 01-06-2022, 01:09 AM   #934
SkinnyG
SkinnyG's Avatar
Re: Frankentruck
You can piece together a complete under-dash AC system pretty gosh darn cheap. I think I'm into mine for aboot $400 CDN, shipped, minus the pump.
Old 01-06-2022, 12:24 PM   #935
cwcarpenter98
Re: Frankentruck
It's been awhile since I've looked at A/C systems, so I should probably look again, but also thinking of starting the rust repair before I do any A/C stuff
Christian Carpenter
Old 01-07-2022, 12:51 PM   #936
pdxhall
pdxhall's Avatar
Re: Frankentruck
I'm happy to see your camber mod problem has been solved. IMHO I would agree with you, rust is your biggest enemy and is only going to get worse. I'm also without AC but it is going to wait. I have found a couple of under dash units for that nostalgia look. As the weather warms up here in southern AZ it will become a bigger priority.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 01-07-2022, 01:04 PM   #937
cwcarpenter98
Re: Frankentruck
I started looking at some AC stuff last night, but I agree with you on the rust. I won't be able to start on the cab rust until I graduate in a couple months, but then I've also got my CPA exams to pass, so I really don't know when I'll actually start that I'm still going to enjoy driving it though!
Christian Carpenter
Old 01-07-2022, 01:12 PM   #938
cwcarpenter98
Re: Frankentruck
My toes, hands and face are cold, but the new to me door checks are in. It's a brisk, high 20s here in Hickory Flat today.
Since I was able to find the versions with rubber stops, I decided to trim one stop into 3rds rather than halves. I wanted a smidge more opening than what the cut in half gives. It worked great and the doors are still far from the front fenders.
I am getting about 30 inches of opening from the body line point to the door frame on both sides.
This is another mod that I recommend for all 60-66 trucks!
Christian Carpenter
Old 01-08-2022, 01:10 PM   #939
straight6chevyguy
straight6chevyguy's Avatar
Re: Frankentruck
Good work Christian. Keep it up!
1965 Chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 Chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 Chevy c20 350 4speed
1998 Chevy c1500 4.3L 5speed
1999 Chevy k1500 Suburban 5.7L auto 4x4
2002 Chevy s10 4.3L auto 4x4
1971 Mercury Monterey wagon 400 auto
Plus other misc. ... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 01-08-2022, 09:09 PM   #940
cwcarpenter98
Re: Frankentruck
Thank you! Won't be too much going on other than driving around for the next couple months as classes start back on Monday
Christian Carpenter
Old 01-08-2022, 09:12 PM   #941
cwcarpenter98
Re: Frankentruck
OSHA would not have approved.
The frame that I got my bed off of is headed to Alabama to go back underneath a truck
Christian Carpenter
Old 01-09-2022, 06:52 PM   #942
cwcarpenter98
Re: Frankentruck
And now, Frankentruck is back in Milledgeville for the next couple months. Interstate driving is much less sketchy now.
I've got 3 classes this semester to finish, then I will be graduating at the beginning of May.
Christian Carpenter
Old 01-13-2022, 12:11 PM   #943
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Frankentruck
That looks like John's Truck Farm with United by Trucks!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-13-2022, 12:27 PM   #944
cwcarpenter98
Re: Frankentruck
I figured someone would recognize the building at some point
It is John's (Flashed) Truck Farm, but John and UBT are no longer working together.
Christian Carpenter
Old 01-13-2022, 12:33 PM   #945
aggie91
aggie91's Avatar
Re: Frankentruck
Did not know they parted ways. I met John a couple years ago, really great guy!
Karl
The LST Challenge:
Old 01-16-2022, 09:58 PM   #946
cwcarpenter98
Re: Frankentruck
No snow here in Milledgeville, but mom sent me a couple pictures from back home that almost made a big sad.
For the stuff I can't keep in the garage, a tarp over the trailer is the next best storage spot. I have 3 rear bumpers keeping the tarp from holding a bunch of water
Christian Carpenter
Old 01-18-2022, 10:44 PM   #947
allaboutchevelles
allaboutchevelles's Avatar
Re: Frankentruck
Nice looking build. Your truck is the same green mine came from the factory as. Mine was also a long bed.
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 01-19-2022, 01:49 AM   #948
cwcarpenter98
Re: Frankentruck
Thank you! I noticed the green in your windshield frame when I was reading through your thread. Seems to me that the dark green was chosen for new trucks much less than other colors
Christian Carpenter
Old 01-19-2022, 04:25 PM   #949
Apache1961
Re: Frankentruck
Did you end up not doing the ball joint flip? I still need to swap the 87 parts I got onto my 61 and plan on doing the caster mod, but was not aware of the ball joint mod. I know taller ball joints are popular on Chevelle front suspension's.
Apache1961 is offline   Reply With Quote
Old 01-19-2022, 05:11 PM   #950
cwcarpenter98
Re: Frankentruck
I chose not to use a taller ball joint for one reason. The ball joints I installed 6 years ago were still in good shape. I might go that route when they need to be replaced again, but that'll hopefully be a long time from now
Christian Carpenter
