Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 08-17-2014, 06:06 PM   #951
swyfor5
swyfor5's Avatar
Re: My new build thread: Stage 4!
Stop and pick up a little more gear oil tomorrow and diff cover swap will be done. Front diff is full, just have to top off the 14 blt rear! The Ballistic covers have way more capacity than the stock ones! Anybody know if a GovLoc needs additive? Currently running 3:73 gears, but planning on swapping out to 5:13's so I can run 40"-or 42" Nitto rubber.
swyfor5 is offline   Reply With Quote
Old 08-17-2014, 06:11 PM   #952
swyfor5
swyfor5's Avatar
Old 08-17-2014, 06:13 PM   #953
swyfor5
swyfor5's Avatar
Double post, oop's!
Old 08-18-2014, 04:09 PM   #954
swyfor5
swyfor5's Avatar
Got it done today. 12 more ounces of gear oil and rear is good to go. Need to fire it up next, and move it around a bit, then recheck the levels front and rear. NO LEAKS!
Old 08-22-2014, 07:12 PM   #955
swyfor5
swyfor5's Avatar
Got the gas tank skid plate reinstalled tonight. Happy, happy,happy! Need to do a little touch up paint, but it's on there! Pic's!Name:  100_0712.jpg
Old 08-24-2014, 06:50 AM   #956
swyfor5
swyfor5's Avatar
Got it fired up and out of the pole barn. Cleaned up the floor from the diff cover swap. Getting the other q-jet carb rebuilt this week. One step at a time!
Old 08-24-2014, 07:47 PM   #957
swyfor5
swyfor5's Avatar
Tried to mock up the ORD steering box brace kit today. It will not be a direct bolt in, my brake lines-prop valve are in the way. Need to rethink this, and move some stuff to make it fit!
Old 08-24-2014, 08:27 PM   #958
mx289
mx289's Avatar
Congrats on getting it fired up.
Its always something right ?
Tom
71 K2500
71 K5 Jimmy
mx289 is offline   Reply With Quote
Old 08-25-2014, 03:48 PM   #959
swyfor5
swyfor5's Avatar
Right, MX289! I need to think this through well as all my brake lines are brand new. Lines might have got routed a little different when the 1 tons got swapped in. Where there's a will, there's a way!
Old 09-03-2014, 05:20 PM   #960
swyfor5
swyfor5's Avatar
Turns out some linkage is missing off my carb being rebuilt. Should be able to transfer some from the q-jet on my motor now. Linkage for the choke and the secondarys. Know more tommorrow.
Old 09-03-2014, 06:24 PM   #961
swyfor5
swyfor5's Avatar
I could'nt wait, went out and took some pic's of the current dirty carb setup. I admitt, I know nothing about carbs-but it looks like some major linkage is missing off of the carb I have been running for quite some time.I put a call in to John, and possibly meet up yet tonight to see what he has for spare parts at the shop. Here's some pic's!Name:  100_0717.jpg
Old 09-03-2014, 09:18 PM   #962
swyfor5
swyfor5's Avatar
Came up empty at CHOAS tonight. Looks like I will look for new linkage parts starting tommorrow!
Old 09-04-2014, 08:12 PM   #963
swyfor5
swyfor5's Avatar
Not trying to break any rules here, but can any members help me out with some linkage? Got the newer carb almost done, and need some linkage to hook it up right. Looking at some new air cleaners also to spruce it up a bit! HELP MY BROTHERS!
Old 09-05-2014, 07:34 AM   #964
jaros44sr
jaros44sr's Avatar
Let me look at my NOS guadrajet, and i ll be able to see what pieces are missing....i would call ruggles for parts
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-05-2014, 08:33 AM   #965
jaros44sr
jaros44sr's Avatar
Hope this helps....linkage for the front pull off is laying on top of carb
20140905_080656 by [url=https://www.flickr.com/people/97391199@N06/
SAFETY FIRST
AS usual, off topic
Jim
Old 09-05-2014, 08:37 AM   #966
straps57
Nice. Keep us updated
straps57 is offline   Reply With Quote
Old 09-05-2014, 06:07 PM   #967
swyfor5
swyfor5's Avatar
Thank's Jaro, yes that pic helps. Just ordered up a secondary linkage rod from Quadrajetparts.com Same place I bought all my rebuild parts for the replacement q-jet from. Going to wait on the choke replacement parts until I swap in the 383 to see what I need to set up on the intake manifold. Been running without a choke setup for this long, I can wait a little longer for that!
Old 09-07-2014, 07:06 AM   #968
swyfor5
swyfor5's Avatar
Finally found the 4 row radiater I wanted! Just ordered it up. I will have to modify my new core support a bit, but that's no problem. Ran me $350.00, but only $15.00 shipping!
Old 09-07-2014, 05:04 PM   #969
swyfor5
swyfor5's Avatar
Cleaned up and repainted my new to me 4 core top and bottom radiator brackets. Bought used a while a go, rubbers could be replaced, but these will do. Just waiting on the new radiator!Name:  100_0721.jpg
Old 09-07-2014, 05:07 PM   #970
swyfor5
swyfor5's Avatar
Last pic is one of a stock top mount next to a 4 row mount!
Old 09-09-2014, 03:30 PM   #971
swyfor5
swyfor5's Avatar
Anybody else running a 4 row in a 1st Gen? Pic's anyone?
Old 09-11-2014, 03:55 PM   #972
swyfor5
swyfor5's Avatar
Got the new radiator yesterday, and it looks great. Came with lines capped off for use with an auto trans also. I got the secondary throttle rod and retainer linkage I needed for the q-jet I'm getting rebuilt. Getting there one part at a time!
Old 09-17-2014, 05:17 PM   #973
swyfor5
swyfor5's Avatar
Got a new windshield rubber today. Bought it from Precision replacement parts. Looks real nice. Makes 11 of about 20 pieces that will need replaced. Getting there! Just need to find a new windshield also!
Old 09-18-2014, 03:04 PM   #974
swyfor5
swyfor5's Avatar
Removed my current (dirty) Qjet carb last night. Hoping we can strip some choke parts/linkage and use on the rebuild!
Old 09-26-2014, 08:21 PM   #975
swyfor5
swyfor5's Avatar
Just got my last daughter her drivers license. Oh my, here goes my insurance rate again. She takes over the GMC envoy, Blazer fund is taking a hit!
