05-09-2015, 04:21 PM | #951 |
Re: What did you do to your truck today part III
Bodywork ugg!!! These pieces are from my 65. I plan to finish ALL the bodywork, priming, wet sanding, then it's matte black time. Next week cab meets frame!!!
05-09-2015, 04:32 PM | #952 |
Active Member
Finally got the steering arm loose, good weekend so far! Replacing studs next.
05-09-2015, 06:23 PM | #953 |
According to one of the guys at Proformance powertrain you can use it all the way back there as long as a 3 inch forward shift lever is used. But yes, I can move it to the center if need be....its only another $400 for the stinkin shifter.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
05-09-2015, 06:33 PM | #954 |
just a 1/64 scale model, got all the pieces hanging beggin to be painted!!!
05-09-2015, 06:35 PM | #955 |
check out my $20 hood rotissorie jig...
05-09-2015, 09:14 PM | #956 |
Washed the '63 Thursday evening. Friday, waxed and generally cleaned up real good for the Buggy Festival in Carthage, NC on Saturday, May 9. I thought my truck looked good until I saw some of the other trucks parked around me.
Hugh |
05-09-2015, 10:44 PM | #957 | |
That's one VERY SWEET lookin' truck you have and it can stand proud in any show. Hold your head high and be proud 'cause it's a great looking truck. Thanks for sharing.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
05-10-2015, 12:38 AM | #958 |
Looks dang good to me
05-10-2015, 10:19 AM | #959 | |
Posted via Mobile Device |
05-10-2015, 10:24 AM | #960 |
I spent the day yesterday putting the engine and transmission back in the 62. Looks like I might have to modify the trans crossmember. Try to get some pics this afternoon.
05-10-2015, 11:27 AM | #961 |
Hey Pappy, I cut my original manual crossmember out. The old adage "when in doubt, weld alot" was used on my frame. 2 Sawzall blades and couple cut disks.
Been working out of town so making the list and trimmed fenders for ground attack.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
05-10-2015, 01:23 PM | #962 | |
Someone has already taken the MT crossmember out when they put the v8 in. I changed the front crossmember, motor mounts to to an 81 for the disc brakes... Looks like the engine and trans are moved back about an inch or so. I have a cpp tubular crossmember that I'm thinking of using, but will have to see how it fits up. Posted via Mobile Device |
05-12-2015, 08:16 AM | #963 |
Here's a few pics of the engine/trans back in the 62, and first time it's been back on the floor with all the changes that have been made.
Pappyx4!
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400 1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver John 3:16 |
05-12-2015, 12:21 PM | #964 |
Experimenting with Buick hinges
05-12-2015, 03:03 PM | #965 |
Got a break and finished fit checking the mild porterbuilt crossmember, DT headers, the LS3 and the CPP drop spindles and Baer brakes. Need to figure out the steering linkage and some bump stops next, pull it all back out and send for powder coating.
05-12-2015, 10:02 PM | #966 |
More stuff!
05-12-2015, 11:05 PM | #967 |
05-12-2015, 11:46 PM | #968 |
Boulevard black.
05-13-2015, 03:26 PM | #969 |
nice!!! i should be spraying by months end... also i got my 2 NOS front rubber brake parts in today!!!
05-13-2015, 09:57 PM | #970 |
Finally!!
A ground wire to the body does wonders for my lights (Duh) I need to rebop a stock steering column, which is a mix of stuff, into a 66 column. Anyone have a pic of the entire assembly or a link to one? The components I've got won't go together. Thanks, W |
05-13-2015, 11:36 PM | #971 |
Pulled the bed off...getting ready to start the frame off.
05-14-2015, 04:26 PM | #972 |
Tore more of it down today. Slowly but surely. Pictures later.
05-14-2015, 05:45 PM | #973 |
Got the radiator out, heater hoses out, will get the rest of the front off the weekend and motor ready to come out. Also crawled around under a truck in the junkyard and got me a T5 for the build back.
05-14-2015, 08:04 PM | #974 |
05-14-2015, 08:12 PM | #975 |
93,v6 S10.
