Old 12-11-2015, 09:03 PM   #76
85raiderburban
85raiderburban's Avatar
Cool my first 3/4 ton...
First off I would like to say, my FIRST 73-91 Burb was an '85 GMC c1500 sierra classic black/silver two tone with a 305/700r4/3.73 (HD towing RPO). That, I dont have pictures of.
Now my current 'Burb (and hopefully till the grave) is an '80 C20 Silverado trim 454/th400/14 Bolt FF/3.73?(possibly 4.10?)
Factory exterior color was dark camel. Now its a light camel with chipping clearcoat. The front grill is not original but looks clean. The original engine has been swapped to a '91 Gen V 454 but converted to Edelbrock intake & carb. I have a toggle switch for the external low pressure electric pump mounted near the tank. It has front and rear A.C., electric rear tailgate window, a quarts (clock?) gauge but NO 3RD ROW option. Thats a definite first for me.
*UNDER CONSTRUCTION*
'80 Suburban C20 (C6P) (Silverado)
- '68 472 (Edelbrock 1813, PH8026 LT's, H pipe) / '91 4L80 (manual shift,vac modulator, 350 converter) / 14B FF 3.21 G80 34' s/ '96 GMT400 interior
85raiderburban is offline   Reply With Quote
Old 12-11-2015, 10:03 PM   #77
85raiderburban
Cool more pics...
under the driver side (long tubes), the quarts guage and cold start at nightfall. The license plate light housing was damaged so i replaced with an LED bulb. $140 ticket out here in AZ if a road pirate can't see your plate
Old 12-15-2015, 04:10 AM   #78
85raiderburban
more pics...
custom audio in the back cab and on another rainy day.
Old 12-16-2015, 03:57 AM   #79
BodyDropInc
Re: The first ever 73-91 Burb post your ride thread!
Whats up ladies and gents heres my 1990 gmc bagged on 22s smothies, i need to tub it front and back to make it lay. Any pics, info, links to build threads will greatly be appreciated
BodyDropInc is offline   Reply With Quote
Old 12-16-2015, 01:02 PM   #80
Nodnarb76
Nodnarb76's Avatar
My 1987 R20 Suburban.
LQ4 and 4L80E on the way!!
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 12-16-2015, 01:27 PM   #81
Electricduane
My 1989 GMC V2500 Suburban. 6.2 diesel. It had a "vegetable oil" kit on it, what a mess! I am removing and selling the kit. 4" block lift, new injector pump. Mediocre quality newer paint job. Rear A/C, 3rd row seat. I have big plans for it all. Best of all, CA smog exempt!!
Electricduane is offline   Reply With Quote
Old 12-16-2015, 09:11 PM   #82
Front Range
Front Range's Avatar
Good to see guys are still working on the Burbs, I never get tired of seeing what other people have built.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you.
Front Range is offline   Reply With Quote
Old 12-28-2015, 08:10 PM   #83
Nodnarb76
Nodnarb76's Avatar
I want to see more burbs!
Old 12-28-2015, 11:06 PM   #84
USSkoval
Re: more pics...
Um yeah... that's a clock I see your Burb also has the '80-only optional front door speakers.
My '88 Burb was also a weird one with rear AC but no 3rd seat option. I added the 3rd seat though, Burbs are meant to haul people!
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 12-29-2015, 02:37 PM   #85
LiveAnimals
LiveAnimals's Avatar
Some of my old Sub
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline   Reply With Quote
Old 12-30-2015, 09:47 PM   #86
bealaddison
bealaddison's Avatar
Here is my '87 V20 Suburban. Just finished up a re-hash of it. Dana 60 front with cross-over steering. Corporate 14bolt with a Detroit locker. Lower mileage tbi350 backed by a sm465 mated to a np205 transfer case. 6in lift sitting on 37" Toyos/Nittos.
'87 Chevy V20 Suburban
6in Lift, 37in Toyos/Nittos on 17x9 KMC Diesels
2009 Chevy Silverado 2500HD
6in Lift, 35in Toyos on 20x9 KMC Monsters
bealaddison is offline   Reply With Quote
Old 01-02-2016, 03:17 AM   #87
4 Wheelin Fudpucker
4 Wheelin Fudpucker's Avatar
My 79 Burb had been beat before I ever saw it. It lasted two years, then the motor took a dump, and the rear is a screaming for attention. I took the 2 grand I had saved up, and bought this 78 instead.
Paint is darn near perfect. 6 inch lift, $1200 new tires and wheels, and runs like a dream.
I do need to get the wipers to work, and the heater core replaced, but I dot my monies worth.
Happy as a pig in mud
4 Wheelin Fudpucker is offline   Reply With Quote
Old 01-02-2016, 09:11 AM   #88
87Skier
87Skier's Avatar
Got mine about 9 months ago. I suspect it was parked for a little while because it had a bad distributor. Needed new seatbelts, new drivers seat, some work on the interior. Added keyless entry, remote start, some fog lights behind the grill, updated to electronic speedometer.
Would like to repair the little bit of rust it has, clean up the few bumps and scrapes and paint it. As it sits, its pretty ugly, but it was cheap and it's reliable.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 01-15-2016, 12:15 AM   #89
krazy_texan
krazy_texan's Avatar
here is my 1990 v1500 been my daily driver for 3 years now
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 01-21-2016, 10:00 PM   #90
AsianBlazer
Active Member
AsianBlazer's Avatar
My 1976 GMC Suburban Sierra Classic 1500 2 wheel drive, 454ci, th400. Has a 14 bolt rear end, tow package, front and rear air conditioning, cruise, tilt wheel. Bought it with 30k miles on the rebuilt 454 and have only driven it about 500 miles. Thinking about lowering it, new wheel/tire combo and just driving it, its nice and drives really well.
AsianBlazer is offline   Reply With Quote
Old 01-21-2016, 11:28 PM   #91
Nodnarb76
Nodnarb76's Avatar
Great looking Burb!, looks like it was stored in a time capsule.
Old 01-21-2016, 11:55 PM   #92
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Updated pictures of the Polar Bear Burb….now powered by an 8.1L
DirtyLarry is offline   Reply With Quote
Old 01-22-2016, 03:30 PM   #93
AsianBlazer
Active Member
Thanks Nonarb76! I've had to do some work to it, new hood and front passenger door, resprayed it the factory ppg 2188 "Hawaiin Blue", but added the white two-tone, looks period correct. New carpet, headliner, and stainless trim as well. Just a great driver, might sell it, might keep it!
Old 01-27-2016, 10:51 PM   #94
1970SWB
1970SWB's Avatar
I was considering using these wheels on my '84 but was told the backspacing is different, did you use spacers or are the wheels "tucked in"? What size tires are those? And lastly is yours 2wd or 4wd?
Thanks in advance. I have an '84 2wd, & use it to pull a 26' enclosed car trailer so I need to use the "E"-load range tires
John Stevens,
ASE master auto tech., ASE master autobody tech.
I-car platinum certified
'70 Chevy SWB pick up
'77 Chevy SWB 4X4 PU
2 '70 Buick GS Stage-1 4-spds
1970SWB is offline   Reply With Quote
Old 05-13-2016, 03:15 PM   #95
buffydores
buffydores's Avatar
This is such a gorgeous Suburban. Fabulous color. Great wood grain. Plush seating. I'd be proud running the roads in that.
Old 05-13-2016, 06:29 PM   #96
AsianBlazer
Active Member
Thanks Buffydores! I appreciate the compliments, the color is the original 1976 GMC Hawaiian Blue, it's been a fun truck to goof around with, and it really is just a nice driver for being 40 years old!
Old 05-13-2016, 09:21 PM   #97
Nodnarb76
Nodnarb76's Avatar
Sorry haven't checked this thread in a while.
There aren't any spacers on the wheels they fit perfect. Tires are 305/70/16 Nitto Terra grapplers. The truck is a 3/4 ton 2wd.
Old 05-14-2016, 02:23 AM   #98
zaccaglin
zaccaglin's Avatar
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 05-22-2016, 10:53 PM   #99
buffydores
buffydores's Avatar
The Hawaiian Blue is the best color. It's so rich and bright. Don't get too crazy on the mods, your rig is spectacular already.
Old 08-21-2016, 07:51 PM   #100
85raiderburban
Re: here is what i have statred with
Originally Posted by bisquik65 View Post
pic of 80 3/4 4x4
Damn that's a clean '80. i want those size tires. Looks bad ass
