Old 10-24-2006, 10:13 AM   #76
timcos
Chief Honcho In Charge
timcos's Avatar
Re: Autometer Cluster Projects
Oh we care...for sure.
Nice job on rewiring.
Would love to know more about the Molex style connector and how you fit it all together...I love pictorials like this.
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 10-24-2006, 12:06 PM   #77
-Greg72
-Greg72's Avatar
You mean this one...?
Back when I had a Fry's Electronics store just up the street, things were easier.... I just spent some time looking at the wiring schematic, and made sure I understood what all the wires in the factory "flex circuit" connector did. (mostly, it's power feeds, grounds, and the sender wires for individual gauges).
Then I went through systematically, one wire at a time, and cut a factory wire, and crimped it into the new Molex fitting.....all the while making careful notes about each wire and it's position in the Molex socket (there are REALLY small numbers embossed on Molex connectors that you can see if you have good eyes).
Later, when I was doing the gauge wiring.....
...I made sure to use the same socket positions that I had previously selected in the earlier step. It doesn't matter what you choose, as long as it's consistent on BOTH sides of the connector!!
Many of the wires are "ganged" together on the gauge cluster (lots of common 12V wires, lots of grounds) and then ultimately travel through a single connector on the Molex.
The nice thing about having the Molex there, especially with a decent sized "service loop" of wiring harness, is that the whole thing can be removed pretty easily for service or whatever...It's a work in progress (what part of my K5 isn't) so I didn't bother to use a nice bezel yet. Mostly it was a "feasability experiment" that just happened to turn out really nice. When the time comes, I will swap the cluster behind a nicer bezel and do some more work on the gauges to try to make them look more "factory"......needle colors and shapes need to be changed, font style, color, etc.
It never ends.
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s
Find me on INSTAGRAM @MIGHTASWELLK5
'72 K5 - Greg's "Might As Well™" Build
-Greg72 is offline   Reply With Quote
Old 10-24-2006, 02:23 PM   #78
timcos
timcos's Avatar
Makes a lot of sense...your methodology.
Goofy questions here...
Couldn't you find a conector that would mate up to the connector on the wiring harness? O is there some advantage to the Molex style connector?...updated materials? better crimping for beginners? etc?
I used to do a lot of wiring in the Navy...I could see myself using Amphenol brand connectors with metal casings...etc. Yeah we overdid it a bit in the nulclear waepon field...but overkill was good. And they were extremely resitant to water and vibration.
I also take from your pics that you did not use the mylar with the printed wires (or electon flow routes) and you are using your wiring instead.
Cheers,
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 10-24-2006, 02:36 PM   #79
-Greg72
-Greg72's Avatar
That would have been sweet, but I don't have those THICK connector catalogs to reference, so I used the Molex that was available at the time.
What's weird about the "stock" connector is that the pins are all on the OUTSIDE of the block....this allows them to make contact with those wide traces on the flex circuit. I suppose with some research there MIGHT be a way to find a compatable female socket for the stock harness .......that would be AWESOME. Any time I can avoid cutting up an original part, I'm always happier.
Old 10-24-2006, 03:17 PM   #80
timcos
timcos's Avatar
I see...wish I had big fat catalogs too.
So are you using that flex circuit? Or have discarded that in place of your wiring...which quite frankly looks great.
Where in NH are you...I used to live in Dover and Portsmouth...on of my boys was born in Newington.
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 10-24-2006, 06:59 PM   #81
mac
Active Member
mac's Avatar
One thing about Mil Spec Amphenol connectors is that for the military "cost is no object". A cheap 7 pin can cost $100 a side. The cost can escalate to as much as $6k for one aircraft pressurized bulkhead connector.
Molex is a great way for all of us hobby truck guys to "get 'er done". Nice post and explanation of how to do it.
Take a look at this site for some ideas www.waytekwire.com
Mac
mac is offline   Reply With Quote
Old 10-24-2006, 08:58 PM   #82
-Greg72
-Greg72's Avatar
The flex circuit is completely gone.... there was not much use for it anymore.
The bottom four gauges, and the center-mounted tach got all new wiring, the fuel gauge has only a single sender wire (which I just replaced with a ring connector and some shrinktube.....and the speedo is mechanical.
Now that I think about it, there was some additional "clever" stuff I had to do to make the backlighting work on the original fuel gauge and speedo. The backlighting uses those 1/4-turn sockets that used to get power from the flex circuit.....so I had to "improve" them to use the same 2-wire system that the Autometer stuff does.
Looking back, this project was a tremendous amount of work.
Oh yes, and the town I live in is called Keene (southwest corner).....home of the film Jumanji, and the previous Guinness World record holder for most carved and illuminated pumpkins in one place (~28,500 of them)
Old 10-24-2006, 09:15 PM   #83
timcos
timcos's Avatar
I have been to Keene many times.
When I was a computer software/hardware rep I called on a few places in Keene...then over to Milford to PC Connection.
What was the clever stuff for backlighting...how did you improve them?
I am sure it was all a labor of love.
Cheers,
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 10-25-2006, 06:01 AM   #84
mike nutt
69fatmotor
mike nutt's Avatar
here's mine
mike nutt is offline   Reply With Quote
Old 10-25-2006, 06:11 AM   #85
watahyahknow
watahyahknow's Avatar
thats a clean looking dash , you could put 2 more gauges in it with this setup
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 10-25-2006, 07:14 AM   #86
-Greg72
-Greg72's Avatar
Well the original sockets use small perimeter contacts that touched the flex circuit (one for + and one for -), so simply attaching them to the housing with the mylar removed does nothing....
What I had to do was drill through the back of the connector and solder wires directly to the bottom and side terminals in the socket to provide power that way. Then, I had to trim off the original contacts to keep them from shorting-out on the bare metal of the gauge housing.
(This is how I remember it anyway....it's been about 3 years and I couldn't find a photo that showed the detail)
Conceptually, at least you understand the objective now and why you can't use the original setup once the mylar is removed.
Old 10-25-2006, 08:30 AM   #87
kbs71
71 rustless in texas
kbs71's Avatar
You can just go out and get side marker light sockets. They have 2 wire attached. Hook one up to your 12V light source and ground the other end. They fit right in the 1/4 turn light socket areas on our dashes.
"The secret to creativity is knowing how to hide your sources."
"No one really listens to anyone else, and if you try it for a while you'll see why"
71 C-10 LWB presently in a perpetual state of disassembly
'96 Toyota (my work car)
'04 Mustang Convertable (wife's car & other money pit)
Latest aquesition and why my trucks still in the garage covered with junk..
2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck
FAQ here
VENDORS here
SUPPORT THE BOARD here
My second favorite SITE
kbs71 is offline   Reply With Quote
Old 10-25-2006, 08:37 AM   #88
kbs71
kbs71's Avatar
I just priced a 12 pin MIL spec connector $860.00, for both sides, backshell and pins. This doesn't include the special tooling required to crimp the pins (you can't just use a regular crimper, it take a "calibrated" crimper to attach the wires to the pins). So yo guys that are thinking "Hi-tech aircraft parts, COOL", Hope you got REALLY fat wallets. Besides a lot of aircraft manufacturers interior connectors are going to the same type connectors as the Molex, i.e; Snap together. It's cheaper.
FAQ here
VENDORS here
Old 10-25-2006, 09:48 AM   #89
timcos
timcos's Avatar
Not to mention the milspec insertion tool.
I should have taken any handfuls when I left the Navy. I used to clean out drawers of them on the submarine to save space. Can't tell you how many I tossed.
A good joke on junior officers first reporting to the boat was to stand out of eyeshot but within earshot and tell your buddy that you were going to do some amphenols after lunch. It would eventually make it back to the wardroom as the young officer was doing his duty...reporting drug use to the captain.
Oh yeah...and even better is having him go back and get 50 feet of fallopian tube from the womb locker.
I just crack myself up.
Until I made Chief...I acted like a hooligan.
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 10-31-2006, 03:44 PM   #90
76bonanza
76bonanza's Avatar
kbs71 the side marker sockets you speak of are they the ones for our year trucks?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 10-31-2006, 08:27 PM   #91
bskylerj
bskylerj's Avatar
Originally Posted by 70clone View Post
where did you get this at i want one
I ordered this and the matching glove box door cover from Covans Classics. I then added the boost gage and the shift light.
bskylerj is offline   Reply With Quote
Old 10-31-2006, 11:48 PM   #92
kbs71
kbs71's Avatar
Yes the same as for our truck. and most other vehicles up to @ 98.
FAQ here
VENDORS here
Old 11-22-2006, 07:02 PM   #93
jackyl9999
jackyl9999's Avatar
Here is my gauge cluster that I am working on.
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e)
1990 K1500 Daily
jackyl9999 is offline   Reply With Quote
Old 11-22-2006, 08:01 PM   #94
djracer
djracer's Avatar
looks good!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 11-22-2006, 08:07 PM   #95
67chevemall
67chevemall's Avatar
Very nice! Center hole 4 your klenix...lol
67chevemall is offline   Reply With Quote
Old 11-22-2006, 10:55 PM   #96
jackyl9999
jackyl9999's Avatar
Im having to fab up a aluminum plate to mount my clock in the center hole.
1990 K1500 Daily
Old 11-23-2006, 03:48 PM   #97
bobw2867
bobw2867's Avatar
Here's mine
bobw2867 is offline   Reply With Quote
Old 11-23-2006, 07:56 PM   #98
watahyahknow
did you airbrushed that or used steelwool on aloy
Old 11-23-2006, 08:26 PM   #99
bobw2867
bobw2867's Avatar
Thats a 2in ginder with a scrotch brite pad on the back of aluminum plate.
Old 12-29-2006, 12:21 PM   #100
jackyl9999
jackyl9999's Avatar
Completed gauge cluster in the truck.
1990 K1500 Daily
