#76 |
Re: Project: Slow Build
#77 |
![]() Join Date: Mar 2004
when you moc'ed up the fenders and front grill did you have anything under them to hold them up or did your tip and flip hold it up without anything?
i'm curious as it would be a conviant way to do hood hinge mods among other things without the frame in the way. ondrew |
#78 | |
#79 |
#80 | |
Kevin LFD Inc. |
#81 | |
Man that is awesome. I envy you and the shop/equipment you have and your skills. I would kill to have the equipment to do what you're doing. Someday..... someday.
I want to see this thing done, it's just freakin awesome is all I can think to say lol.
1968 Chevy SWB C/10 Stepside, completely torn down. 1968 Dodge Charger R/T 1989 Honda Accord LX-I 1996 Dodge Ram 1500 SWB Club Cab Race Truck 1996 Acura Integra GS-R 2000 Dodge Ram 1500 SWB Single Cab Quote:
#82 |
29* out this morning
![]() ![]() Kevin LFD Inc. |
#83 |
Damn Its looking good. How much would you charge me too raise my floor bed?
#84 |
I think Teflon would wear through with not a lot of scrapes (would slide easy though!!!). If you made a skid plate out of steel, you would have happy sparks!!
Another option you might consider would be phenolic (the stuff race car skid plates are made of). Aircraft Spruce carries it in sheets that can be cut with ordinary woodworking tools. http://www.aircraftspruce.com/menus/me/phenolic.html |
#85 |
wow. that's actuly one of the cleanest bed floor mods i've seen. it maintains the usefull ness of the bed "it is a truck after all" but allows the bad ass drop. kudos man. i'd seriously love to just watch you work for a week. i really think i'd learn alot.
thank you for the endless ideas and photos they really are a blessing to the board. ondrew |
#86 |
Commander Taco Bello
the bed floor and stance look awesome!! I would be a bit worried about the gas tank though. It seems to be awful low, even if it's only that low when aired out.
what happens if you blow a bag while going down the high way?? |
#87 | |
Phenolic will wear out just as fast as teflon, it's just fiberglass cloth and a special type of resin. We used to make mold-friendly scrapers from phenolic sheets when I built UAV Aircraft from carbon fiber. We made our own molds, vac formed the parts, and assembled the planes and test flew them. The phenolic worked great as a hand made scraper because it was hard enough to hold an edge to scrape off bits of resin on the mold surface, but soft enough it didnt scratch the mold.
If anything, I would use some 3" or so steel wheels for heavy work tables or such, make a couple brackets that had the wheels come down by each side of the tank near the rear, and have the wheel stop the truck from dropping when the tank has at least an inch of clearance from the ground. This gives a solid stop to the truck's drop, it wont wear out any time soon, and will protect the tank. They could even be made to be easily removed with a couple heavy duty Category 1 tractor three point pins like our brush hog and other impliments are held on with. Like two studs sticking out from the frame. then have a plate about 1/2" thick with two holes in it and a couple thick spacers to stabilize the plate on the pins welded to the plate, and a pin or bolt to attach the wheel. Then at show time they could be removed, but put back on for street driving just to protect your ass end. Just a thought..... ![]()
#88 |
Thanks for the tank input but I think it will be fine. It will have 2" of clearance when a "bag blows" on the freeway right now but it is getting larger rear and front tires and that will add more room. I think my rears are 26" tall (335/35/17) and I will be going to a 29" tall tire shortly after getting it on the road so that will give me 3.5" Yes I know the teflon will wear fast but a 1/2" sheet will protect it from the rare small bump when cruising at full bump.
Kevin LFD Inc. |
#89 |
THE VILLIAGE IDIOT
its looking good..glad to see you get some time on your own..now its time to go back to making money for your truck..funn how that works out isnt it...your doing a great job..
honestly honey,,i have no idea how that truck got here. ![]() |
#90 | |
#91 |
Here is a small update. No work has been done at all! But I have been buisy on the phone and I have all my exterior trim on it's way. I am going with a 68 look on my truck and it will have all the exterior trim that was available on these trucks. Full side lower molding, headlights and grill openings, front fender noisings and hood front edge, tailgate upper molding and hockey puck tail light surounds. Rear cab paint divider strip and front and rear window trim. I will also be going with chrome vent windows and the window scrapper felt with the trim if it is offered but have not ordered these parts yet. I also have the colors picked out, my insperation was John Fabris's truck below. He gave me the colors he used but when i was at San Leandro color I was going thru color books and found a different blue to go with that is a solid color with out metalic in it.
I also ordered a new EFI harness and computer from Painless it is their "Perfect system" for LT1's that should solve my computer/wiring problems I have been having for going on 6yrs now. That has been one of the main reasons my truck has not been completed sooner. I would get started on it and get to the point of wanting the motor fired up before tearing down the frame and it just would not start so I would get pissed and shove it back in the corner hopping it would fix it self ![]() So now with the new EFI set up comming I can finish up the frame and drivetrain. With the trim I can get all the holes drilled and ready for body work to start. Then paint and put it all together. I hope to get it done before July because that is when we are expecting our first child and I know after that it will be hard to find time for awhile. So that is all that is going on here. To all of you that have been following my builds this year Thank You! It has helped me keep focused as much as I have been between by build and all the others so again Thank You! I hope eveyone has a Great Christmas and a safe New Years! Kevin LFD Inc. |
#92 |
TTT.... I love this one.
#93 |
I agree, Scoti. I am waiting to see this rig DONE.
Kevin, I love the idea of full trim you're doing. With the Ralley wheels and full trim, this will be a sick blend of resto/custom. |
#94 |
Well I finaly got around to putting the front end on for trial fitment. I cut out for the tire stuff clearance issue I had before and now with the tilt I have no problems. I do still want to go to a larger tire (27") then my 24"s right now. All I will have to do is trim just a bit more off the fender hinge area. Here are a few pics.
Kevin LFD Inc. |
#95 |
Post Whore
![]() Join Date: Feb 2000
Lookin' great - really like the tilt hood.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#96 |
Wow it has been awhile since this has been touched. I just took down the tent garage that the truck was in. I am having a new power service dropped and the meter is going right back behind were the tent was so no more garage for Slow Build
![]() ![]() So I fired it up and keeped an eye on it because I have never had the fans pluged in and did not know if they would kick on or not. Well once it hit 190* the fans kicked on and for the next 35min at idle the temp never went over 195* So now I juess it just needs everything else and it will be ready for a road test! ![]() Here's a few pics and the 70 has a 4.5/7 drop! Kevin LFD Inc. Last edited by Rokcrln; 06-13-2007 at 09:43 PM. |
#97 |
Damn that BITC^ looks bad. Finish it for sure. It looks mean sitting so low
#98 |
#99 |
cant wait to see it done but hate to see it go
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
#100 |
Yeh I agree but it will be so worth it. I was sitting on the job at 2am this morning watching them stock sheetrock I started a list of mods and items that will be done on the 70 2WD Blazer. I have 7 full pages
![]() ![]() Kevin LFD Inc. Last edited by Rokcrln; 06-14-2007 at 02:39 PM. |
