#76 |
Re: Idea on cleaning up the back end...
You know my manager?
![]() Last edited by Shane; 03-19-2007 at 09:32 PM. |
#77 |
GEARHEAD
I just read/looked at the whole thread for the first time all I can say it I LOVE IT. Dare to be different. GR8 thread GR8 build can't wait to see it when it's done. RJ22
#78 |
Señor Member
I'm not quite satisfied with the corner, but here is some progress so far...
#79 |
Here is a couple shots of mine. I went with the biggest steel pan I could find.
And the vents sold it.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD Last edited by 67chevemall; 07-09-2010 at 02:26 PM. |
#80 |
tiggerstoy
i think i looks great, verry creative thinking i must say.....and when you figger out how to do pshopsdirectly to the truck....let me no!
#81 |
Used Register
#82 | |
![]() Join Date: Oct 2001
I like the rounded ends that follow the form of the fenders. Is this pan available commercially or did you make it. The filler panels on the fender bottoms look cool too. Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
#83 |
Señor Member
Are you talking about my truck or 67chevemall's?
#84 |
I was talking about the roll pan on 67chevemall's truck. The ends of the pan look like the bottoms of the fenders. It all looks like it goes together. It would also look great with your rounded upper ends.
Tom |
#85 |
why dont you use some cab corners to make the tranistion from the door skins to fenders.
#86 |
Señor Member
Got the corners rounded to my liking...
#87 |
![]() Join Date: Aug 2005
Awesome! Much better.
One observation I've made about roll pans in general: If they hang down too low they look like a little kid running around with a load in his diaper... ![]() I think they shouldn't hang down as low as the lower edges of the fenders. They can start even with the fenders, but angle up toward the rear. Make sense? Look at any sports car and you will see this aesthetic. You could do the same with yours. I pie cut my rear fenders to achieve this shape (not suggesting that you do, but...). Take a straight side shot of that area and post it for a PS if I'm not making sense. |
#88 | |
Señor Member
![]() ![]() Oops... wrong pic.
#89 |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#90 |
![]() ![]() ![]() You see what I'm sayin??? ![]() Last edited by Frizzle Fry; 03-22-2007 at 02:12 PM. |
#91 |
Fo real doe....
#92 |
Questionable
I personally don't like the "slits for brake lights" look. The rest of it isn't really terrible, but man, shaved doesn't look as good unless you have curvature and form, so a big flat piece of steel on the back of your truck looks like....well, a big flat piece of steel on the back of your truck w/paint applied.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#93 |
Señor Member
The pictures aren't as clear as the actual 3D view is... it is most certainly not a "flat piece of steel" (hell, it's shaped like the door... since it's a pair of door panels).
#94 |
Señor Member
The magenta is the curve above the lower body line (green line).
The purple is exaggerated a bit, but represents both the forward curve and the side curve, and it mimics the yellow lines on the rear fender. The orange (also exaggerated, but very clear in person) matches the door and front fender curves... and what would be on the bedside if a fleet bed. The blue line is an exaggeration of the curve the whole back has from side to side... ala the Caravan curve.
#95 |
chevelito
I think it looks like crap. I'll come by to take it off your hands and drop you my virgin bed instead. j/k. are you able to take a wider 3/4 angle pic to see how the rear flows with the rest of the bed?
jay
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI |
#96 |
I hope you don't mind a little constructive criticism. I love most of what you've done. Especially carrying the lower bodyline through the tailgate with the door skins and of coarse the rounded bed corners
![]() I was looking at the "gate" more and what doesn't seem to work for me is that it looks too tall. Maybe it's because the gate and pan are now one continuous piece. Obviously you are not going to change the top edge. So, if you make the purple curve more like the yellow curve and roll the bottom of the gate/pan under it would reduce the overall perceived height back there. I'd love to see some low-direct-rear shots and a straight side shot ...or you can just say shut the eff up and do your thing... ![]() ![]() Last edited by Frizzle Fry; 03-23-2007 at 11:45 AM. |
#97 | |
Señor Member
And, rather than tell you to STFU, I would just post something like the below. I keed, I keed ![]() ![]()
#98 |
![]() ![]() ![]() Have a nice Spring Break ![]() |
#99 | |
A guy with a truck
I'm with Frizzle on this one; I thought the plan was to use cab corners there? Either way, it looks great and will definitely be smoooooth. -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#100 |
Señor Member
progress <-- get it... small progress. I make me laugh.
First pic is of my new "don't stepside"...
