01-01-2007, 12:42 AM | #76 |
Re: 52 Project
I am looking at your front crossmember too. I have a Camaro front clip no my truck right now (junk). I have another frame that I going to buy to replace it. I plan on running a Mustang II set up. It looks so much cleaner!
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
01-01-2007, 01:34 PM | #77 |
Re: 52 Project
Thanks Brian,
Is Progressive the guys that do the Corvette suspension? That crossmember looks like it will really make a strong frame for these old AD's. I am looking at one from Industrial Chassie he said he wold have one by the end of the month, I will let you know what i think when I see it and the price !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
01-02-2007, 12:55 PM | #78 |
Re: 52 Project
I did a little work yesterday...mostly cleaning up some areas that needed some work. I did remove the old cab mount and took a few shots. Kinda boring but I will post them anyway. This was the worst part of the floor replacement so far but the pass side was much easier than the drivers side...probably because I knew what I was looking for after doing the drivers side. The silver paint on there is the POR15 that we coated the heck out of because after we install the cowl panel you can't get to it. I am hoping to get on the floor in the next week or so but I am still waiting on some parts before I can start.
Bernie |
01-07-2007, 04:40 PM | #79 |
Re: 52 Project
I went down to dad's today for a couple hours and got the cab mount in on the pass side. Here is some pictures in a step by step form...might be boring but I wanted to show the steps that I did so if someone else is going to do this then it might make sense.
The first thing I did was to grind the mating surface to make sure that is was flat. Then I used weld through primer on that surface of the cab mount. I then went to the cab and ground the area where the mount was going and prime that area also. The third picture shows the spacer washers that I used to space the mount up off the frame. Picture 4 and 5 shows the mount clamped to the frame and the rocker panel. |
01-07-2007, 04:54 PM | #80 |
Re: 52 Project
Here are some more pictures.
Picture 1 shows the cab mount tacked to the upper part of the of the rocker. There is a small gap at the bottom because of the way the original rocker is made. Picture 2 shows the gap closed up by the hammer method...lol. That is what the guy at *****in told me to do and it worked great. Sorry about the blurry picture but you get the idea. Picture 3, 4 and 5 show the finished cab mount in different views. I still have to weld the bottom but I can do that when I get the cab off the frame. I left the spacer washers in there to help support the mount while I get the floor sections welded in. I am going to do the drivers side next weekend the same way and hopefully the inner cowl panels will come in this week so I can finish the floor. I have to weld them in first before I can lay the floor. Bernie |
01-07-2007, 05:45 PM | #81 | |
Re: 52 Project
FatMan Fabrications makes a complete mustang II front clip. This would allow you to cut the camaro clip off of your truck and weld the MII stub on. This would probably save you some time from having to redo the entire frame. http://www.fatmanfab.com/07page6.htm Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 01-07-2007 at 05:47 PM. |
01-07-2007, 10:46 PM | #82 |
Re: 52 Project
Solid, I took a couple shots of the tranny crossmembers that we have. The first one is the original with a home made tranny mount. The second is the CPP (I think that who's it is) and the third is the Progressive monster. I just laid the pcs out for that and it still need to be welded together.
Bernie |
01-07-2007, 11:11 PM | #83 |
Re: 52 Project
Hey Brian, I like the third one !!!
I am waiting to see what Steve at Industrial Chassie builds for me!!
01-10-2007, 11:48 PM | #84 |
Re: 52 Project
thanks for the floor write up... great info. that will really help us. i should get a 4 day weekend 2nd week of feb and thats when the floor gets cut out and the bed comes off.
01-11-2007, 10:14 AM | #85 |
Re: 52 Project
I am planning on doing some more stuff this weekend depending on the weather. You might want to get your new floor before cutting out the old one because it comes with the braces that you are going to need to support the cab. Other than that good luck and have fun.
Bernie |
01-11-2007, 03:10 PM | #86 |
Re: 52 Project
Looking good Bernie!!
01-11-2007, 11:28 PM | #87 |
Re: 52 Project
Thanks Gator, We need to get together and swap truck stories one day since I am not to far from you.
Bernie |
01-17-2007, 08:40 PM | #88 | |
Re: 52 Project
was just checking in, we have been really busy so no new progress on ours. maybe in Feb, i have a 4 day weekend. my son is gonna have a few friends over to help with a 3 day wrench-a-thon to get some of the sanding done and the bed off. |
01-17-2007, 11:25 PM | #89 |
Re: 52 Project
Good luck with the wrench-a-thon. Thanks for the invite and I just might make it down there keep me informed.
Bernie |
03-05-2007, 08:11 PM | #90 |
Re: 52 Project
I got a little work done on the truck yesterday. Seems like I only get a few hours to work on the truck these days because of several other projects going on. I got the inner cowl panel fitted for the drivers side and probably will work on the pass side this weekend. I am planning on opening up the holes and plug welding them on. These have been more work than i had planned on...probably just getting to picky . Here are a couple of pictures.
03-05-2007, 09:40 PM | #91 |
Re: 52 Project
Looks good! Looks like everybodys down to a few hours a week these days.
03-06-2007, 07:57 AM | #92 |
Re: 52 Project
Yeah it seems like I have too many thinks going on and the truck/car projects have gotten put on the back burner. I am sure here pretty soon I will get a chance to have a good work week .
Bernie |
03-25-2007, 07:25 PM | #93 |
Re: 52 Project
Yahoooooooo!!!!!!!!! I finally got the floor fitted today. I still need to weld everything but at least the fitting is done. Here are a few pictures of what I got done today. Enjoy.
Bernie |
03-25-2007, 09:20 PM | #94 |
Re: 52 Project
Nice job Bernie, you are making great progress !!
Was that a kit from *****en? Is that what i need for a tunnel for a 700R to fit the floor of my 53/49?
03-26-2007, 09:30 AM | #95 |
Re: 52 Project
Solid, Yeah that is a *****in firewall and front floor kit. The back half is in good shape so we only went with the front half of the floor. I don't know if it will fit a 700, but I can tell you in a few weeks how it fits a 400....ok maybe a couple months..lol. I forgot all about getting you the measurement on the front axle centerline. I won't be able to make it out there for a couple of weeks if you still need it I will try to remember to measure it for you.
Bernie |
03-26-2007, 09:48 AM | #96 |
Re: 52 Project
Fordet the measurments, I had some help with the numbers and they are within 1/8" +/- so I went with them.
The only question I had was the rear bump stops C/L and 116" to the front axle C/L this did not measure out correctly, -1". I did check three other measurments and they we close enough for the girls we go with!!! Next measurment will be the motor mount placement, W/O the cab in place, I am hoping I can so it from the rear crossmember mount forward to engine mount, and then set the angle! You are making good progress, what brake kit are you using?
03-26-2007, 01:13 PM | #97 |
Re: 52 Project
I still need to relocate the motor so that won't be for a while. We are using the MII setup from Heidts on the front and Wilwood on the rear. We still have a ways to go before we get to the brakes. Hopefully there won't be too many problems with the brake system but I won't know til I get there.
Bernie |
03-26-2007, 01:45 PM | #98 |
Re: 52 Project
Man that is some really nice work you did pgf545! I love that fire wall!
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
03-26-2007, 04:26 PM | #99 |
Re: 52 Project
I agree, good work. My brother will want to see this. My mom's '54 needs new floors. Thanks for the pics!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe |
03-26-2007, 07:07 PM | #100 |
Re: 52 Project
Thanks Cal and Daniel. I think my dad was getting a little impatient with all my cutting and fitting but it really came out nice. I think he will be impressed with the final outcome.
Daniel, I am going to take it back apart to do the welding and I will try to get some step by step photos for you. I got a little ahead of myself and missed some shots. If you have any questions let me know. Bernie |
