Old 04-19-2007, 05:42 PM   #76
1969k10stepside
Re: The Wrecker Is Home
I prefer the 205 but......here is the choices.
203 is for a full time front axle.But,you can get a convert kit if you want to run lockouts on the front end.Which I prefer to use.
The 208 is a 80s model.You might have to use a different front driveshaft.
The 208 is alot lighter.They dont have to be converted to part time 4wd like the 203.
I believe that he has a 205/Th350 there,thats what I would choose.I would beef up the tranny if I was going with a turbo 350 though.It all depends on what all you plan to do with the truck,and if you want lockouts,etc
Last edited by 1969k10stepside; 05-30-2007 at 05:04 PM. Reason: it helps if I can spell right
1969k10stepside is offline   Reply With Quote
Old 05-30-2007, 04:47 PM   #77
1969k10stepside
Any more progress on it,Rick?
Old 05-30-2007, 05:01 PM   #78
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
the 208 is a part time t-case...isn't it?
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 05-30-2007, 05:03 PM   #79
1969k10stepside
Yes...They are part time transfer cases not like the 203.
Old 05-30-2007, 05:19 PM   #80
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Looking good so far
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-31-2007, 01:55 AM   #81
GREASEMONKEY72
GREASEMONKEY72's Avatar
looks good
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-02-2007, 12:22 AM   #82
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Not Much to Speak of, Had A Stupid Accident a Couple Wks after getting the Crew home from Troy's. Was moving a 4x4 Frame around & it rolled into my Leg & messed me up for awhile, Just now getting to where i can get around Good.
Actually tonight is 1st time i've even spent much time on the Board.....
Rick
toomanytoyz is offline   Reply With Quote
Old 06-02-2007, 12:26 AM   #83
1969k10stepside
ouch! Sorry to hear that,hope you get better
Old 06-02-2007, 12:32 AM   #84
toomanytoyz
Luv the Crewcabs
Thanks Dustin, Just got Lucky that nothing was Broke...........
Rick
Old 01-26-2008, 02:15 PM   #85
toomanytoyz
Luv the Crewcabs
Dropped a 6 cyl. down into the Wrecker to Make sure that Wrecker Part's would work before going to all the work of swapping it over to the 4x4 Frame. When cranking the Motor over the Driveshaft is Turning with the Tranny in Nuetral , Could that be something to do with the PTO for the Wrecker Bed or Have i screwed something up???
Fuel Pump was Bad & Was only able to get it to start with starting Fluid, Got a new Pump in it but hav'nt tried starting till i have some info on the Driveshaft turning, Once Motor is running, What Step's would be needed to Check out the PTO for Wrecker Bed???
Thanks, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 01-26-2008, 02:21 PM   #86
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Looking great!!! I remember when you started this post, seems like yesterday. Just real excited about seeing the old wrecker on the road again!
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 01-26-2008, 02:38 PM   #87
70cst
70cst's Avatar
Looks like a super project toomanytoyz! I bet you were a "WRECK" by the time you got your truck home.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 01-26-2008, 11:04 PM   #88
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks like shes gonna be prety sweet when shes done. Keep us posted..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 01-26-2008, 11:37 PM   #89
toomanytoyz
Luv the Crewcabs
I did a Google Search & Apparently Driveshaft Rotation in Neutral it is nothing to Worry about, Here are a Couple Quote's that i Found on Subject on message Board's.............
Drive Shaft Spinning while in Neutral
(1) While in Neutral the input shaft inside the trans is still spinning. With the drive wheels off the ground the gears inside the trans are spinning on roller bearings. With no drag they will kinda freewheel letting them turn some making the output shaft turn as well. There is nothing wrong, I've seen it a thousand times over the years, don't worry about it.
(2) its resistance in the transmission. Your gears ride the output shaft on bearings, and when there is no resistance at the wheels the small amount of resistance in the bearings will get the output shaft spinning.
Can anybody tell me what to expect with the PTO, Do u Just engage it & Then Control Motion with the Lever's at the Back of Wrecker Bed?
Thanks, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 01-27-2008, 03:32 PM   #90
abebummy26
abebummy26's Avatar
That is gonna be really nice Rick Gotta love the Chevy orange!
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 01-27-2008, 09:59 PM   #91
72gord
Never enough time!!
72gord's Avatar
Rick, every wrecker I've been around thats how it works clutch and engage pto, release clutch and use levers/controls on wrecker bed to control cable operations, good luck
72gord is offline   Reply With Quote
Old 01-28-2008, 07:53 AM   #92
Rod
Wreckers usually have the winch control either direction of the wire pull. So you only need a one way PTO in that case.
My Holmes winch is such a model and I just engage the PTO then go to back of truck and can have the cable go in or out via the lever.
Some have a free wheelking option too so you can just splool the cable out when winching from the rubarb.
Some bigger and older winches use a two way PTO, and you need to unwind or pull the cable either way by switching the direction via the pto.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 03-28-2008, 06:32 AM   #93
toomanytoyz
Luv the Crewcabs
Got the Pto For Wrecker Working Now, Got the Motor Running Good & Having been Plugging away at Getting it Finished up. Just Got it Painted Today, Not Too Bad for the 1st Vehicle i ever Painted ,Going to Use Bed liner Spray on the Lower section of Cab is why it's not Painted. Just not Sure i Like it all Red???
I Have Decided to Just leave it as 2 wheel Drive, Want to Finish this Up so i can Get to work on my Crew cab Stepper Build............
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 03-29-2008, 06:25 AM   #94
ed2552
ed2552's Avatar
looks like it is going to be a fun truck to haul future projects home on
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 03-30-2008, 02:04 AM   #95
1972CheyenneSuper
1972CheyenneSuper's Avatar
Here's a brochure on that Holmes 480 of yours. Kind of handy just so you know the specs on it.
http://zips.com/images/brochures/480%20mechanical.pdf
$500 for that 1-ton w/ Holmes 500 was a heck of a deal as well. Great looking trucks, I hope to watch updated progress on them.
1972CheyenneSuper is offline   Reply With Quote
Old 03-30-2008, 08:55 AM   #96
Jerry Jones
Happy Camper
Jerry Jones's Avatar
Keep it up man, and keep us in the loop! Looks great!
RIP El Jay! Love you brother!
Jerry Jones is offline   Reply With Quote
Old 03-31-2008, 08:36 AM   #97
ole school
ole school's Avatar
that will be a fun truck.ive had mine for 4 yrs after restoring it
IT'S HARD TO MAKE CHICKEN SALAD WHEN YOUR USING CHICKEN S.........
1968 crew cab build (under construction)
ole school is offline   Reply With Quote
Old 03-31-2008, 08:44 AM   #98
toomanytoyz
Luv the Crewcabs
What are the Details on Your's? Got any Pics of it Posted anywhere? Got New Cab Bushings installed Today & Should be able to Get the Doghouse on Tomorrow & Then Not Much more to do other than Putting interior back Together..........
Thanks, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 04-01-2008, 05:39 AM   #99
toomanytoyz
Luv the Crewcabs
Managed to get the Doghouse back on Today, Will start on interior Next, Getting Close Now...................
Would Still like too break up all the Red Somehow???
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 04-01-2008, 05:43 AM   #100
ed2552
ed2552's Avatar
Put a logo on the door
