View Poll Results: What Material Would You All Like For These Trailing Arms? | |||
Steel Round Tubing, 2" or 2 1/2" O.D. Least $$ | 4 | 7.69% | |
Steel Rectangle Tubing, 1/8" x 2" x 3" Moderate $$ | 21 | 40.38% | |
304 Stainless Round Tubing, 2" or 2 1/2" O.D. Moderate + $$ | 12 | 23.08% | |
304 Stainless Rectangle Tubing, 1/8" x 2" x 3" Most $$ | 15 | 28.85% | |
Multiple Choice Poll. Voters: 52. You may not vote on this poll |
04-05-2007, 05:07 PM | #76 |
Junior Member
Re: Stainless Steel Rear Trailing Arms...?
Maybe two bucks....
STAINLESS ARM PICS, FINALLY! These pictures are beautiful examples of how bad my photography skills are.... The black lines on the arm are there to help show what I mentioned earlier about how and where the arm widens in a gentle curve on each side for 24", and then maintains its width all the way to the rear. The holes may be milled today, and the front bushing is ready to install once the front 3" or so of the arm is tapered down and curved for clearance on the mount. The rear end adjustment will be from the oval inserts discussed earlier. This arm took less material, and only 9 pieces compared to the way-too-many-piece steel one, and is a solid 50% stronger. The curved sides, multi-internal box construction (near honeycombed) and being welded inside and out made this thing stupidly strong. The streaks and smudges are just from the light, I guess. I gave the thing a hasty brushed finish, but the camera didn't seem to care I'll try for some better pics...
Ryan Metal Massacre Fabrication New Projects: -New radiator core supports, steel and stainless -Aluminum radiators -Aluminum dual electric fan shrouds '69 C-20 Custom '69 Nova...BIG BBC soon '72 3-door 'Burb...in a few '94 K2500 454 'Burb |
04-05-2007, 05:18 PM | #77 |
Active Member
Those look sweet. Such a shame that the untrained eye won't notice them when they are installed.
Sonny New Project: 67 Small window SWB 2006 Crew Cab Silverado LT |
04-05-2007, 10:24 PM | #78 |
Junior Member
True, but then again I dont really want people crawling under my truck... falling rust hazard... The reason to build these (to me anyway) is for longevity. I plan on driving my truck for a good 30+ years, and anything that can be feasibly replaced with a stainless part, will be. You could soak these things in salt water for the next 35 years, scrape the marine growth, and they will look like new.
10-22-2007, 10:02 PM | #79 |
Those look awesome. I'd definetly like a pair if the budget allows. Any updates?
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown '70 SWB Step-Side (More rust than metal) |
10-25-2007, 09:33 AM | #80 |
Those look sexy! I'd be happy to stress test a set on the drag truck!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
10-25-2007, 09:51 AM | #81 |
More Cowbell....
Su-weeeet.
Keep the progress updated. We love us some pics.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
10-25-2007, 10:05 AM | #82 |
Wow, this is great. I have a C-20 that I am working with that has to stay a c-20 as well (Hauling hay bales 2x1600 lbs in the bed). Anyway, my trailing arms are coming apart, the lower plate that is on them is FLAKING away from the I-beam looking section. I guess my only issue is the price. $765 is a little north of the $500 that they were supposed to end up being. Guess I will have to start saving up my coin now. Hope you make these for a while, since it will take me a while to come up with the cash!
Orlando
70 C-20 Custom Camper Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=300251 |
01-24-2009, 07:44 PM | #83 |
back from the dead.....
what happened to these?
CHEVY ONLY |
01-30-2009, 07:49 PM | #84 |
I'd like to know also.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
01-30-2009, 08:59 PM | #85 |
those looked great!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
