#76 |
Re: 6" front drop question
No that was a mock up picture.. That was months (YEARS actually) ago.
-John II "A Little's Good! A Lot's Better! & Too Much is Just Right!!" -1978 Chevy C10 Stepside 350/4sp/12 bolt -1967 Nova 2dr HT & a couple others... ![]() Last edited by jr2; 05-23-2007 at 04:21 PM. |
#77 | |
![]() I gotta say though.. for as low as it is it sure does ride nice goin down the road.
-John II "A Little's Good! A Lot's Better! & Too Much is Just Right!!" -1978 Chevy C10 Stepside 350/4sp/12 bolt -1967 Nova 2dr HT & a couple others... ![]() Last edited by jr2; 05-23-2007 at 05:14 PM. |
#78 |
Chris
Well, around here I can't go anywhere I don't think. I have a inch or 2 roll down off my driveway, and then another inch or two drop off the sidewalk out front, let alone the holes in the road and bumps lol.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
#79 |
yeller
OK, if anyone is still following, here are the updated pictures.
![]() I have a L to R lean, not sure if it is the driveway/garage level that is causing it (they are both not level side to side), tire pressure, or suspension related. I will wait to address the issue until I can get it on flat/level ground and go from there. What do you think folks?
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#80 |
LOOKS PERFECT! as far as the lean, try swapping the springs side to side. I know it's the last thing you want to do but it worked for me
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction ![]() |
#81 |
Chris
I agree it's perfect what drop front and rear do you have on it right now in the last pics?
#82 | |
yeller
Airmale, thanks for the tip...I think I will try that tomorrow. ![]()
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 05-27-2007 at 10:18 PM. Reason: spelling correction |
#83 |
you got stance jeff............looks excellent.i can't see by your pics.that one side is off a little.are you getting tired of putting in and taking out coil springs yet?dumb smart as$ question i know.
" Never look up a dead dogs butt." ![]() |
#84 |
Until Seventy Times Seven
Been followin' from the beginning, Jeff.
The drop and the rake looks good. I guess when you get the color on it and finish the assembly, the stance may be a 'bit' lower. ![]() Should look really nice, once it done. It'll be a good example of a real low static drop that's driveable. ![]() Your persistence shows ...
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
#85 | |
yeller
Airmale, I did what you suggested and that did the trick for me too...thanks!! . . . In closing, the truck sits the way I like it, and will sit slightly better once I assemble everything and take it for a spin (let the suspension settle in). Thanks everyone for the help!!!
#86 |
Brother. . .....You nailed the 'look'. I love it. What front bumpstops are you going with?
The reason I ask is on mine I was going to use some shorter rubber stops (for a Chrysler product). They were a slightly denser rubber & were about 3/4" shorter than the stock rubber truck bumpstops. But, after I installed them I was buzzing the tops of my 27" tall tires way more than I liked. I wound up putting the truck bumpstops back in. They only allow about 1" of 'free' suspension travel before contact is made & the rubber starts compressing; but they keep the tops of the inner fenderwells off the tires. The ride isn't bad on decent roads, but it gets annoying on crappy, pothole-infested, inner-city roads (but that's better than the constant buzzing I was experiencing w/the shorter stops). I just want you to watch out for that shiny paint!!!!!!!!!!! Keep the updates comin'.
#87 |
Happy to be here
![]() Join Date: Mar 2000
Nice rake...
#88 |
I run 275 50x15's up front and no problems with close to a 5' drop. I have to slow down for speed bumps and avoid pot holes but this is pretty common when driving a lowered vehicle. At speed, cornering and turning in parking lots or drive ways again no problems. Tire size does play an important role in trouble free handling.
esll. ![]()
Tomorrow is for doing today's stuff. ![]() ************************************* This truck has just the right amount of energy for me! ![]() Author: Warren Lake .... (member) |
#89 |
THE VILLIAGE IDIOT
well looks ike you nailed the perfect look..truck looks good like that..
billy
honestly honey,,i have no idea how that truck got here. ![]() |
