Old 08-28-2007, 10:28 PM   #76
slimbailess
slimbailess's Avatar
Re: BACK in BLACK
Originally Posted by Texasbigblock View Post
Ive been trying to work all the little kinks out of my truck because i finally have it street legal and have been waiting two years to drive it! Maybe some of yall can help me out. First off, there is the power steering. I have a new (rebuilt) pump that has plenty of fluid in it (not too much or too little) and it wines all the time, even when im not turnin the wheel. Then it blows fluid out of the cap and when i open the cap its full of bubbles. I know the pumps are supposed to be self bleeding and it should have bled out by know, but bubbles indicate air in the system still, right? Now for the carburation issue: brand new holley 750 double pumper, worked great for a while.......then died on me all of a sudden....held pedal to the floor and it started (flooded) but kept flooding. I cleaned out the needles and it worked great for a while and then started flooding again. i have an inline fuel filter as well as the two rock filters in the carb.......where is this trash coming from?!? Appreciate the feedback!
in my experience, having put power steering on several 67-72s over the years, you need to fill the reservoir to the top, then start the motor and turn lock to lock till it quits whining, then refill...i have never heard of a self-bleeding p/s system...good luck and pretty truck
slimbailess is offline   Reply With Quote
Old 08-31-2007, 10:07 PM   #77
Jetrngr430
Jetrngr430's Avatar
Re: BACK in BLACK
NICE lookin' bowtie Very nice.
Jetrngr430 is offline   Reply With Quote
Old 09-11-2007, 08:08 AM   #78
Dova
Dova's Avatar
Re: BACK in BLACK
how is the gas tank treatin you behind the license plate? is it pretty convenient? by the way great paint job
Dova is offline   Reply With Quote
Old 09-25-2007, 10:32 PM   #79
Hardway
Re: BACK in BLACK
I had the same issue on my '69 Camaro when I put a new steering box on it. I filled the resevoir, jacked up the car leaving just a little pressure/resistance on the tires, started the car, and slowly turned it lock to lock. Did it about 5 times and its been quiet ever since. The pump will work the air bubbles out but I think having full load on it for some reason makes them stay in the system. Another thing, make sure your belt is tight enough aswell.
Jeff's Current Vehicles:
1989 Turbo Trans Am Pacecar
"Life is like racing, it goes by fast and has many turns"
Hardway is offline   Reply With Quote
Old 09-26-2007, 08:30 PM   #80
BHRS
BHRS's Avatar
Re: BACK in BLACK
Maybe recheck the fittings to make sure they are not sucking air into the system.
NICE TRUCK!!! I like the 69-70 frontend on it too.
1972 Cheyenne C10
Unrestored Original-3 Owner-RUST FREE Texas Truck
Big Block-TH400-PS-PB-AC-AM/FM Radio
BHRS is offline   Reply With Quote
Old 01-12-2009, 09:32 AM   #81
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Re: BACK in BLACK
I wanted to know how this tank worked out- This is an older post, So heres a bump and maybe someone knows results after road miles- Anyone else with the Camaro tank installed care to comment on their experience?
Thanks!
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 01-12-2009, 09:38 AM   #82
chuckmc8
chuckmc8's Avatar
Re: BACK in BLACK
Does the camaro Sending unit work correctly with our fuel gauges?
Old 01-12-2009, 09:59 PM   #83
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: BACK in BLACK
It should be 0-90 ohms just like your truck sender.
--Josh
Old 01-13-2009, 08:28 AM   #84
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: BACK in BLACK
I can't figure out why all the speculation on the tank. He took an unmodified Camaro tank and bolted it into his truck. Why wouldn't it work fine ? Lots of Camaros out there running them everyday.
And, if you read his thread he answered the sending unit question earlier. It's the same resistance as a truck sender so no mods needed.
Old 01-19-2009, 09:22 AM   #85
themikehyde
Re: BACK in BLACK
I love the concept. I am tryin to figure out if it would be possible to still install a receiver hitch. I was hoping to have that hidden behind my license plate rather than hanging down.
Mike
themikehyde is offline   Reply With Quote
Old 02-12-2009, 06:15 PM   #86
truckintexas
Thumbs up Re: BACK in BLACK
Kevin, the confusion or speculation, as you call it, stems from a few other posts. There seems to be a misconception that these tanks will not work in these trucks. I have read in other posts that filling from behind the license plate is impossible. In fact I just read it this week.
But this has to put in the proper context. That post that was referring to use with a blazer tank (and I agree that will not work). But the Camaro tank is a different animal.
I'm with you, this Camaro tank looks straight forward and this post has all the info....Michael.
truckintexas is offline   Reply With Quote
Old 02-12-2009, 06:30 PM   #87
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: BACK in BLACK
Mike
I have been looking into this as well. I think the problem is the Camaro and Chevelle tanks are a few inches wider then the frame rails, so the likelihood of a receiver hitch fitting is fairly low. Most hitches I have seen bolt to the bottom and/or sides of the frame rails. Since these tanks are wider on each side, based on measurements and pictures, a hitch would not fit.
At least that is what I have been able to figure out based on info found.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 02-12-2009, 09:05 PM   #88
jgrisafi
Velocity Speed Shop
jgrisafi's Avatar
Re: BACK in BLACK
Beautiful truck man. Black is perfect.
My Build Thread ..... http://67-72chevytrucks.com/vboard/s...d.php?t=288143
My Garage ..... http://www.hubgarage.com/mygarage/OCD69
jgrisafi is offline   Reply With Quote
Old 02-16-2009, 12:59 AM   #89
truckintexas
Re: BACK in BLACK
Chevy_Mike,
sent you a PM
Old 02-16-2009, 01:20 AM   #90
nuke1
nuke1's Avatar
Re: BACK in BLACK
if you are still having problems with your carb, check your float level, that is where i start, btw beautiful truck, how many hours in that polish job?
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 03-31-2009, 10:17 PM   #91
Texasbigblock
Texasbigblock's Avatar
Re: BACK in BLACK
wow, haven't checked this in a long while... sorry. As for the tank, like txfirefighter said, i don't understand why people keep thinkin it wouldn't work. I have been drivin it for two years and have never had any type of problem with it. Whenever i get my next project i plan on doing it all over again.
Nuke1: why do you ask about the polish job? wanna donate some time? haha
-Scott-
1970 C10 shortbed 396
1969 C30 dually flatbed "Vidalia"
Texasbigblock is offline   Reply With Quote
Old 04-04-2009, 07:59 AM   #92
RCbowtie69
RCbowtie69's Avatar
Re: BACK in BLACK
sweet looking truck, truely is black & looking great, keep pictures coming
RCbowtie69 is offline   Reply With Quote
Old 04-05-2009, 09:57 AM   #93
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: BACK in BLACK
Very nice....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-06-2009, 10:16 PM   #94
Texasbigblock
Re: BACK in BLACK
thanks guys, sorry it's been a while. didn't realize i never posted finished pics of the interior and all....so here ya'll go.
-Scott-
Old 07-07-2009, 06:42 AM   #95
nuke1
nuke1's Avatar
Re: BACK in BLACK
oh that is sexy looking, great looking truck all together, at least now i do not have to donate some time polishing her, but since you have some free time on your hands now that she is done, why not come up here and help me out some eh! lol. nicely done on the truck, got any bigger pics?
James
1968 GMC "HAVOC"
1986 GMC "Frank"
Old 09-06-2009, 10:42 PM   #96
mcbassin
Still Learning
mcbassin's Avatar
Re: BACK in BLACK
Very nice black paint! I never saw it in any of your posts so sorry if it's a repost. What kind of paint did you use? It looks like Lacquer but I guess it could be some of the new Base Clear sanded and polished?
BTW, I love the way you kept the stance of the truck and the Kragers....looks great!
mcbassin is offline   Reply With Quote
Old 09-08-2009, 07:38 PM   #97
72 SUPER10
Re: BACK in BLACK
NICE TRUCK ,GOOD WORK, VINCE
72 SUPER10 is offline   Reply With Quote
Old 09-08-2009, 07:41 PM   #98
big mike71
big mike71's Avatar
Re: BACK in BLACK
Nice truck, how did you get those old style Cragers to fit.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 09-08-2009, 09:58 PM   #99
HuggerCST
HuggerCST's Avatar
Re: BACK in BLACK
I agree, VERY nice!
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 09-12-2009, 07:20 PM   #100
Texasbigblock
Re: BACK in BLACK
they have always fitted these old trucks....and look great on them in my opinion...although some have accused cragars as bein out of date on here
-Scott-
