Old 10-28-2009, 10:30 AM   #76
SCOTI
SCOTI's Avatar
Re: Heavy Chevy -- the penny pinchers rebuild
Gotta love momentum!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-29-2009, 06:20 AM   #77
panhandler62
Java Mechanic
panhandler62's Avatar
I just waiting for the trailing arms and panhard bar from Nate then I will have all the big ticket items I need for the suspension. I'll need some little stuff (tie rod ends, ball joints, bushings, etc. but that stuff is easy to hide in the grocery budget.) I was originaly going to re-use the stock trailing arms but the more I looked at them the more I wasn't real happy about the rust in them.
Got my $40 ebay intake manifold in yesterday too. I have a pic on the camera at home -- I'll post that later.
The biggest roadblock I'm looking at right now is getting tat last cross member and the rotted out frame stiffeners off the frame so I can install the c-notches and decide if I need more stiffening plates in that area or not.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 04-05-2010, 03:01 PM   #78
panhandler62
Java Mechanic
Well... the weather got nice again so I got back into it.
This is the left side. The notch plates are bolt-ons but they don't *really* fit, so I'm weldig the bugggers. I had to remove a lot of material that was compromised so I'm going to have to add a new stiffener anyway.
Sorry to offend with my row-o-buggers (as opposed to stack-o-dimes) beads, but I'm learning as I go. Haven't welded since HS.
Keith
Old 04-05-2010, 05:39 PM   #79
panhandler62
Java Mechanic
Here is a lovely picture ... I had to remove a lot of rot. I'm going to be doing some re-enforcing once I put the c-notch plate on.
Keith
Old 04-05-2010, 08:09 PM   #80
panhandler62
Java Mechanic
Working on the right side..... hopefully my welding skills will improve by the time I get to sheet metal! lol
Keith
Old 04-05-2010, 08:10 PM   #81
panhandler62
Java Mechanic
Next I'll get the left side then do something about making some backing plates to shore up the insides.
Keith
Old 04-07-2010, 12:43 AM   #82
srr
Thumbs up Re: Heavy Chevy -- the penny pinchers rebuild
Nice work so far!
srr is offline   Reply With Quote
Old 04-07-2010, 04:29 PM   #83
panhandler62
Java Mechanic
Ran out of welding wire again... have to pick more up this weekend. I also need to get some plate so I can box in the frame around the c-notch. I had to remove a lot of frame to get rid of all the rust so I thinkk it needs a bit of re-enforcement.
Keith
Old 04-10-2010, 05:49 PM   #84
panhandler62
Java Mechanic
Phew...... ok... got this part done... I'll start working on getting the trailing arm cross-member out tomorrow. I already cut the heads off the 6 rivets on the bottom but I think the 4 on top might be.. err... amusing.
I have a new cross-member from Nathan Porter so I may hack this one to bits if that makes it easier to get out. lol
Keith
Old 04-10-2010, 06:38 PM   #85
SCOTI
SCOTI's Avatar
Would definitely be easier.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-10-2010, 11:51 PM   #86
ripdog28
ripdog28's Avatar
We must have had the same training for welding. Yours look just like my own do.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 04-11-2010, 06:09 PM   #87
panhandler62
Java Mechanic
When I said this thing was coming out in peices I wasn't kidding! lol
The best news though... I have now removed the LAST RIVET I should throw a party or something! lol
Keith
Old 04-11-2010, 06:10 PM   #88
panhandler62
Java Mechanic
This peice from Porterbuild (Nathan rocks!) is going to look and work a lot better than the original c.member.
Keith
Old 04-12-2010, 10:58 AM   #89
srr
Great work! I love threads like this.
I'm a retired Navy HTC and welding instructor so may I suggest some welding tips?
1, Slow down! Do a dry run before you pull the trigger to see if you can complete the entire bead without moving around.
2, Watch the puddle NOT the arc, maintain your 10 degree lead angle and your 3/8" distance from your work. Your molten puddle should be as round as possible but not piling up. Use two hands until you get really good.
Old 04-12-2010, 11:21 AM   #90
panhandler62
Java Mechanic
Mocking some things up here. Trying to decide if I want/need to add a plate to cover the portion of the airbag that will extend past the frame. The bolts in the top of the airbag are pretty much centered in the heavy, re-enforced plate of the c-notch.
Keith
Old 04-12-2010, 11:40 AM   #91
panhandler62
Java Mechanic
Thanks.... every bit helps. I haven't used a welder since HS (never mind how long ago that was! lol) ... so I'm learning as I go.
Keith
Old 04-12-2010, 01:23 PM   #92
SCOTI
SCOTI's Avatar
Any reason why you didn't bolt it in w/quality GRADE-8 hardware & then weld the perimeter? Not being 100% in the welding category does not afford margain for error in a 'critical control' point.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-12-2010, 02:18 PM   #93
panhandler62
Java Mechanic
I have all the bolts that came with htem. I'm going to drill the holes and use them. I'm just scattered in my approach.
Keith
Old 04-14-2010, 04:06 PM   #94
panhandler62
Java Mechanic
Got the Track arm mount back on the frame... man -- drilling through the c-notch plates is killing me. I'm going to go get better drill bits! Hope to get the bags mounted today and then, this weekend, my boy and I will get the rear-end in shape so that can go back in.
edit: Change of plan. The more I looke over the situation the more I saw all kinds of irratations arrising with the idea of mounting the bags directly to the frame. I'm going to get some brackets to simplify this bit.
Keith
Old 04-20-2010, 11:54 AM   #95
highperf4x4
Subscribed
highperf4x4 is offline   Reply With Quote
Old 04-26-2010, 05:22 PM   #96
panhandler62
Java Mechanic
It doesn't look like a weekend's worth of work, but with all the rain... it will do. lol
Installed a new pinion seal and cleaned and painted the pinion cover and yoke. I was hoping to have the third member done by now, but weather and stuff keeps coming up.
:P
Oh well.. give me something to kep me busy this weekend and I'm still waiting for the upper bad blanks to show up so I can't get the rear completely fitted and installed yet anyway.
Keith
Old 05-01-2010, 07:59 PM   #97
panhandler62
Java Mechanic
I didn't want to mount the bags directly to the frame and I couldn't find a ready made part that seemed to work here so I called Mat at ***************** and he suggested I just make something.
I got a couple single-port blanks and made 2 of these to mount the top of the bags:
Keith
Old 05-01-2010, 08:02 PM   #98
panhandler62
Java Mechanic
Since I had a cutting wheel on my grinder I went ahead and hacked the stock panhard bar mount off.
As the pool under the snout of the rear-end attests; I obviously didn't get the nut on the pinion tight enough... oh well.. put that back on the list... lol
Keith
Old 05-02-2010, 01:54 PM   #99
ibad57
ibad57's Avatar
Im in the progress on mine where you are i seen these brakets on here some where but couldn't find supplyer they were called bag hat look as though they would simflyfy things but pryer to mounting c notch i layed out the three holes needed on the notch and drilled holes before mounting notch.
It was much easyer on drill press than on frame working upside down.
I too had only rust to mount bag to before.
I think jeff at CPP should sell the notches with air bag hole's
I just found your build thread guess at this point penny pinching don't always work. Keep up the good work
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172
ibad57 is offline   Reply With Quote
Old 05-02-2010, 08:54 PM   #100
panhandler62
Java Mechanic
I got them all in place now. Nothing is tight yet.. I need to take a bunch of measurements first and make sure the geometry is right, but it's sure nice to see it moving forward after being a lawn ornament for so long. I think those are front upper cups for an S-10. They probably work just fine in this application though.
I rather enjoyed making my own and in making them rectangular they won't be as likely to collect rain and what-not. I should have left more side clearance though because the nuts to hold the bags in place were very close to the sides.
I'll be working on that rear end next.. get it leakeless, re-lubed, new brakes and clean 'er up and paint 'er nice.
If things go well I'll be burning my fingers patching the cab before fall.
Keith
