Old 12-04-2008, 12:31 PM   #76
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Re: Gulfcoast66 rebuild. Rust don't sleep!
For my brake booster and m/c I used a complete unit from a 72 pick-up. Drilled 3 holes for the bracket on the firewall, and mounted it, I still need to take the push-rod to work with me and weld the 66 and 72 together to make it longer its about 2 1/2 in too short to line up with the foot pedel..[IMG][/IMG]
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 12-04-2008, 12:32 PM   #77
gulfcoast66
64-66 CHEVY JUNKIE
[IMG][/IMG]
Old 12-04-2008, 12:33 PM   #78
gulfcoast66
64-66 CHEVY JUNKIE
[IMG][/IMG]
Old 12-04-2008, 12:34 PM   #79
gulfcoast66
64-66 CHEVY JUNKIE
[IMG][/IMG]
Old 12-04-2008, 12:41 PM   #80
gulfcoast66
64-66 CHEVY JUNKIE
[IMG][/IMG]
Old 12-04-2008, 12:42 PM   #81
gulfcoast66
64-66 CHEVY JUNKIE
[IMG][/IMG]
Old 12-04-2008, 12:45 PM   #82
gulfcoast66
64-66 CHEVY JUNKIE
[IMG][/IMG]
Old 12-04-2008, 12:56 PM   #83
gulfcoast66
64-66 CHEVY JUNKIE
No that the front is 5 lug its time to match the back with the front. I installed a you guessed it 72 rearend 1/2ton from a suburban.[IMG][/IMG]
Old 12-04-2008, 12:57 PM   #84
gulfcoast66
64-66 CHEVY JUNKIE
[IMG][/IMG]
Old 12-04-2008, 12:58 PM   #85
gulfcoast66
64-66 CHEVY JUNKIE
[IMG][/IMG]
Old 12-04-2008, 12:59 PM   #86
gulfcoast66
64-66 CHEVY JUNKIE
[IMG][/IMG]
Old 12-04-2008, 01:00 PM   #87
gulfcoast66
64-66 CHEVY JUNKIE
[IMG][/IMG]
Old 12-04-2008, 01:00 PM   #88
gulfcoast66
64-66 CHEVY JUNKIE
[IMG][/IMG]
Old 12-04-2008, 07:01 PM   #89
joe231
joe231's Avatar
Looking good!!
CHEVY ONLY
Old 12-04-2008, 07:19 PM   #90
gulfcoast66
64-66 CHEVY JUNKIE
Thanks Joe, Im just itching to get it running agian.
Old 12-04-2008, 08:15 PM   #91
smiti7
smiti7's Avatar
Man you're making some great progresss. Looks good!
smiti7 is offline   Reply With Quote
Old 12-04-2008, 10:00 PM   #92
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Nice work Keep it up
Alan's Classic is offline   Reply With Quote
Old 12-04-2008, 10:57 PM   #93
TimE
Hey Y'all!!
TimE's Avatar
Nice! Your moving along with it.
TimE is offline   Reply With Quote
Old 12-05-2008, 11:45 AM   #94
gulfcoast66
64-66 CHEVY JUNKIE
Thanks smiti7, just wish i had more time too get it done.
Old 12-05-2008, 11:47 AM   #95
gulfcoast66
64-66 CHEVY JUNKIE
THANKS alan and timE.. Chris..
Old 12-05-2008, 12:16 PM   #96
4dranch
Shloooooong bed member #2
4dranch's Avatar
Gulfcoast66, I wish I had half the skills you guys have...them rims and tires look sweet. Keep the pictures coming.
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 12-08-2008, 12:12 PM   #97
gulfcoast66
64-66 CHEVY JUNKIE
Thanks 4dranch, Heres some more pics, Last night i took my 72 brake push rod to work and cut the rod in the middle and took a hex bolt same od size as the rod and cut a 2 1/4 section out the center of the bolt, belved all the ends and welded them together. Not the best weld in the world but it will get job done Got home this morning and put it together and everything lined up good. And since i was in the mant. shop I drilled some air holes in those two front covers by the rad. Dont know the correct name for them, Since ill be running a bigger rad. give it a little more air. Chris..
Old 12-08-2008, 12:15 PM   #98
gulfcoast66
64-66 CHEVY JUNKIE
[IMG][/IMG]
Old 12-08-2008, 12:16 PM   #99
gulfcoast66
64-66 CHEVY JUNKIE
[IMG][/IMG]
Old 12-08-2008, 12:17 PM   #100
gulfcoast66
64-66 CHEVY JUNKIE
[IMG][/IMG]
